No audio output device installed
  1. Posts : 20
    Win7 Pro 32bit
    I already installed the wired networking, I think the tool has a wrong version-number...
  2.   My Computer
  3. Posts : 20
    Win7 Pro 32bit
    First link: OS not supported
    Second link: not supported
  4. Posts : 1,996
    Windows 7 Home Premium 64 bit
       #14
    The latest driver can be found here.
    It was posted on 04-08-2011
    http://downloadcenter.intel.com/Deta...adType=Drivers
  5. Posts : 20
    Win7 Pro 32bit
       #15
    done, still no changes
  6. Posts : 1,996
       #16
    Intel has no Windows 7 support for the board, which is a big part of the problem.
    http://downloadcenter.intel.com/Deta...&DownloadType=
    However the sound and video options should be there.
    I don't have a fix, but I'll post something if I come up with it.
  7.   My Computer
  8. Posts : 20
    Win7 Pro 32bit
       #18
    first one: installed
    second one: hardware not supported
    in device manager: only pci serial port with (!), still no audio menu
  9. Posts : 20
    Win7 Pro 32bit
       #19
    Nobody?
    I found this in the manual:
    Desktop Board DQ965GF has a flexible 6-channel (5.1) onboard audio subsystem that
    includes a SigmaTel STAC9227 audio codec and an HD Audio Link header.
    The audio subsystem features:
    • Intel® High Definition Audio interface
    • Advanced jack sense, for the back panel connectors, that enables the audio codec
    to recognize the device that is connected to an audio port and retask the connector
    via the audio driver.
    • S/N (signal-to-noise) ratio: 95 dB
    • Microphone input supporting:
    ― Stereo microphone
    ― Microphone boost
    The subsystem includes the following connectors:
    • Front panel audio connector, including functionality for:
    ― Line out
    ― Microphone in
    • Back panel audio connectors that are configurable through the audio device
    drivers:
    ― Line in/retasking jack
    ― Line out/retasking jack
    ― Mic in/retasking jack
    Related Links:
    Go to the following link or pages for more information about:
    • Audio drivers and utilities Support for Desktop Boards
    • Installing the front panel audio solution, page 45
    • The location of audio connectors, Figure 23 on page 48
    The intel support page doesn't give me a solution...
    edit: in the device manager: no (!) anymore but also no audio tab...
  10. Posts : 1,996
       #20
    In the BIOS, disable on board audio and High Definition Audio....save, reboot.
    After Windows loads everything, reboot into the BIOS and enable onboard audio and High Definition Audio......
    save, reboot. Hopefully Windows will reload your devices.
