User Folders - Allow or Prevent Moving Location
    How to Allow or Prevent Users to Move their User Folders to a New Location
    This tutorial will show you how to allow or prevent all or specific users from being able to change the location of their user folders in Vista, Windows 7, and Windows 8.
    EXAMPLE: User Folders
    NOTE: These are located at C:\Users\(user-name).
    EXAMPLE: Moving User Profile Folders Allowed and Prevented
    NOTE: This is an example of moving the Music user folder if set to allow or prevent.
    User Folders - Allow or Prevent Moving Location-allowed.jpgUser Folders - Allow or Prevent Moving Location-prevented.jpg
    OPTION ONE
    Using a REG File Download
    1. To Allow Moving User Profile Folders
    A) Click/tap on the Download button below to download the file below, and go to step 3 below.
    Allow_Moving_User_Folders_Location.reg
    2. To Prevent Moving User Profile Folders
    Prevent_Movning_User_Folders_Location.reg
    3. Save the .reg file to your desktop.
    4. Double click/tap on the downloaded .reg file and click on Merge.
    5. If prompted, click/tap on Run, Yes (UAC-Windows 7/8) OR Continue (UAC-Vista), Yes, and OK.
    6. When finished, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and Desktop. (see screenshot below)
    3. In the right pane, right click on Prohibit User from Manually redirecting Profile Folders, and click/tap on Edit. (see screenshot above)
    4. To Allow Moving User Profile Folders
    A) Select (dot) either Not Configured or Disabled, and go to step 6 below. (see screenshot below step 6)
    5. To Prevent Moving User Profile Folders
    A) Select (dot) Enabled, and go to step 6 below. (see screenshot below step 6)
    6. Click/tap on OK. (see screenshot below)
  1. Posts : 10,200
    Think you meant to say User Configuration in the discussion of manually changing.
  2. Posts : 72,059
    Nice catch Karl. Thank you. It has been corrected. :)
