Atheros wired ethernet connection problem
tnad
3:37 PM
Every time I connect my laptop with the Atheros wired ethernet adaptor at my work at my university (but it works home), I am forced to uninstall the driver from the device manager and then restarting windows 7 to get it to connect (it automatically installs the driver in this case). This happens every single time. I tried installing drivers from the laptop site and from the manufacturer but nothing works. I really have no clue what to do here to troubleshoot or fix the problem. I hope I can get some help or clues from someone. Please ask if you need some extra details. Thanks.
Windows 7 home premium 64bit
Perhaps work is using IPv6 and home IPv4. Are you using "homegroup" or workgroup at home?
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
I asked at work and was told there is no IPv6 and I tried to disable IPv6 but that did not help. I usually use wireless at home (but I tried wired a few times just to test). Maybe this will clarify things more: as I said, after uninstalling the drivers from the device manager and restarting, the wired connection at work works perfectly (windows auto-installs drivers), but simply restarting the computer again at work (after the connection is working) will cause the connection to stop working and will force me to uninstall the drivers again and restart.
I know this is a bit late but i have just had the same issue my self with at Toshi satellite using an Atheros Wierd NIC. I have two networks at work one for our internal use and a septate DMZ network for working on customers computers.
I noticed the the NIC worked correctly (DHCP and Ping) when connected to a SRW2048 (Primary) Network Switch but would fail (NO DHCP and intermittent Pings) when connected to a CABAC Smart 10/100 (DMZ)
I am only speculating here but there seems to be an issue when talking to some older managed switches.
The only solution i see is to either use an Expansion Network Card or get a WIFI bride Device so the wireless can be used to connect to the weired network.
Built by Billman
Core I7 2600
Intel DH67GD
4096MB Kingston DDR3 667Mhz
Asus nV560Ti
BenQ E2220HD
60Gb OCZ Vexer 2 (boot)
500Gb WD Green (Swap)
2x500Gb WD Blacks non RE (Striped)
1000 Watt Antec
Coolmaster Elite 353
Microsoft Wired
Microsoft Wired
Usless
Have you tried connecting wirelessly? If so does it connect with out any trouble? You may want to contact your works IT department and see if they can't sort out your connection problem. It sounds like you need to have both lan drivers installed. Usally all the generic lan drivers all most all ways work for home and office networks, this one might be specific.
Custom built
Windows 7 Ultimate 64 bit
AMD Phenom II X4 965 Black Edition
Gigabyte GA-MA790X-DS4
GSkill 4 X 2 GB PC 8500
XFX Radeon HD 6790 D
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
In my case the wireless worked perfectly, and in the end I left my customer using the Wifi. However this is not practical for all situation, Aslo Limiting the network card to 10Mbit (if 1250k/sec is enough) can improve the stability if you were receiving massive packet lose(like i was when I Static the IP address due to no DHCP).
Another Note maybe these NIC don't like old school 10/100 managed switches. I no longer have the laptop to try, but maybe (As Stupid As It Sounds) put a new Gigabit switch between you and the wall socket.
Built by Billman
Core I7 2600
Intel DH67GD
Asus nV560Ti
BenQ E2220HD
1000 Watt Antec
Microsoft Wired
Microsoft Wired
Usless
