Hibernate - Enable or Disable
Page 11 of 12 FirstFirst ... 9101112 LastLast
  1. Posts : 2
    windows 7 home premium 64bit svc pk 1
       #100
    thank you Shawn, straight way gained back 5gigs on my system, when i set the hybernate, i had no idea this was happening, and i keep a sharp eye on my memory, i used the command prompt, because i started out in dos in the mid 80's learning to be a programmer, and am more familiar with it, but i'am still missing about 5gigs, guess i'll have to start a thread or do a little more archive hunting, anyway thanks as always when i come here i always get real working solutions. tothe3rdpwr
  2. Posts : 72,076
       #101
    You're welcome tothe3rdpwr, and welcome to Seven Forums.
    In addition, the tutorial below can help you free up more hard drive space. :)
    Hard Disk Space - Free Up and Recover
  3. Posts : 2
       #102
    to melissasoua3
    i had hibernate active cause i thought it was cool when i closed my laptop, i could come back to my session, web and all, but i like movies and music, and always kept track of my harddisk space, cause they eat alot ( click, start, go to computor and a quick glance shows your available space) when i began to notice 5 and 10 gigs at a time vanishing, with no downloads, so i came here, and got the answers i needed, i also got back 10 more gigs by using a program that is in "system mechanic" called " program accelerator " which realigns programs and dependant files, but it can take more than 2hrs depending on the size of your HD and how jumbled your files are, system mechanic is free to dwnld, and program accl. will work but its a trial version, but it did get the job done, i also believe that a boot time defrag will also help which i believe also helps in system performance ( i have the paid ver.) hope this helps, and weekly maintenace is a good idea and will prevent alot of problems, its like getting a cold, you were already sick but its not till you crash that you really notice. also check out the tutorials on freeing up hard disk space, very good stuff....
  4. Posts : 67
    Windows 10 Pro Insider Preview + WSL2
       #103
    (OPTION ONE) (To Disable Hibernate) NOTE: This step will disable hibernation, delete the hiberfil.sys file, and remove the Allow hybrid sleep and Hibernate after Power Options under Sleep.
    but it will leave 'hibernate' in 'Battery>Critical battery action' in power plan. I was working ignoring 'battery low' warnings and suddenly KABOOM! screen black, no power. System didn't shutdown/sleep when battery got critical, it was set to hibernate but the function was disabled. (windows 7 Pro x64)
  5. Posts : 72,076
       #104
    Hello mt12345,
    Hmm, interesting. I never noticed that before. I updated the tutorial for this to help others avoid that.
    Thank you. :)
  6. Posts : 5
    windows 7 pro x64
       #105
    hibernation--disable "wake on..." "feature"
    Hibernation is working fine for me, but soon after it completes, the system wakes up, probably as a result of receiving an e-mail. I want hibernation to last until I turn the machine back on.
    How do I do that?
    Thanks,
    Steve Samson
  7. Posts : 1
    windows 7 64bit
       #106
    I do not have hibernate in any of my power menus. I have Windows 7 64 bit.
    I have tried the option to run in command window and get the following messages:
    C:\Windows\system32>powercfg -h on
    Hibernation failed with the following error: The request is not supported.
    The following items are preventing hibernation on this system.
    An internal system component has disable hibernation.
    I have also downloaded and run the enable hibernate script and still do not
    have hibernate in my power menus. Any suggestions?
  8. Posts : 72,076
       #107
    Hello Tom, and welcome to Seven Forums. :)
    If this Windows is a virtual machine or on VHD, then hibernate is not available.
    If not, then double check to make sure that you are not having any issues with your display adapter in Device Manager, and that you have the latest drivers installed for your graphics card/chip.
  9. Posts : 5
    windows 7 pro x64
       #108
    Brink,
    Perhaps you can help me with the post I originally placed in this thread: I have a rather new HP desktop with Windows 7 Pro 64. I can enable hibernation and put the machine into hibernation just fine, but within a (variable) short time, the machine starts up again. I think it's some sort of "wake on e-mail" trigger, but I cannot find any way to control it. I would like hibernation to remain in effect until I hit the power button.
    Any ideas?
    TIA,
    Steve
  10. Posts : 72,076
       #109
    Hello Steve,
    Yeah, that would be a wake up issue instead of for enabling or disabling hibernation.
    For your issue, you could use the tutorial below to read your wake source event log to see if it may help to ID what it waking the PC.
    Wake Source - Read Event Viewer Log
    Afterwards, you could see about disabling whatever may have woke the PC up. :)
