Internet Explorer Zoom - Enable or Disable
    How to Enable or Disable Zoom Level Option in Internet Explorer
    This will show you how to enable or disable either the current user or all users to be able to use the Internet Explorer Zoom level option to enlarge or reduce the view of a webpage from 10% to 1000% in Vista, Windows 7, and Windows 8.
    In Windows 8/8.1, this will enable or disable the zoom feature in both the desktop and modern IE10 and IE11 versions.
    EXAMPLE: Internet Explorer Zoom Options Enable and Disabled
    OPTION ONE
    Using a REG File Download
    1. To Enable Zoom in Internet Explorer for All Users
    A) Click/tap on the Download button below to download the file below.
    Enable_All_Users_Internet_Explorer_Zoom.reg
    B) Go to step 5.
    2. To Disable Zoom in Internet Explorer for All Users
    Disable_All_Users_Internet_Explorer_Zoom.reg
    3. To Disable Zoom in Internet Explorer for Current User Only
    Disable_Current_User_Internet_Explorer_Zoom.reg
    B) Go to step 5.
    4. To Enable Zoom in Internet Explorer for Current User Only
    NOTE: This will not enable the all users option (step 2) if applied. You will need to use step 1 if you used step 2.
    Undo_Disable_Current_User_Internet_Explorer_Zoom.reg
    5. Save the .reg file to the desktop.
    6. Double click/tap on the downloaded .reg file to merge it.
    7. Click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK when prompted.
    8. For current user only option, close and reopen Internet Explorer, if already opened, to apply.
    9. For all users option, log off and log on, or restart the computer to apply.
    10. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, Windows Components, and Internet Explorer. (see screenshot below)
    3. In the right pane, double click/tap on Turn off page zooming functionality to edit it. (see screenshot above)
    4. To Enable Internet Explorer Zoom for All Users
    A) Select (dot) either Not Configured or Disabled. (see screenshot below step 6)
    B) Go to step 6.
    5. To Disable Internet Explorer Zoom for All Users
    A) Select (dot) Enabled. (see screenshot below step 6)
    6. Click/tap on OK. (see screenshot below)
    8. Close and reopen Internet Explorer if already opened.
  1. JMH
    Win 7 Ultimate 64-bit. SP1.
    Up to your usual high standard Shawn.
    Professional, explicit & easy to follow.
    Well done!
  2. Posts : 72,058
    Thank you Jan. :)
  3. Posts : 1,747
    window's 7
    good info Brink..thanks
