Theme - How to Apply Custom Themes
Page 1 of 14 12311 ... LastLast
    How to Apply Custom Themes in Windows 7
    This will show you how to apply a custom theme from deviantART as your theme in Windows 7.
    Here's How:
    1. First you will need to click on the Download button below to download and install either the 32-bit (x86) or 64-bit (x64) Universal Theme Patcher (auto installer) below for your 32-bit or 64-bit Windows 7.
    32-bit:
    Download
    64-bit:
    Download
    2. When downloaded, unrar the file using winrar, and run the exe.
    3. Select your user interface language
    4. Click OK
    5. The click yes when this box appear.
    6. The you need to patch these 3 files (As you see i already have mine patched) Click the patch outside each file, after patching them all reboot.
    7. Now you need a custom theme, i will advise you to check these out:
    New Orleans Saints by ~sergiogarcia9 on deviantART
    Aero Evolution 1.0 by ~sergiogarcia9 on deviantART
    Majestic Excellence by ~sergiogarcia9 on deviantART
    Midnight by ~MrGRiM01 on deviantART
    My DA profile: sergiogarcia9 on deviantART
    Mr Grim's DA profile: MrGRiM01 on deviantART
    You can also find more themes on Deviantart, but make sure they work with windows 7.
    They need to be unzipped first.
    8. Now navigate to the Windows folder, find the folder called resources and click on the themes folder. (C:\Windows\Resources\Themes)
    These are the files that has to be placed in the folder:
    9. Then paste the folder and theme provided, then the theme should appear in your personalization menu :)
    NOTE: In most themes there are only 2 files (a folder and a theme file)
    Good luck :)
  1. Posts : 80
    Win 7
  2. Posts : 4,755
    moinmoin said:
    Thanks for these, they look great :)
  3. Posts : 79
    Win7 RTM, XP Pro, Arch Linux, Puppy (Quad boot)
    For those who don't need Aero or are using the basic Windows 7 theme, here's a brilliant collection of 16 themes that will get rid of the boring default color:
    Windows 7 Basic - 16 Colors by ~UntitledGame on deviantART
  4. Posts : 3,028
    Windows 7 Ultimate (x64) SP1
    moinmoin said:
    great link...+rep
  5. Posts : 4,755
    Please people remember this is not a thread to post themes in. This is a tutorial on how to apply them.
  6. Posts : 1,011
    Windows 7 Ultimate x64 (Retail)
    Where do you get or find the 3 files that have to be added to the Themes directory?
  7. Posts : 4,755
    Download a theme and you will see.
  8. Posts : 1,011
    Sorry, I downloaded your red fusion theme and I still don't see.
  9. Posts : 4,755
    In the Red Fusion theme folder there is a folder called Red Fusion theme. Open that folder, and copy the folder and the themepack file to C:\Windows\Resources\Themes
