Microsoft security bulletin for October 8 2013
Ranger a new install will grab all updates including unneeded ones. Even more if the installer is not SP1.
Just got my 21 updates at 9:26Pm ET, installed no issues. I did 6, 8, then 7. IT irks me the Microsoft still thinks I need the Bing Desktop which I've hidden several times. :mad:
Thanks Britton. You are spot on as my installer was prior to SP1, which explains all my old updates.
I agree with you on the Bing Desktop, an item I absolutely do not want.
1920 x 1080 HD
Corsair VS450
Codeng
PSU fan & CPU fan
I have just completed all of my 24 updates without any problems.
I always do net framework updates first and always reboot. Then I do 3 or 4 updates at a time depending on the size and reboot whether it request a reboot or not.
The last ones I do are Office updates.then reboot and check for Updates again to make sure I got them all.
I just use the new KB Update Clean Up tool and removed 4.41 GB.
Rebooted again and checked for Windows Updates again and none were there. Things are still working as they should.
Just had 29 updates to do. Rebooted and system paused for about 10 minutes at 32% before restarting. Got to 32% second time round, long long pause, then finally the familiar Windows chime. Shuts down before logon screen appears. Boots up third time, long long pause while it "configures my system", Windows chime.....long pause....login appears, keyboard works, enter password, bingo!
Why do these Tuesdays have to be so fraught? It's "cross your fingers and hope I don't have to reinstall the image I made of my system last month" time whenever the updates ready notification pops up.
Win 7 Pro 64 bit
Win 7 Pro 64 bit
Layback, i do them the same way as you, i find if you allow them to all go on at the same time that is when you run into problems, i have done all my windows eight ones but , today i start windows 7. I have my 5 to do and i maintain 40 client computers remotely so i wait to see how mine do and those in here that comment, the only thing i do differently, i do the net framework last, and do the 3.5 first, then the 4 then the 4.5
Windows 7 Pro 32/64 bit and Windows 10 Pro 32...4gigsAMD Radeon HD and Nvidia
Dell Computers
Windows 7 Pro 32/64 bit and Windows 10 Pro 32 Bit/64bit
4gigs
Samsung 24". INC 19". Dell 22 ". Dell 17" & 19"
I only reboot once and was like 20 updates for me. Computer is working fine also on my end.
Windows 10 64bitAMD Phenom II X4 925 (Deneb)(2.8GHz) OC 3.4GHzCorsair Vengeance DDR3 4GBX2 (8192MB)XFX HD 6870 1GB (OC)- 940MHz core, mem 1150MHz
custom build
Windows 10 64bit
M5A78L-MLX Plus
Vizio 26' 1920x1080 / Acer 1336x768
1920x1080 60Hz /1336x768
Kingston Digital 60GB SSDNow V300/500gb HDD Western Digital 7200rpm (/WD 160GB HDD 7200rpm
CORSAIR CX600 600w
AZZA Orion 202 EVO
cooler master hyper TX3 cpu cooler
Razer DeathStalker
Logitech Optical Gaming Mouse G400
Defualt on win 10
cpu is overclocked in bios
It is a newer version being offered each time,
I had 29 updates and 28 were selected by default, I just blasted through those and then did the remaining MSE Platform update.
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
All 26 on this machine and 29 on another went without a hitch for me ( in 3/4 batches, as usual) - and on interesting result was that in a XP machine, I actually managed to get some .NET updates installed that had been misbehaving for years! Unfortunately this simply moved the problem along the chain a bit and I still have a couple with problems.
The problem is confusing, to say the least.
KB 982168 installs OK - reboot and check for more updates, and it request KB951847. That installs OK, so reboot and check again - and it now wants KB 982168 again!
I've hidden both until I have time to play - it's an office fileshare server so I can't keep it offline too long.
Win 7 x64 Home Premium (and x86 VirtualBox VM...i3 370M/i7 6500U8GB - finally :)/8GBit's an i3, dude!/dual Intel&nVidia
Asus K52F or Lenovo B51-80
Win 7 x64 Home Premium (and x86 VirtualBox VM)/Win10
i3 370M/i7 6500U
Asus/Lenovo
onboard
15.6" built-in
1366x768/1920x1080
750GB Seagate internal
Sundry external drives attached to other computers on the local network
1TB SSD on the Lenovo
n/a
as much as I can get - usually on a dongle/phone, so <1MB/s
MSE/Defender
IE11/12/Edge/Chrome/FF(if I must)
I don't give the north end of a southbound furry little rodent if it is a new, improved version of Bing Desktop. If I've previously hidden it and have never installed it, that should tell M$ I don't want the misbegotten thing! And, in the past, it did; M$ has been acting desperate lately with the way it has been trying to RAM programs, etc. down our throats.
Win 7 Ultimate 64 bit
Intel i7-3930K
ASUS P9X79 WS
Asus Xonar Essence STX
1920 x 1080, ?
Samsung 4TB 850 EVO SSDs (4)
Corsair HX750w
Logitech G510s
Logitech M525 (two in use)
=< 32Mbps down, 8Mbps up
IE11
I just did the cleanup tool on my windows 7 sp1 desktop to see what would happen
It showed I had 6gigs of windows update cleanups.
It did the cleanup then went away (it does not even tell you to reboot)
but I rebooted anyway
now it stated- Windows is installing New updates
That took about 15 min
then it came up and said Windows is cleaning computer
it sat there for about 30minutes then finally went into windows 7
Is this suppose to happen?
robin
Dell Computers
4gigs
Did I get 4 for Kernel-Mode Drivers 'cause I still have some Kernel updates hidden from Aug & Sept or did everyone?
Edit: And I see they brought back another hidden one, KB2834140 as Recommended but what I get out of all the reading I've done, is that it has something to do with IE 10 & KB2670838 which is Optional. Very confusing to a dummy. Oh, I have IE 9.
Microsoft Windows 7 Home Premium 64-bit 7601 ...AMD Athlon(tm) II X2 220 Processor3.00 GBNVIDIA GeForce 6150SE nForce 430
emachines
eMachines EL1358G
3.00 GB
1280 x 1024 x 32 bits (4294967296 colors) @ 60 Hz
(1) WDC WD10 EADX-22TDHB0 SCSI Disk Device (2) Generic- Multi-Card USB Device
came with PC
came with PC
IE 9
don't know how to get info for the other 5 areas
Would you believe that this is my 5th day of almost solid 6-8 hours trying to figure out what to go ahead with & what to keep hidden from the last 2 or more months updates. :o
Edit: And now my total for Oct. is 22!!
emachines
eMachines EL1358G
3.00 GB
came with PC
came with PC
IE 9
I did not do the ones for ie 10 and 11 because i am sticking with ie 9
I did all the kernal ones one one computer and prayed. It took a bit to install but it did. I am not sure if i am going to put them on my business computer yet, are 4 of them and i cannot understand why you need 4 kernal drive updates when it says it is for the exact same thing, anyone wanna explain why?
Dell Computers
4gigs
How we all look forward to this time of the month!
I installed about 20 updates on my gaming machine this morning, leaving just the MSE update to do separately when I'm satisfied that everything else is ok. So far so good. The updates included KB2862330 and I only had the usual single reboot, installing the lot in one go inside about 10 minutes.
This afternoon I applied the same updates to my work machine, but minus KB2862330 as this one was now unchecked by MS, presumably because it is causing double reboots on some machines and that can play havoc with the rest of the updates. I'll leave that one at least for now. I then separately installed the six Office updates, but have again left the MSE update for later.
On the work machine I've also left the Silverlight update for now as I didn't want to compromise the other updates, and I'm none too clear whether I need it. Does anyone have any strong views on that one, for or against?
Windows 7 Home Premium 64AMD Phenom II X4 9558GB Corsair XMS3 DDR3Gigabyte Geforce GTX 960 2GB
Custom build by PC Specialist
Asus M4A78T-E
SB Audigy
BenQ 24"
500GB Serial ATA
1010W Quiet Quad Rail
Antec 900
Fenrir
Corsair
20mbps
MSE plus MBAM 2.x Free
Second desktop different spec but similar level.
Silverlight is basically the MS version of Java. Thus far I've only encountered a few MS site which say I need it to view the page properly. I leave it both uninstalled.
Windows 7 Ultimate X64 SP1
ASUS P8Z68-V PRO/GEN3
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Norton Internet Security 2013
I've had Silverlight installed on previous machines and never had a problem with it. I don't have it installed on wither of machines now because, until recently, I never needed it. The one time I went to a web site that needed it, I blew off the site.
Intel i7-3930K
ASUS P9X79 WS
1920 x 1080, ?
Corsair HX750w
Logitech G510s
IE11
I just spent the last hour fixing my windows 7 64 bit after installing these updates it went like this 1 could not boot into the drive 2 could not repair start up with recovery after several attempts 3 disconnected all external devices apart from mouse and keyboard still could not repair it. so after about 10 times of turning off/on pc it booted up and took 30 mins to get to the desktop can't believe it.
That's why Patch Tuesday scares the h*** out of me. I don't know diddlysquat about what to do if I were to have a problem like that. That's why I'm such a PIA at this forum.
You think it's bad for Windows? Linux users usually get updates DAILY and they have a tendency to break things OFTEN lol. Talk about being paranoid :cry:
Windows 7 Ultimate x64FX 8350 @ 4.8ghz, turbo clocked to 5.4ghzMushkin Enhanced Blackline 16GB 1760mhz 10-10...Gigabyte-660 Windforce OC- GPU Clock 1212MHz ...
Asus Sabertooth FX990 Gen 3.0 R2.0
Mushkin Enhanced Blackline 16GB 1760mhz 10-10-9-24 T1
Gigabyte-660 Windforce OC- GPU Clock 1212MHz /3504MHz ram
Creative Sound Blaster Recon3D PCIe Sound Card
Samsung SyncMaster S27B350H (HDMI)
1920x1080 60HZ
1 x SSD Crucial M4 256GB (Primary OS)
3 x HDD WD 1TB
4 x HDD 2TB
1 x HDD 160GB (Secondary Backup OS)
Raid SATA III 6GB/s 4-port PCI-e Controller Card, Marvel 88SE9215 chipset
Chieftec-650-14CS (Modular) 80 Plus Gold-650 Watt
Akasa Venom Toxic Gaming Big tower ( Custom Black ) Ver 2.0
Water 2.0 PRO / GEIL Cyclone VRM / 6x120mm 2x220mm 2x140mm
Logitech G19
Wireless Notebook Presenter Mouse 8000
Fiber GBS
Don't Announce it to the world :)
Gotta have at least 1!
So, I gather that most people have installed all Oct. updates with no problems? It's been a week today & I'm still holding. As I said in earlier post, "wouldn't know what to do".
Was doing reading elsewhere & sounds like lots of problems with all or most of the Kernel & USB Drivers, that's why I always come back to this forum, my favorite.
emachines
eMachines EL1358G
3.00 GB
came with PC
came with PC
IE 9
I've installed all of them on 3 machines, the first two I did 6-7 at a time, rebooting before the next round. the last one I did all of them, 17 in this case, with no issues.
I had to hide the Silverlight installation every time, MS must really believe we need it. :huh:
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
I still haven't installed KB2862330 on my second machine. I installed it ok on my first one, but by the time I did my second machine updates a couple of days later it had been unchecked by MS so I left it. It's still unchecked so I'll probably hide it as it looks like it's caused a few problems. Everything else went ok, including the Office updates on my second machine.
I think I was only prompted to install the Silverlight update on one of the machines, and hid it.
Asus M4A78T-E
SB Audigy
BenQ 24"
500GB Serial ATA
Antec 900
Fenrir
Corsair
20mbps
I had no trouble with KB2862330 on both of my machines. Anything M$ leaves unchecked I leave until everything else has been installed, then install the unchecked ones.
You shouldn't receive Silverlight updates unless you have it installed (I don't—haven't needed it—and I don't get the updates). If you have Silverlight installed (and you probably do if you are receiving the updates), you should also install the updates to avoid potential security problems.
Intel i7-3930K
ASUS P9X79 WS
1920 x 1080, ?
Corsair HX750w
Logitech G510s
IE11
