Web cam problem :(
  1. Posts : 15
    osholt said:
    It doesn't appeared to have worked, I just get 404 error message stating the page doesn't exist.
    If you are having trouble entering your system Specs in User CP then a screenshot will suffice.
    You can do this by opening the start menu and searching Snipping tool (or in Lithuanian: snipping rīks, according to Google Translate) and hitting enter.
    Take a screenshot of the Speccy overview Window please so that all the information is visible.
    Oli
    Added a pic.
  2. Posts : 1,241
    Windows 7 Profesional x86, Mac OS X 10.6 Snow Leopard
       #12
    Oli
    Added a pic.
    It didn't work, I get another 404 page not found error.
    Perhaps if you upload it to something like your Windows live Skydrive or Flickr and put [IMG]<IMAGE URL HERE>[/IMG) around it it will work.
    Oli
  3. Posts : 93
    Windows 7 64-bit
    take a print screen, and save it, then go to TinyPic - Free Image Hosting, Photo Sharing & Video Hosting and upload the image
    make sure you choose the one which is saying [IMG*]linkgoesher[/IMG*] *is not shown there.
  4. Posts : 15
       #14
    Oli
    Added a pic.
    Oli
    aaa Pictures, aaa Images, aaa Photos, aaa Videos - Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting <-- IT SHOULD BE HERE!
  5. Posts : 1,241
       #15
    aleksito said:
    osholt said:
    aleksito said:
    Added a pic.
    Oli
    That effort was fruitless.
    It appears either your manufacturer doesn't have a website (in English at least) or that I've missed something gapingly obvious, luckily I don't think it's the latter again this time .
    If you still have the driver disk that came with your PC use that.
    Oli
  6. Posts : 15
       #16
    osholt said:
    Oli
    Oli
    I used the CD. but one problem. In that CD i have all drivers, but thay are for windows vista. But now i have windows 7. and that drivers wont work for me.
    Maybe try this ->
    http://i46.tinypic.com/2rrkoqh.jpg
  7. Posts : 1,241
       #17
    Oli
    Maybe try this ->
    This is a common misconception.
    In lota cases, especially in terms of peripheral devices like that webcam, it should be absolutely fine.
    If for some reason it isn't though try running it in Compatibility Mode
    Oli
  8. Posts : 15
       #18
    Oli
    Maybe try this ->
    Oli
    I found that my webcam driver is Sonix. driver date 4/17/2007. I will try to update it :)
  9. Posts : 15
       #19
    aleksito said:
    osholt said:
    Maybe try this ->
    Oli
    doh, its not working It says that its already updated. But when i turn on web cam it just shows black screen
  10. Posts : 1,241
       #20
    Oli
    The update button you are using inside device manager in the webcams properties just looks on Windows Update... as said before not terribly helpful.
    You need to find the most up to date Sonix driver for your webcam model off the internet.
    Oli
