Aero Peek - Turn On or Off
Page 10 of 11 FirstFirst ... 891011 LastLast
  1. Posts : 72,054
       #90
    IJmir said:
    Shawn,
    Yes, Options 1 and 2 work, but they only disable Aero Peek for a peek at the Desktop. So I am still stuck with annoying windows popping up every time I move the cursor too low
    Is there really no way to get rid of this feature?
    IJmir
    Oh, I see. You were wanting to stop the "Show Desktop" pop-up instead. The tutorial is not for that, but only to turn the Aero Peek feature on or off for the transparent window look.
    Sorry, but there is no way to stop this pop-up other than not hovering over the Aero Peek/Show Desktop button on the taskbar.
  2. Posts : 72,054
       #91
    IJmir,
    I just remember this that will remove this button from the taskbar that may work for you. :)
    https://www.sevenforums.com/tutorials...e-taskbar.html
  3. Posts : 23
    Aero peek
    Looking at your earlier reply, I think we may have misunderstood each other. You wrote "You were wanting to stop the "Show Desktop" pop-up instead. The tutorial is not for that, but only to turn the Aero Peek feature on or off for the transparent window look." The "Show Desktop" pop-up I managed to disable without any problem (even though I don't mind it so much because it's just one pop-up and it only pops up when the cursor is in the extreme lower-right corner of the screen - which hardly ever happens so it's not such a nuisance).
    It is in fact "turn the Aero Peek feature on or off for the transparent window look." that I am looking for - so I can turn it off. But it is simply not happening. Nothing works. The tutorial doesn't do it either. So every time the cursor goes too low, a host of mini windows pop up which I find very distracting
    IJmir
  4. Posts : 72,054
       #93
    IJmir,
    As a test, create a new administrator account and see if you are able to turn Aero Peek off while logged in it.
  5. Posts : 1
    Aero Peak Solution
    Hello,
    There is one more option you can try to get Aero Peek working. Go to 'Control Panel\All Control Panel Items\Personalization' and select one of the Aero Themes. If you do not have an Aero Theme selected here, Aero Peek won't work no matter what selections you have made elsewhere.
    Check items in the red Warning box at the top of the tutorial.
    Tenne
  6. Posts : 1
    Windows7 Ultimate 32bit
       #95
    My issue solved
    Hi, Thankyou so much for this solution. I have been trying to fix this myself since a long time. I got my issue solved in 5 mins just by following your instructions. My Aero features are working great now. Keep up your good work :)
  7. Posts : 72,054
       #96
    You're most welcome NaughtybyNature, and welcome to Seven Forums. :)
  8. Posts : 2
    another option
    system was set to High Colour. Changed to True Colour (right click desktop --> Screen Resolution --> Advanced Settings --> List All Modes) and voila!; back in business.
  9. Posts : 260
    Windows 7 Ultimate 64bit
       #98
    I've just noticed on my new build of 7600, strangely, that the options (options 4-6) aren't actually there.
    Maybe the auto-fix will magically restore it, maybe it was my over-zealous optimising that has achieved this "state" - will check in a sec ala reboots, first trying to manually ascertain (as I fear regfromapp.exe will fail as usual even when running with a winpatch... again we'll see).
    New build exhibiting the anomaly is mounted on f: sw and sys hives are loaded.
    Quick comparison tells me it's not UxSms, it's not the shake disable setting, NoWindowMinimizingShortcuts I added (AFAIK!)....
    first thing, reboot into backup (before tweaks:)
    I'm a dab hand with diskpart and bcdedit now at least!
  10. Posts : 72,054
       #99
