Restart Time
Page 1 of 11 123 ... LastLast
    Restart Time
    Restart Time
    How to See What Your Windows Restart Time is
    This will show you how to see how long in seconds it takes your Windows 7, Windows 8, or Windows 10 PC to restart back to the desktop.
    You can also view the startup logs in Event Viewer (C:\Windows\system32\eventvwr.msc) under Applications and Services Logs, Microsoft, Windows, Diagnostics-Performance, and Operational. The logs will be in the middle to show you what ran at startup, how long it took, and more.
    Credit completely belongs to sidney1st for writing this VBS script.
       Tip
    For fun, post your restart time at this link.
    Here's How:
    1. Click on the download button below to download the Restart-Time.bat or Restart-Time.vbs file, and save it to your desktop.
    Restart-Time.bat
    Download
    OR
    Restart-Time.vbs
    Download
    2. Right click on the downloaded Restart-Time.bat or Restart-Time.vbs file, click on Properties, click on the General tab, click on the Unblock button to unblock the Restart-Time.vbs file. (see screenshots below)
    NOTE: If you do not have a Unblock button, then it is already unblocked. Continue to step 3.
    3. Run the Restart-Time.bat or Restart-Time.vbs file.
    4. Click on OK to restart the computer. (see screenshot below)
    WARNING: Close and save all windows first. This will immediately restart your computer.
    5. When the computer finishes restarting, you will see your Windows restart time. Click on OK when done. (see screenshot below)
    6. You can now delete the downloaded Restart-Time.bat or Restart-Time.vbs file if you like, or save it somewhere to use again later.
  1. Posts : 2,899
    you should to add to unblock vbs since it would add to the time shown in the restart time...
    just a thought
  2. Posts : 72,072
    Good ideal Darkassain. Done.
    Thank you,
  3. Posts : 14
    Win 7 Pro SP1 and Win XP Pro SP3 32bit
    Is there a way to make one of these just for boot up time?
  4. Posts : 72,072
    Hello Seeker, I will forward this to the script author to see if it is possible :)
  5. Posts : 92
    Windows 7 Home - 64 Bit
    Brink - Hello! I tried your script to capture "The windows Restart time" for windows 7. I used the snipping tool and I can't see how to paste an image here. I think that You told me that, the "How to was over in thew Vista 64 forum." Could you assist me with that. Thank You - Patrick C
  6. Posts : 4,282
    Use the advanced option on your post, then select the paperclip to attach your image and once you have uploaded it close that window and select the paperclip again and your image to place the image in the post.
  7. Posts : 14
    I'm just curious,because I tried boot trace with perf toolkit and that didn,t work for me,and of course bootvis doesn't work either.
  8. Posts : 72,072
    Seeker,
    I have not heard anything back yet, but if you make sure you have nothing running when you restart the computer each time, then the shutdown time only adds a few seconds to the total restart time to make it pretty accurate for the boot time.
  9. Posts : 16,166
    7 X64
    Hi Patrick,
    To post a jpeg, click the Go Advanced button at the bottom of the thread page and follow step 8 onward of this tutorial
    How to use the Snipping Tool in Vista - Vista Forums
    Hope it helps
    SIW2
      My Computers
