Libraries Desktop Icon - Add or Remove
Page 1 of 6 123 ... LastLast
    How to Add or Remove the Libraries Desktop Icon in Windows 7
    This will show you how to add or remove the default Libraries desktop icon in Windows 7. This is not like a standard shortcut.
    EXAMPLE: Libraries desktop icon
    Here's How:
    1. To Add the Libraries Desktop Icon
    Add_Libraries_Desktop_Icon.reg
    B) Go to step 3.
    2. To Remove the Libraries Desktop Icon
    Remove_Libraries_Desktop_Icon.reg
    4. Right click on the downloaded .reg file, and click on Merge.
    5. Click on Run, Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
    7. When done, you can delete the downloaded .reg file if you like.
  1. Posts : 4,925
    Windows 7 Professional 64-bit
    Open windows explorer,
    Left click and drag the main Libraries icon onto the desktop
  2. Posts : 72,052
    Hi Swarfega,
    That's a good one for placing a shortcut of Libraries on the desktop instead. :)
    Thank you for sharing this.
  3. Posts : 3
    Windows 7 Ultimate built 6956 32 bits
    (my first message)
    Anyone knows how to change the icon of a created folder in the library?
    thank you in advance.
  4. Posts : 3,141
    Hello randomhell,
    Welcome to the Seven Forums.
    Take a look at this thread. Quick question
    Gary
  5. Posts : 3
    Sorry for that,
    I browsed throught tutorials tho, but didn't find anything.
    I won't do it again..^^
  6. Posts : 3,141
    Not a problem. Now others will be able to find it too.
    Enjoy your stay.
    Gary
  7. Posts : 4
    Windows Vista SP1 -> Windows 7 Ultimate x86 Build 7100
    been trying to delete the library icon from my desktop but can't seem to do so.
    cause when i right click the icon there's no delete option and i also tried using that .reg fiel above. which is weird. can anyone shed some light to why this is?
    heres a screen shot.
  8. Posts : 72,052
    Hello w00t, and welcome to Seven Forums. :)
    After you have downloaded and merged the reg file in step 2, did you right click on a empty space on the desktop and click on Refresh?
  9. Posts : 4
    thanks for the welcome :), and yea i refreshed the desktop and also restarted.
