Priority Level - Set for Applications and Processes
    How to Set CPU Priority Level for Applications and Processes in Windows 7
    Windows shares the processor time between all running processes based upon their priority. If a process has a higher priority, it gets more processor time compared to a process having a lower priority.
    This tutorial will show you how to Set Priority of an application or process in Task Manager to have it run with a Realtime, High, Above Normal, Normal, Below Normal, or Low processor priority level in Windows 7 or Vista.
    The changes you make to the priority level of the current instance of an application or process are only temporary and not set permanently.
    Once you close the application or restart your system, Windows forgets your custom priority and automatically assigns the default priority back to this process or application.
    OPTION ONE
    To Set CPU Priority of Process in Task Manager
    1. Right click on a empty space on the taskbar and click on Task Manager, OR press CTRL+SHIFT+ESC.
    2. If UAC Permission is Required for Application to "Run as administrator"
    A) Click on the Processes tab in Task Manager, then click on the Show processes from all users button. (see screenshot below)
    B) If prompted by UAC, then click on Yes (if administrator) or enter the administrator's password (if standard user).
    C) Continue on to step 3 or 4.
    3. To Set Priority Level for an Application
    A) Click on the Applications tab, then right click on the application that you want to change the priority level of and click on Go to Process. (see screenshot below)
    B) Continue on to step 4B.
    4. To Set Priority Level for a Process
    A) Click on the Processes tab. (see screenshot below)
    TIP: It will make it easier to see what the priority levels of the listed processes are currently set as by adding the Base Priority column here.
    B) Right click on the process that you want to change the priority level of, then select Set Priority and click on the priority level you want to select (dot) it. (see screenshot below)
    5. Click on Change Priority. (see screenshot below)
    6. Repeat for any others you wish to change the priority level of.
    7. When finished, close Task Manager.
    OPTION TWO
    To Run a Program with a Set CPU Priority in Command Prompt
    1. Open a command prompt.
    2. In the command prompt, type the command below, and press Enter. (see screenshot below)
    cmd.exe /c start "Program Name" /priority "Full path of application file"
    For example: I would type this command below exactly if I wanted to run Process Monitor using a high priority, and it's .exe file is located at "E:\Programs\Process Monitor 3.05\Procmon.exe".
    cmd.exe /c start "Process Monitor" /High "E:\Programs\Process Monitor 3.05\Procmon.exe"
    Substitute Program Name in the command with the actual program's name within quotes.
    Substitute Full path of application file in the command with the full path of the file within quotes.
    Substitute priority in the command with the CPU priority level below you want the application file to run as.
    • Realtime
    • High
    • AboveNormal
    • Normal
    • BelowNormal
    • Low
  1. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Excellent, Brink; very well done. Thanks.
  2. Posts : 72,058
    Thank you Carl. :)
  3. Posts : 4,049
    Fantastic Brink!
    This is useful though not as spectacular as your Registry downloads
  4. Posts : 4
    Win7 Ultimate x86
    this tip might not look important but REMEMBER cpu is the most powerful fastest component in your entire system, cpu have the speeds of L1-112,849mb/s , L2 and L3 are bit slower, BUT your ram have the speed of only 8,000mb/s for ddr3 10600, and pitiful moment is hdd has only 130mb/s at most for 7200rpm.
    so if you increase priority you'll more performance
  5. Posts : 249
    Hello Shawn. You may consider adding the comment that the priority level change only lasts as long as application is open. Once the running application is closed & re-opened, the priority level reverts to its original setting.
    At least this is what I've noticed from my experience trying your tutorial. Let me know if your priority changes remain after the app is closed & re-opened.
  6. Posts : 4,161
    Windows 7 Pro-x64
    TBoyd said:
    I changed the priority from Normal to High for lightroom.exe, but once I close & reopen lightroom.exe, the priority level reverts to Normal. I guess this doesn't work on all programs.
    I found that the program (lightroom) will run at a High priority level as long as it is open, but reverts to Normal after closing.
    I believe that's the way it's supposed to work. You're setting it through active processes and programs. If it's not active, it reverts to normal. Setting Affinity works the same way.
  7. Posts : 249
    You're right, carwiz. I totally overlooked the note at the beginning of the tutorial:
    "The changes you make to the priority level of the current instance of an application or process are only temporary and not set permanently.
    Once you close the application or restart your system, Windows forgets your custom priority and automatically assigns the default priority back to this process or application."
    What can I say, but "DUH". I'm embarrassed.
  8. Posts : 72,058
    No worries Tom. If we all don't do this at least once a week, then we're just not human. :)
  9. Posts : 881
    that's why we never see your mess ups.
