Solved 1 second sound delay on playing audio or system sounds.
The Flume
5:05 AM
I have recently been having this problem about this sound delay. I recently have replaced my broken AMD Radeon HD7700 to an NVIDIA GeForce GTX 750 TI Superclocked and my soundcard is built into the gpu I think.
I know this for BSOD's but here is the diagnostics file if you need it.
PS: I have been looking online for this problem but i cant find anything that works or even sloved.
Windows 7 Ultimate x64Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz16GBNVIDIA GeForce GTX 750 Ti Superclocked
DELL XPS 8500
DELL
16GB
(C:) SanDisk SDSSDHP 128GB
(E:) ST2000DM001-1CH164 1.80TB
(D:) SAMSUNG SSD PM830 MmSATA 32G
Fans
Logitech K120
Logitech G402
50 mega bits
If you are using HDMI audio then the video card is supplying the audio. However, if you are using the standard motherboard sound and speakers then its the sound chip on the motherboard (or separate audio card) that is supplying the audio.
The XPS 8500 uses Realtek for integrated on motherboard audio.
The dump doesn't detail exactly which you are using. However, if you are using HDMI audio make sure you have the latest drivers for the video card.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
The problem fixed itself
the problem went after a few days its fine now
DELL XPS 8500
DELL
16GB
Fans
Logitech K120
Logitech G402
50 mega bits
