#270
Hi, I have a problem with my LCD 32''. The native resolution is 1280x720. I have no problem setting it and even no problems forcing the refresh rate to 75hz (as I had it on WinXP but no forced then).
The problem is that I had the edges off the screen. So the "default" resolution happens to be 1216x684. I can't force the refresh rate with that resolution and some games didn't recognize it (only has the "standards" on wich I had the edges off the screen).
I tried a few nvidia drivers (I have a MSI GTX560 Ti) and a couple of the tweaked ones and nothing.
The TV doesn't has any options to resize the screen (i mean, in the remote).
I've tried the tutorial. I can generate the *.INF and "update" the monitor driver, but nothing happens after the reboot, the refresh rate is the same, also the resolution and obviously, the edges are off the screen.
Any help?
Thanks in advance.
