Any way to auto switch power plans when plugging in to charger?
zapp22
Power User
8:53 PM
Tejas, northern Mexico
anyone know how to do this? when plugging in to AC adapter, the system switches to a different power plan?
Windows XP Pro SP3, Windows 7 Pro 32-bit, Win...Pentium 4 3.2GHz, Pentium 4 3.4GHz 64bit, Atom,4GB matched, 1GB, 2.5GB, 4.0 GBGeforce 8400 GS and others
HP DC7600, HP DC7600[2], HP DC7100, Samsung NC10
Windows XP Pro SP3, Windows 7 Pro 32-bit, Windows 7 Ultimate 64bit, Windows XP Home SP3
Dunno
RealteK ALC260 and others
Asus HD
WD Caviar 640gb SATA
We Be Cool
Custom assembled by me :}
Win-7-Pro64bit 7-H-Prem-64bit
Built-in Realtek
2-Samsung M.2 Evo & Evo Plus
Custom water loops
FireFox & Pale moon
It is possible with AVG PC Tune up.
The software comes with PC optimization mode with standard,economy and turbo mode.
It automatically switches to economy mode when running on battery and is restored to normal mode when running on ac supply.It changes its mode automatically based on power supply.
It also consists of turbo mode which is efficient for gaming.
windows 7 ultimate 64 bitIntel core i3-2350M cpu@!2.30 Ghz4.00 GBAMD RADEON HD 6370M(1GB)
LENOVO G570
Lenovo
4.00 GB
Generic pnp Monitor
1366*768
ST9500325AS ATA device(500GB) NTFS
Standard ps/2 keyboard
synaptics ps/2 port Touchpad
921.6 kbps(Dial up Connection)
Quick Heal,MSE
Opera,Chrome
let me try to be clear:
when on battery, I want 'Balanced" plan with all my custom settings [already done]
when I plug into AC Adapter I want windows 7 to automatically switch to "High Performance" plan [which I have setup, but I have to manually change over from Balanced to High Performance]
my understanding is that high performance features such as the use of overclock/turbo settings are not available in "balanced" or the "power saving" defaults. but I could be wrong... wouldn't be the first time
Dunno
Asus HD
We Be Cool
I believe the Balanced power settings are best all around let windows manage the settings that's why balanced is there ;)
Cheers.
Built-in Realtek
Custom water loops
FireFox & Pale moon
"I believe" the Balanced power settings are best all around let windows manage the settings that's why balanced is there ;)
Cheers.
I didn't know we dealt with belief systems here... Oh! yes we do... just take a look at the "best anti-virus" thread!! :sarc:
the issue is maximum performance.
Dunno
Asus HD
We Be Cool
Brink posted an alternative to switch manually,
Belief system works very well depending on how much junkware is installed :)
Cheers.
Built-in Realtek
Custom water loops
FireFox & Pale moon
A workaround
I'll just throw this in. It's not a perfect solution but it's possible to change power plans just by running any process that you care to define.
This screenshot shows the Power Plan changing when EmEditor is run then being restored to the original Power Plan when the process stops.
I can't figure out if any additional process runs when a charger is plugged in - or at least I couldn't track one down on my machine.
ASUS
ASUSTeK COMPUTER INC. X501U
4.00 GB
AMD Radeon HD 6290 Graphics
It is okay to be wrong, which you are. Turbo boost and overclocking are not affected by which plan you have enabled. It is just how they are configured with their default settings.
For example you can configure the high performance mode to be super power saving if you wanted. The actual plans are just setting profiles to quickly change as the need arised.
Alienware Aurora ALX R4
Windows 10 Pro (x64)
Alienware Aurora-R4 x79
Nvidia Geforce GTX 690
SteelSeries Siberia Elite
Dell UltraSharp U3011
2560x1600
875W Some Dell PSU <.<
Logitech G710+ Mechanical
