Do I need to put new water in my water cooling system?
Vaas
11:05 AM
So i have heard that some water cooling systems do need new water in them every 6 months, and i have also heard that some never need to have the water replaced, so i have no idea of what brand/kind of water cooling system i have because it has no branding or anything, i got my computer custom built from ibuypower so it was professionally installed and stuff, so anyway here is a picture of it and maybe you guys can tell what i need to do, http://i.imgur.com/qxlPpCR.jpg
It looks like even if i wanted to replace the water its not built to open up, so yeah can any of you guys tell me what kind it is.
Thanks for reading this~
Microsoft Windows 7 Home Premium 64-bit 7601 ...Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz8.00 GB(1) NVIDIA GeForce GTX 770 (2) Standard VGA G...
unknown
Gigabyte Technology Co., Ltd. Z87X-D3H-CF
8.00 GB
(1) NVIDIA GeForce GTX 770 (2) Standard VGA Graphics Adapt
(1) NVIDIA Virtual Audio Device (Wave Extensible) (WDM) (2
(1) 1280 x 720 x 32 bits (4294967296 colors) @ 60 Hz (2) 1
(1) KINGSTON SH103S3120G ATA Device (2) WDC WD10EZEX-00KUWA0 ATA Device
Raidmax yellow
120mm(3) Cooler Master Hyper N520 - CPU Cooler
CM Storm quickfire rapid
Logitech g500
Your system should of come with some kind of manual from ibuypower. If not I would contact them and find out what they recommend to use to replace the fluid and how often.
This appears to be a 'closed-loop' type cooler, no opening for adding fluid. The medium inside is formulated to prevent any growth of algae. No Maintenance. :cool:
Win7 Home Premium x64 W10Pro&HomeA12 9720p 4+8 TurionII M5206GB 8GBR7
HP 17-ak0xx, dv7 3173nr
HP 3839
6GB 8GB
R7
24" sa550
1600x900 1920x1080
Logitechx2
120Mb/s down 12up
Looks like a sealed unit to me also, but even they degrade after time. What are your temps at idle and at full load ?
Strange there is no trademark on the waterblock.
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
My temps at idle are 40°C, Full load 57°C
Any idea of how long it takes them to degrade?
@LayBackBear i did not get a manual with my system, and i will from now on post pictures that way =D
unknown
8.00 GB
Raidmax yellow
Logitech g500
Thank you Vaas.
Bump
unknown
8.00 GB
Raidmax yellow
Logitech g500
If that is a closed loop system, then no......there pretty much isn't anything to be done to it. If there seems to be a fill/drain hole in the radiator, you may be able to flush it and refill it. Although I don't know how you would find out how much to put in it and if there is a certain type. If it is still doing it's job, I'd leave it be.
Windows 7 Professional 64bit SP1Intel Core i5-3570K @ 4.5GHzCorsair Vengeance 16GB (4x4) @1866MHz CL 9-9-...EVGA GTX 750 Ti FTW
Asus Sabertooth Z77
EVGA GTX 750 Ti FTW
Onboard Audio
Dell S2309W
Samsung 830 128GB SSD - OS
(4) Seagate 5TB HDD
(1) Seagate 2TB HDD
Intel Liquid Cooler
Mionix Naos 7000
50 Mbps Down / 10 Mbps Up
Chrome/Firefox
Klipsch ProMedia 2.1's
Asus RT-N66R Wireless Router
