Power Plan - Restore Default Settings
How to Restore Default Power Plan Settings in Windows 7 and Windows 8
This will show you how to reset and restore all of the default Power Plans back with their default settings, or how to restore a single Power Plan back to default settings in Windows 7 and Windows 8.
EXAMPLE: Default Power Plans
EXAMPLE: Missing Power Plans
NOTE: This is just an example of the power plans missing.
OPTION ONE
To Reset and Restore All Power Plans to Default
NOTE: This can be handy if you have a missing default power plan and would like to restore it, or would like to reset all default power plans back to their default settings. 1. Open a command prompt in Windows 7 or Windows 8.
2. In the command prompt, type powercfg -restoredefaultschemes and press Enter. (See screenshot below) W7_CMD.jpg
3. Close the command prompt.
OPTION TWO
To Restore a Single Power Plan back to Default
NOTE: This will restore a single power plan that you select back to it's default settings. 1. Open the Control Panel (icons view) in Windows 7 or Windows 8, click/tap on the Power Options icon, and go to step 3 below.
2. Click/tap on the Change plan settings link to the right of the power plan that you want to restore the default settings for. (See screenshot below) Step1.jpg
3. Do step 4 or 5 below for what you would like to do.
4. Click/tap on the Restore default settings for this plan link, and go to step 6 below.. (See screenshot below) Advanced_Settings.jpg
5. Click/tap on the Change advanced power settings link, click/tap on the Restore plan defaults button, and go to step 6 below.. (See screenshot below) Step4.jpg
6. Click/tap on Yes to confirm. (See screenshot below)
NOTE: If you did step 5 instead of step 4, then click/tap on OK. (See screenshot below step 5A) Confirm.jpg
7. Close the Edit Plan Settings window. (See screenshot below step 4)
Thanks :) this would be a great help.
Windows 7 Ultimate 32-bit (6.1, Build 7600)Intel(R) Core(TM)2 Duo CPU T6500 @ 2.10GHz (2...4096MB RAMATI Mobility Radeon HD 4500 Series
HP Pavilion dv6 Notebook PC
Intel(R) Core(TM)2 Duo CPU T6500 @ 2.10GHz (2 CPUs), ~2
4096MB RAM
Digital Audio (S/PDIF)
You're most welcome Afrozenminute. :)
You're most welcome Aybe, and welcome to Seven Forums. I'm glad it was able to help. :)
Thank you !
Windows 8 x64
Windows 8 x64
Power settings really bricked - Just Repair-Installed
I ALREADY DID "powercfg -restoredefaultschemes" about 10 dozen times in Elevated Command prompt, it just says, "You do not have the permissions required to perform this action."
And I just repair-installed this stupid OS! What else is there to break next?
Microsoft Windows 7 Home Premium 64-bit Servi...AMD A10-6800K APU with Radeon(tm)™ HD Graphic...(2) G.Skill F3-12800CL10-8GBXLASUS R7 250 Series (0x6610)
AMD A10-6800K APU with Radeon(tm)™ HD Graphics 4100
ASRock FM2A85X Extreme4-M
Acer X213H LCD monitor, 21"
1920 x 1080 x 32 bits @ 60 Hz
WD Black, 1.0TB, WDC WD1002FAEX-00Z3A0
Rosewill Quark-650
Raidmax Comet SECC Steel ATX Mid Tower Computer Case
1 x 80mm + 2 x 120mm + Stock cooler
Gear Head Wireless Optical 5-button mouse
FTTx 6000 / 1000
Avast! Free Antivirus 2015.10.0.2208
Google Chrome Version 40.0.2214.115
*AMD Dual-Graphics
*Uses OpenDNS
*Uses Folding@Home
*HP 16x Super-Multi DVD Writer
*Superspeed 74-in-1 Card Reader
*Maximum overclock has not been determined.
Hey AG,
Odd, does using Option Two to manually reset your power plan work for you?
It didn't work either. In fact the problem started when I tried to create a custom power plan for my tower.
Rosewill Quark-650
FTTx 6000 / 1000
*AMD Dual-Graphics
*Uses OpenDNS
*Uses Folding@Home
If you like, doing a system restore using a restore point dated before this should be able to sort it for you.
I did that once, from the Recovery Console, up to 4 times from 4 different checkpoints, but it keeps getting me a failed (0x8000FFFF) message each time, but then I go back INTO Windows, then it says "System restore has completed successfully". I'm like WHAT?
:what:
Something is still broken with Windows. Maybe I didn't install a driver correctly?
Rosewill Quark-650
FTTx 6000 / 1000
*AMD Dual-Graphics
*Uses OpenDNS
*Uses Folding@Home
Right, I tried to reinstall my motherboard drivers, then AMD Catalyst 13.9, then I disabled Avast Antivirus.
Tried "powercfg -restoredefaultschemes" again -- Now it says, "An unexpected error condition has occurred. Unable to perform operation. You may not have permission to perform this operation."
Issuing "powercfg -L" shows:
Existing Power Schemes (* Active)
Power Scheme GUID: 381b4222-f694-41f0-9685-ff5bb260df2e   *
Rosewill Quark-650
FTTx 6000 / 1000
*AMD Dual-Graphics
*Uses OpenDNS
*Uses Folding@Home
Now it's doing the same thing on my Windows 8.1 laptop, and I think I've got the gist of what's behind all of this.
Stupid avast hardened mode.
There is no command-line to reset all the default schemes FOR powercfg, and I had already made a custom scheme prior to upgrading to avast 2014. However, my laptop's display stayed bright until it was time for it to switch off, meaning it wouldn't dim down after e.g. 5 minutes, like it was set for. In fact, recently I had posted a short note on Facebook about it:
I can't change my power management settings! What's the big idea?
And now it looks like I can't find the Dim display after setting. Imma have to uninstall the stupid AV.
Rosewill Quark-650
FTTx 6000 / 1000
*AMD Dual-Graphics
*Uses OpenDNS
*Uses Folding@Home
That new feature in the new Avast sure has restricted/broken a lot of things.
I must be at the end of my rope. Had to reset my Dell laptop to factory defaults, because running sfc /scannow couldn't fix all of the damage that avast did. For some reason, however, installing Windows 8.1 causes me to lose the Dim display after controls, which is very discouraging, since the screen brightness impacts energy usage on battery power.
It's for that same reason that I have created a new account on Eight Forums.
Rosewill Quark-650
FTTx 6000 / 1000
*AMD Dual-Graphics
*Uses OpenDNS
*Uses Folding@Home
Since it's an OEM PC, you might see if there may be a power management program that came preinstalled with it that may be overriding what you are setting in Windows.
I couldn't fix it. Sorry man. :picnic:
There is a "Dell Extended Battery Life" option that puts my laptop to Power Saver when I unplug it. Unfortunately, that can't be removed from Programs and Features.
Looks like I'll have to leave avast 2014 off the computers for a while. Is it possible to install an old version or will it simply cause problems?
Rosewill Quark-650
FTTx 6000 / 1000
*AMD Dual-Graphics
*Uses OpenDNS
*Uses Folding@Home
Not sure, but it appears that Avast 2014 is breaking quite a bit in Windows 8/8.1.
