Hardware Identification
    If you have got hardware on your system, but are not sure of the manufacturer of that device and hence where to download drivers for it, then this might help. Note that it is not exhaustive, and that there may be omissions and possible errors.
    PCI Vendor and Device Lists
    To use it, simply find the relevant device IDs in the Device Manager. I shall use my graphics card as an example.
    To get this information, open the Device Manager. Click to expand the category you are interested in and then double-click the relevant sub-category (alternatively, click on the sub-category and then click on the Properties icon). In the Properties page that appears, click on the Details tab. In the Properties dropdown, select Hardware Ids. The information you require can usually be found in the first entry.
    The information that we want is already highlighted, so let's have a look at it in more detail. I've copied it here, to make it clearer.
    PCI\VEN_10DE&DEV_0611&SUBSYS_00000000&REV_A2
    We are only interested in the data highlighted in RED (the vendor) and BLUE (the device ID).
    Now that we have got this information, we need to input it on the website (link given above).
    Clicking on Search yields the following.
    Vendor search: (Useful for identifying the manufacturer's website.)
    Device search: (Identifies the device itself. Note that you need to match both IDs here.)
  1. Posts : 759
    Windows 7 Enterprise x64
    Good post, that's a useful tool. By the way, I have the same GFX card as you.
  2. Posts : 8,476
    Windows® 8 Pro (64-bit)
    Very useful. I always wondered what company make is my onboard sound card. Now I know its Conexant. :)
  3. Posts : 12,364
    8 Pro x64
    ddd
  4. Posts : 11,840
    64-bit Windows 8.1 Pro
    smarteyeball said:
    +1
  5. Posts : 15
    Thanks again!!
    I will try that when I am at my work PC tomorrow. I already know its a SigmaTel card fitted as standard on my Dell 1510c. I have seen loads of posts/complaints about the absence of a Win 7 driver for this model but I will certainly try this solution.
  6. Posts : 2
    MT
    Windows 10 solved: with Win7 x64 driver
    THANK YOU so much!
    I installed Win 10 Pro on an inherited HP ProBook 6555b and most drivers were OK except three.
    I found a post where the HWID was the same as mine via Google. The solution was an HP Win7 x64
    driver from the mfr site. Fixed one problem.
    Then I had two mystery Error 28 drivers; used this post to figure out it was a Ricoh SD card PCI driver.
    Went to HP, downloaded the Win 7 x64 driver, BOOOM! Fixed BOTH Error drivers in Win 10 pro.
    Thank you
  7. Posts : 0
    The vendor/dev link no longer works.
  8. Posts : 2
    MT
    Use this link: PCI Lookup
  9. Posts : 0
    Nice, thanks! Bookmarked.
