Solved Are my water cooling temps okay
BigTabs
It's All About Money
Power User
2:50 AM
Chester
So and ideal its 29c to 31c
and full load using prim95 is 45c and that is with the AMD FX8150 running full 8 cores and i think its clocked at 3.9 ghz
Windows 7 64 (bit)I7 4790K8GBEVGA 770 SC ACX
Windows 7 64 (bit)
I7 4790K
Asus Maximus VII Hero
8GB
EVGA 770 SC ACX
iiyama GB2488HSU
1920*1080
1TB WESTERN DIGITAL BLACK
850 EVGA Supernova G2
Carbide Series® Air 540 High Airflow ATX Cube Case
The Black Ice® GT Stealth 240, Alphacool NexXxoS UT60 280
STEELSERIES APEX [RAW]
Roccat XTD
30Meg
Bitdefender
Those are perfectly fine temps
on air for my fx-8150 at idle i have 25-35c and on prime95 I have 65-80c
so you have nothing to worry about
not to mention on everyday applications your never going to be using your CPU to 100%
windows 7 home premium 64 bitAMD FX-81508gb g.skill 1333mhzSapphire Radeon HD7770 Ghz edition
First custom build
AMD FX-8150
GA-78LMT-S2P 760g REV3.1
8gb g.skill 1333mhz
Onboard
1600x900
320gb 7200RPM HDD
500gb external hybrid drive
460w
Cooler Master Centurion 590
Cooler Master Hyper 212 Evo
ROCCAT ISKU
ROCCAT Kova +
Terrible everywhere, everyday
