Icons - Change Using Resource Hacker
Page 6 of 10 FirstFirst ... 45678 ... LastLast
  1. Posts : 220
    Windows 7 Ultimate
       #50
    Arc the prob is that Thumbnail is turned off & acc. to Thumbnail Previews - Enable or Disable. That's what i was thniking how to get rid of it because i can't turn off something which is already off.
    Can't i use any other folder icons as i have Leopard icons that's what i have used over here???
    Or does it need to be done through only custom live folder icons?? Ohh i love my old Mac please i don't want to use any other icons set there is no way to get this right???
    What is causing some icons to be the same???That's what even more disturbing (i'm Ok with other things).
  2. Arc
       #51
    After disabling thumbnail preview still thumbnails are being shown ? Try Icon Cache - Rebuild . It will clear your existing icon cache so that the previous effects dont come there any more .
    Mac folder icons are cool , you may apply those too ... in the place of the book
  3. Posts : 220
    Windows 7 Ultimate
       #52
    Sorry Arc i couldn't reply soon but i resolved the problem of thumbnail,all folders not being changed to "book", they were few options that i tried & now everything just fine & every folder in my windows know got the "Mac Book" look...
    Btw that "book" folder icon is Mac Leopard Icon.....Thnx anyway for your
  4. Arc
       #53
    That's the dictionary icon
  5. Posts : 2
    7 Ultimate x86
       #54
    How about taking it a little bit farther ...
    That was an excellent tutorial. Now I would love to see how one can change the association of the "Games" and "Favorites" folders to those of one's liking, since
    right clicking on them doesn't show "Properties" option, thus not allowing to change
    the path to them.
  6. Posts : 328
    kevin21388 said:
    By changing the imageres.dll files, it changed some of the icons, but not all of them. What is going on with it?
    As your system is x64 did you make the changes to *both* imageres.dll files?
    1st. C:\Windows\System32\imageres.dll
    2nd. C:\Windows\SysWOW64\imageres.dll
    You should reboot following each occasion you take ownership of system files. I say this because often people have issues when renaming the files straight away.
    Before flushing or rebuilding the icon cache try restarting Explorer cleanly by typing "TSKILL EXPLORER" *without the quotes* in the start/search box and hitting return.
  7. Posts : 435
    What if I wanted to change the opera.exe icon for example using ResHacker?
    I'm assuming you open Program Files / Opera / opera.exe or wherever it's located.
    And find a 1033 file or something.
  8. Arc
       #57
    To change the Opera.exe icon, you need not to take all the hazards. You are to use the desktop shortcut for Opera, and change it. Right click on the desktop icon > Properties > Change Icon > Browse (to the location where the substitute icon is stored) > OK > Apply >OK .
    It will change the icon of a particular program throughout the system .
  9. Posts : 435
    But after I surf the Web automatically for 30 minutes, the icon comes to a blank icon or the Opera icon.
  10. Arc
       #59
    In this case you may change it ....
    If you do it, please post the result back . I have never changed a third party program,s icon using this method .
