Stuttering Sound
  1. Posts : 4
    Windows 7 Pro
    Stuttering Sound
    New user to windows 7! Everythign runs and works great minus the sound!!! It stutters and echoes very badly every so often. And being an avid player of Conan i use Vent. Vent does not even work. Any help provided is greatly appreciated!
  2. Posts : 4,925
    Windows 7 Professional 64-bit
    Have you been to the Dell website and downloaded the latest drivers?
  3. Posts : 4
    Windows 7 Pro
    Yes i went there and the "latest" drivers were from 2006. Hopefully I was just being dumb and not looking int he correct place but I tried to no avail.
  4. Posts : 551
    XP Pro/Vista Ultimate (64)/Windows 7 Ultimate Signature Edition(64)
    Sorry, I'm a little confused... by "minus the sound", do you mean:
    a) you get no sound whatsoever, only stutters and echoes every so often
    b) the sound works, but stutters and echoes every so often, in every program that uses audio
    c) the sound works, but stutters and echoes every so often, while using games w/vent.
    d) other (please explain!)
  5. Posts : 8,135
    What model Dell is it? I can check the downloads, but if it'a a 2006 dated driver then it's not for Win 7 and probably not for Vista either and you need Vista drivers, at a minimum.
    Stuttering on Dell's is generally the wrong drivers. On older XP systems (PC's that came with XP) if users used non-Dell drivers that would happen.
    Some drivers come with a "Sonnd Enhancement" panel that you can set echo, reverb, chorus, etc. If you have that and have any of those enabled that can cause what you are hearing.
    Finally, many users on the Dell forum with older PC's that do not have Dell support (at least for Vista) have resorted to installing a separate PCI sound card (on Desktop systems) to remedy sound issues.
  6. Posts : 4
    Windows 7 Pro
    I have a Dell XPS/Dimension 410/9200. The echo is defintately stemmign from a legit problem. It is a very bad stutter. and as said before my Ventrillo doesnt even work
  7. Posts : 71
    Win7
    After installing the best driver, if it still doesn't work well, check to make sure there is no cpu throttling in the bios or in an app that starts with Windows.
    You can see any throttling going on using CPU-Z in Windows.
    On ASUS, the throttling is called Cool N Quiet. On others, it's named differently.
  8. Posts : 4
    Windows 7 Pro
    I have tried all the dell provided drivers for vista audio. none would install... a messgae stating i was not using the correct OS would always pop up.
  9. Posts : 71
    Win7
    Use the device manager.
    Right click the audio. Update driver software. Browse my computer. Let me pick. Have disk. Browse. Find the extracted .inf. Double click it. Hit ok. Hit next. Reboot if necessary after it installs, but shouldn't be.
