Realtek HD Audio Manager not in Control Panel
Page 1 of 5 123 ... LastLast
  1. Posts : 30
    Hi everyone,
    I've just installed the latest Realtek driver and the installation goes fine but Realtek HD Audio Manager won't appear in the Control Panel or the System Tray (however, when I go to customize the notification icons, Realtek HD Audio Manager appears as "Show icon and notifications").
    I've tried reinstalling time and time again. Also, Device Manager shows 4 instances of "High Definition Audio Device" as well as Realtek High Definition Audio. I've tried uninstalling these and installing Realtek but Windows automatically installs them upon restart.
    Anyone got any ideas?
  2. Posts : 2,393
    Microsoft Windows 7 Ultimate: x64 (SP1)
    Hello MultiCat & Welcome to SevenForums!
    Try following this fix (I've smashed up a #permalink for you):
    Solved Realtek hd audio not showing up in control panel - Vista Forums
    Best Regards,
    FredeGail
  3. Posts : 30
    Best Regards,
    FredeGail
    Thanks FredeGail. However, the problem is Realtek HD Audio Manager isn't showing in the System Tray or in the Control Panel.
  4. Posts : 2,393
    Best Regards,
    FredeGail
    Have you been downloading the driver only, or the utility included?
    Link for download: Latest Realtek HD Audio Driver Version
    Best Regards,
    FredeGail
  5. Posts : 30
    Best Regards,
    FredeGail
    Best Regards,
    FredeGail
    I've been downloading the latest drivers (which include the Audio Manager) from the Realtek website.
    Realtek
  6. Posts : 2,393
    You may have another soundcard driver installed.
    Look for it in Device Manager. My suggest is to uninstall the Realtek driver in Control Panel all normal, and then download Driver Sweeper, and clean the leftover files following your soundcard.
    Best Regards,
    FredeGail
  7. Posts : 30
    Best Regards,
    FredeGail
    I'm trying that now.
    Just something I noticed when I was using Task Manager is that RAVCpl64.exe (Realtek HD Audio Manager) is a running process. Strikes me as a little odd...
  8. Posts : 2,393
    Your RAVCpl64.exe should remove when uninstalling your driver. That's my guess.
    And it'll probably be back when installing the driver back on
    Best Regards,
    FredeGail
  9. Posts : 30
    Best Regards,
    FredeGail
    Just tried using Driver Sweeper to remove the stray files and then install the drivers again and I'm still getting the same problem.
  10. Arc
    You may use Revo Uninstaller Freeware in advanced mode to delete all the leftover files during uninstallation .
    After that you may try installing realtek again !
