Stereo Mix problem-can't seem to record any sound?
  1. Posts : 19
    Windows 7 HP
    So im using windows 7 and i seem to have a problem recording sound directly from my computer
    1-i showed disabled devices
    2-Stereo mix is set as default
    there is:
    MICROPHONE-i tap my microphone and there is the GREEN bars bouncing up and down
    LINE IN-N/A
    STEREO MIX-i played some music and the green bars are NOT bouncing up and down...
    how do i fix this?
    Attached Thumbnails Attached Thumbnails Stereo Mix problem-can't seem to record any sound?-untitled.jpg
  2. Posts : 354
    Windows 8, Ubuntu 12.04 64bit, Pear Linux Triple Boot
    What program are you using to record? You will need to set it up to recognize what your inputs and outputs are.
    Geeve
  3. Posts : 908
    Windows 7 Home Premium
    there is:
    LINE IN-N/A
    how do i fix this?
    You have the RECORDING tab pulled up. Even though it may seem Logical it's wrong.
    What you want as the default "Stereo Mix" device is under the PLAYBACK tab.
    Then set whatever else you want "Line in" or "Mic" as the default recording device.
    Ap
  4. Posts : 19
    Windows 7 HP
    @geeve420
    i use the 'sound recorder' in windows and i want to record sound directly from my computer...eg.sounds from youtube, sounds from other websites
    @Aphelion
    'stereo mix' does not exist in the PLAYBACK tab
  5. Posts : 19
    Windows 7 HP
    EDIT: it works now but everytime i record the sound is epic soft ??? i have to turn it to nearly loudest to get the volume right
  6. Posts : 908
    re: Stereo Mix
    Sorry, yes... in Recording Devices. duh!
    When you select Stereo Mix and then select the "Properties" button at the bottom, then the "Levels" tab, what volume is the record level of Stereo Mix.
    Ap
  7. Posts : 19
    Windows 7 HP
    its ninety something when i recorded it and i just made it to 100 and i dun think thats gna make much different
  8. Posts : 908
    What are you feeding it with, what are you recording?
    I only have mine set on 20.
    There's also Input level controls for Mic, Line-In...etc.
    Ap
  9. Posts : 19
    Windows 7 HP
    Ap
    i wanna record some of the things i hear from youtube and some other sites which got music i like but u cant download
    and does that mean everytime i wanna record sound from that i have to make it to etreme loud??
  10. Posts : 908
    Ap
    Basically... yes!
    Turn your speakers down and your playback volume up.
    Ap
    Do you have any of the
