USB Intermittent Drop Out - Not Power Related
Page 1 of 3 123 LastLast
  1. Posts : 9
    Windows 7 64 bit
    Hi all,
    I found this forum looking for an answer to my USBs randomly cutting out, so I apologise my first post is a cry for help.
    I have a Samsung np530u3c-a01uk series 5 laptop running windows 7 64 bit.
    The problem I'm having is with the USB ports. I have 2 USB 2.0 ports and one USB 3.0 port. I have noticed that when turning on the laptop it can take up to a minute for a usb mouse to be recognised, and once recognised it will randomly lose connection and regain connection. More annoying for my self is that I also dj from my laptop, and I use a Behringer MM-1 which has in it a powered USB hub. After half an hour or so's use this also stops working. What is bizarre though is that all the lights on the dj controller still light up AND the sound card that is plugged into the 4 port hub on the back of the controller continues to provide sound to my amp, BUT the controller no longer gives any signals/commands to the computer until I unplug it, close my dj software, and plug the controller back in.
    I have read that a lot of USB issues are around power, but clearly using only one usb mouse, or a controller with a hub and it's own power supply should cause any drain on the usb ports. I have also gone into device manager and unticked the power saving option under "usb generic hub" AND under the power options in control panel, I have disabled the USB power management options. Neither of these workarounds has helped.
    I am currently using the USB 3.0 port and for 5 minutes at least, there has been no cut out with the mouse (unfortunately I haven't got the USB hub/dj controller here to test).
    So.... Am I left with two duff USB ports? If I uninstall "generic USB hub" from device manager, will it just reinstall without issue? Is it worth doing? Any other ideas?
    Any help would be great. Many thanks for reading.
  2. Posts : 21,004
    Hello an welcome floateruk mate I would be running these first
    https://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
    https://www.sevenforums.com/tutorials/433-disk-check.html
    Then maybe update the drivers just for elimination purposes the chipset and the USB 3.0 ones
    SAMSUNG
    If here is no change to the machine after run these as well
    http://www.superantispyware.com/
    http://www.malwarebytes.org/products/malwarebytes_free/
    http://www.bleepingcomputer.com/download/adwcleaner/
    download from bleeping computer – delete any rubbishthese find.
  3. Posts : 9
    Windows 7 64 bit
    Thanks for coming back so quickly! I'm just at work but when I get back I'll give it a shot.
    I also found this post on here when I was mooching last night: USB Driver - General Fix for Problems
    I might try that out too.
    Again, thanks for coming back to me, and I'll post what I find later tonight.
    EDIT: I have already updates the chipset and USB 3 drivers. Can't see an upgrade to the Generic USB hub drivers though.
  4. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    You can try uninstalling Generic USB hub and deleting Drivers too. Upon reboot manually dun Windows Update and you should get them back.
    Running through the steps in the tutorial you found fixes many USB problems.
    It could also be a power issue, if the port you have the self-powered hub plugged into loses its power the hub won't work.
  5. Posts : 9
    Windows 7 64 bit
    I've run chkdsk and scannow and no issues.
    I'm going to try the USB tutorial next and see if that clears it. If not could it really be a power issue? I guess on a laptop there's no cure but a new laptop??? That would suck.
  6. Posts : 21,004
    No mate just test the adaptor for volts even and also check out the battery. You could even try it with the battery out and on the adaptor alone.
    did you run those malware scans and if not try them and thee is this Free Anti-Malware Download | Emsisoft Anti-Malware, Online Armor Firewall, Mamutu Behavior Blocker try the first and second scanners.
    Plus it might be worth running this Download Kaspersky Rescue Disk 10 make a bootable disk and run it from power on. It doesn't take long and at least we can eliminate these things.
  7. Posts : 9
    Windows 7 64 bit
    Done without issue and didn't fix problem
    Disk Check
    SUPERAntiSpyware | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware!
    I have AVG running and it hasn't picked anything up....
    Malwarebytes | Free Anti-Malware Detection & Removal Software
    Malwarebytes Anti-Malware
    Malwarebytes | Free Anti-Malware & Internet Security Software
    Scan Date: 14/05/2014
    Scan Time: 20:04:48
    Logfile:
    Administrator: Yes
    Version: 2.00.1.1004
    Malware Database: v2014.05.14.08
    Rootkit Database: v2014.03.27.01
    License: Free
    Malware Protection: Disabled
    Malicious Website Protection: Disabled
    Chameleon: Disabled
    OS: Windows 7 Service Pack 1
    CPU: x64
    File System: NTFS
    User: Floateruk
    Scan Type: Threat Scan
    Result: Completed
    Objects Scanned: 274229
    Time Elapsed: 11 min, 14 sec
    Memory: Enabled
    Startup: Enabled
    Filesystem: Enabled
    Archives: Enabled
    Rootkits: Disabled
    Shuriken: Enabled
    PUP: Enabled
    PUM: Enabled
    Processes: 0
    (No malicious items detected)
    Modules: 0
    Registry Keys: 8
    PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\CLSID\{4e1dfdc4-5474-47fc-bcaa-6f1f0c49bae2}, , [321edc7590ebb383adad7aaacc368779],
    PUP.Optional.PassShow.A, HKLM\SOFTWARE\CLASSES\TYPELIB\{ade2113b-9952-46c8-85b0-b115be39a9fa}, , [321edc7590ebb383adad7aaacc368779],
    PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\INTERFACE\{77bf05d1-5f5f-40d2-8feb-7e326c73a257}, , [321edc7590ebb383adad7aaacc368779],
    PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\CLASSES\TYPELIB\{ade2113b-9952-46c8-85b0-b115be39a9fa}, , [321edc7590ebb383adad7aaacc368779],
    PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\MICROSOFT\WINDOWS\CURRENTVERSION\EXPLORER\BROWSER HELPER OBJECTS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
    PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\SETTINGS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
    PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\EXT\STATS\{4E1DFDC4-5474-47FC-BCAA-6F1F0C49BAE2}, , [321edc7590ebb383adad7aaacc368779],
    PUP.Optional.PassShow.A, HKLM\SOFTWARE\WOW6432NODE\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\c20771cf-b330-43f0-bd27-e728ae7fe413, , [242ca3aef982aa8ce817027aaa587987],
    Registry Values: 1
    PUP.Optional.PassShow.A, HKU\S-1-5-21-1365210169-2043555165-912279061-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\SOFTWARE\MOZILLA\FIREFOX\EXTENSIONS|{591f9d2f-ffb2-4bbe-98fc-2fb86649c789}, C:\Program Files (x86)\PassShow-soft\157.xpi, , [8bc55ef36714db5b38d8bdc6877ba858]
    Registry Data: 0
    Folders: 1
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft, , [242ca3aef982aa8ce817027aaa587987],
    Files: 9
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.dll, , [321edc7590ebb383adad7aaacc368779],
    PUP.Optional.PassShow.A, C:\Windows\Tasks\PassShow Update.job, , [b29e7dd49ae1d95da29eecad986a36ca],
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.dat, , [242ca3aef982aa8ce817027aaa587987],
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\157.xpi, , [242ca3aef982aa8ce817027aaa587987],
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\a.db, , [242ca3aef982aa8ce817027aaa587987],
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\b.db, , [242ca3aef982aa8ce817027aaa587987],
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\PsUP.exe, , [242ca3aef982aa8ce817027aaa587987],
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\Sqlite3.dll, , [242ca3aef982aa8ce817027aaa587987],
    PUP.Optional.PassShow.A, C:\Program Files (x86)\PassShow-soft\Uninstall.exe, , [242ca3aef982aa8ce817027aaa587987],
    Physical Sectors: 0
    (end)
    AdwCleaner Download
    # AdwCleaner v3.208 - Report created 14/05/2014 at 20:15:15
    # Updated 11/05/2014 by Xplode
    # Operating System : Windows 7 Home Premium Service Pack 1 (64 bits)
    # Username : Floateruk - FLOATERUK-PC
    # Running from : C:\Users\Floateruk\Downloads\AdwCleaner (1).exe
    # Option : Scan
    ***** [ Services ] *****
    ***** [ Files / Folders ] *****
    ***** [ Shortcuts ] *****
    ***** [ Registry ] *****
    Key Found : HKCU\Software\APN PIP
    Key Found : HKCU\Software\AVG Nation toolbar
    Key Found : [x64] HKCU\Software\APN PIP
    Key Found : [x64] HKCU\Software\AVG Nation toolbar
    Key Found : HKLM\Software\AVG Nation toolbar
    Key Found : HKLM\Software\AVG Secure Search
    Key Found : HKLM\Software\AVG Security Toolbar
    Key Found : HKLM\SOFTWARE\Microsoft\Tracing\au__rasapi32
    Key Found : HKLM\SOFTWARE\Microsoft\Tracing\au__rasmancs
    Key Found : HKLM\SOFTWARE\Microsoft\Tracing\BingBar_RASMANCS
    Key Found : HKLM\Software\PIP
    ***** [ Browsers ] *****
    -\\ Internet Explorer v11.0.9600.17041
    -\\ Google Chrome v34.0.1847.131
    [ File : C:\Users\Floateruk\AppData\Local\Google\Chrome\User Data\Default\preferences ]
    Found [Extension] : booedmolknjekdopkepjjeckmjkdpfgl
    Found [Extension] : flpcjncodpafbgdpnkljologafpionhb
    AdwCleaner[R0].txt - [1415 octets] - [14/05/2014 20:07:56]
    AdwCleaner[R1].txt - [1327 octets] - [14/05/2014 20:15:15]
    ########## EOF - C:\AdwCleaner\AdwCleaner[R1].txt - [1387 octets] ##########
    Followed this and only deleted the greyed out icons as it suggests. Plugged back in USB devices but problem persists.
    Dammit. Is it actually the power on the mobo?
  8. Posts : 9
    Windows 7 64 bit
    Thanks for your help by the way. I've been all over the coutry this week, so tonight is the first chance I've had to get back sit and down and try stuff out.
  9. Posts : 21,004
    No probs.
  10. Posts : 9
    Windows 7 64 bit
    So do you think there's anything left to try? Or is it good night USB?
    Cheers
