Power Plan - Restore Default Settings
How to Restore Default Power Plan Settings in Windows 7 and Windows 8
This will show you how to reset and restore all of the default Power Plans back with their default settings, or how to restore a single Power Plan back to default settings in Windows 7 and Windows 8.
EXAMPLE: Default Power Plans
EXAMPLE: Missing Power Plans
NOTE: This is just an example of the power plans missing.
OPTION ONE
To Reset and Restore All Power Plans to Default
NOTE: This can be handy if you have a missing default power plan and would like to restore it, or would like to reset all default power plans back to their default settings. 1. Open a command prompt in Windows 7 or Windows 8.
2. In the command prompt, type powercfg -restoredefaultschemes and press Enter. (See screenshot below) W7_CMD.jpg
3. Close the command prompt.
OPTION TWO
To Restore a Single Power Plan back to Default
NOTE: This will restore a single power plan that you select back to it's default settings. 1. Open the Control Panel (icons view) in Windows 7 or Windows 8, click/tap on the Power Options icon, and go to step 3 below.
2. Click/tap on the Change plan settings link to the right of the power plan that you want to restore the default settings for. (See screenshot below) Step1.jpg
3. Do step 4 or 5 below for what you would like to do.
4. Click/tap on the Restore default settings for this plan link, and go to step 6 below.. (See screenshot below) Advanced_Settings.jpg
5. Click/tap on the Change advanced power settings link, click/tap on the Restore plan defaults button, and go to step 6 below.. (See screenshot below) Step4.jpg
6. Click/tap on Yes to confirm. (See screenshot below)
NOTE: If you did step 5 instead of step 4, then click/tap on OK. (See screenshot below step 5A) Confirm.jpg
7. Close the Edit Plan Settings window. (See screenshot below step 4)
OK, now I'm ticked. Infuriated, I say! :mad:
I just now got an email back from Avast about this and they said, and I quote:
This issue (Windows can't save some of your changes to this plan's power settings - Access is denied.) is not caused by avast! but by the absence of administration rights while making the changes.
Which means, prior to installing avast, I will have to activate the built-in Administrator account.
Unfortunately, the same thing happened there even in the built-in Administrator account:
I give up! I sent out a support package to the avast! team.
AMD A10-6800K APU with Radeon(tm)™ HD Graphics 4100
ASRock FM2A85X Extreme4-M
(2) G.Skill F3-12800CL10-8GBXL
ASUS R7 250 Series (0x6610)
Acer X213H LCD monitor, 21"
1920 x 1080 x 32 bits @ 60 Hz
WD Black, 1.0TB, WDC WD1002FAEX-00Z3A0
Rosewill Quark-650
Raidmax Comet SECC Steel ATX Mid Tower Computer Case
1 x 80mm + 2 x 120mm + Stock cooler
Gear Head Wireless Optical 5-button mouse
FTTx 6000 / 1000
Avast! Free Antivirus 2015.10.0.2208
Google Chrome Version 40.0.2214.115
*AMD Dual-Graphics
*Uses OpenDNS
*Uses Folding@Home
*HP 16x Super-Multi DVD Writer
*Superspeed 74-in-1 Card Reader
*Maximum overclock has not been determined.
