SF Diagnostic Tool - Using for Troubleshooting
Page 23 of 23 FirstFirst ... 13212223
  1. Posts : 72,052
       #220
    Go ahead and create a new thread for whatever the issue is for why you are running these tests to see if we may be able to further help with it. :)
  2. Posts : 2
    windows 7 ultimate 32 bit
       #221
    SD reply
    please check the attached file
    SF Diagnostic Tool - Using for Troubleshooting Attached Files
  3. Posts : 51,480
    Windows 11 Workstation x64
       #222
    You need to follow the instructions and post the files it creates in a new thread in the bsod section.
    Just follow all the instructions here - Blue Screen of Death (BSOD) Posting Instructions
    And DO NOT post them back in this tutorial
      My Computers
  4. Posts : 111
    Windows 10 Pro
       #223
    Once pressing GRAB ALL and it starts running, it stops at each one with an OKAY message box to continue. This message box is stuck behind the main UI. Therefore the only way to proceed is to close that menu, hovering over the sf tool and closing the 2nd instance.
    Really this message should not come up to say it has completed each category, it's useless.
  5. Posts : 4,772
       #224
    Thanks for feedback. I'll look into it.
  6. Posts : 111
    Windows 10 Pro
       #225
    Welcome:)
  7. Posts : 15
    Windows 7 x64 Ultimate
       #226
    Cooee Captain, cool app :)
    b4 clicking 'grad all', I just moved the app to 1 side so I can get to the 'OK' button underneath, easy
    I first ran it from D drive & it made a desktop folder on that drive, I now run it from C drive, easier to find the results folder :)
    cheers
