avast installation problem...help me
nfsworldpinoy
5:33 AM
this is what i get when im opening avast..after loading the buffer symbol this is what i get what is supposed to be the problem
windows xp pro 32-bit
Sometimes program installations can be corrupted through no fault of the user. Go to Control Panel > Programs and Features and see if Avast is listed. If it is, uninstall it. Then use the official Avast uninstall utility to make sure all traces of Avast are removed. I'd also run a Disk Cleanup and delete any unnecessary non-system files (Step 4 in tutorial) just in case some Avast temp files may remain. Then use the official Avast download site (or your install disk if you're using the paid version) to reinstall. Hopefully this will solve the installation problem.
avast! Uninstall Utility | Download aswClear for avast! Removal
http://www.sevenforums.com/tutorials/818-disk-cleanup-open-use.html
avast! | Download Free Antivirus Software or Internet Security
NOTE: If you now have, or ever had, any other antivirus programs on your machine you should consider running that product's uninstall utility. Previous remnants could interfere with this installation.
Security Software | SingularLabs
Sony Vaio VPCEB47GM Laptop
Win 7 Pro 64-bit
Intel i5 2.4 Ghz
8GB DDR3
Intel HD 3000
IDT High Definition
15.6 WGXA Anti-Glare LED
1280x800
640Gb 7200rpm
