Solved 8-PIN Motherboard and a 4-PIN Power Supply
hArLtRoN
Power User
6:05 PM
Denver, Colorado
I was looking through motherboards and noticed that this one has an 8-PIN power connector.
I went and looked through PSUs and found that most are only 4-PIN, like this one.
What am I missing? How do you connect a 4-PIN PSU to an 8-PIN board?
Thanks!
Windows 7 Ultimate x64AMD Phenom 9850 x4 2.50GHz4GB DDR2nVidia GeFore 210
ASUS M4A785-M
4GB DDR2
nVidia GeFore 210
Onboard
Samsung SyncMaster BX2031 20" LED
1600x900
Western Digital Caviar Blue 500 GB SATA III 7200 RPM
450 Watt
Raygo R12-40835 ATX Mid-Tower Case
Air
Laptop:
Intel Core Duo T2450 @ 2.00GHz
2GB RAM
Windows 7 Ultimate x86
A lot of the newer PSUs have two 4 pin connectors to use for the 8 pin connection. Also I have seen some 4pin to 8 pin adapters on NewEgg and eBay.
on motherboard
6 pata Ide HD's & 2 Sata HD's
All Generic Full Towers
Fast Cable InterNet
Linked via TeamViewer !
The PSU you linked has an eight pin power connector. It's listed as 4+4 which means it can be split to use with a MOBO that has only a four pin socket or it can be used put together side by side for MOBOs with an eight socket.
Win 7 Ultimate 64 bit
Intel i7-3930K
ASUS P9X79 WS
Asus Xonar Essence STX
1920 x 1080, ?
Samsung 4TB 850 EVO SSDs (4)
Corsair HX750w
Logitech G510s
Logitech M525 (two in use)
=< 32Mbps down, 8Mbps up
IE11
Does "1 x 12V (4+4Pin EPS/ATX)" mean it has (2) 4-PIN connectors?
EDIT: Lady Fitzgerald, we posted at same time. Thank you!
ASUS M4A785-M
4GB DDR2
nVidia GeFore 210
Onboard
1600x900
450 Watt
Air
Laptop:
2GB RAM
It happens. ;)
Intel i7-3930K
ASUS P9X79 WS
1920 x 1080, ?
Corsair HX750w
Logitech G510s
IE11
ASUS M4A785-M
4GB DDR2
nVidia GeFore 210
Onboard
1600x900
450 Watt
Air
Laptop:
2GB RAM
