Solved Bought parts and i failed. I think.
VincentStrike
4:07 AM
Finland
My old computer is Acer ASpire x1301 where i took the parts from to those new one
So i bought this Corsair 600W CX V2 Builder Series, ATX-virtalähde, 80Plus | 65.00e - Jimms.fi and CoolerMaster Elite 430 ATX-kotelo, musta | 59.00e - Jimms.fi
I'm not sure but i think that PSU's the long cable seems like to be too big for my motherboard white slot. here's picture of my motherboard Google-kuvahaun tulos kohteessa http://bios-repair.co.uk/Images/mobo/Acer/Aspire/Aspire-X1301-Mainboard.jpg
So...I think the power supply is the problem that my computer won't start up...Or the motherboard? Too old? Please help me :(
Windows 7 64 bitAMD Athlon(tm) II X2 215 Processor 2.70 GHz4gb RAM (3.75 In use)Nvidia Integrated Geforce 9200
Acer Aspire X1301
Windows 7 64 bit
Acer Aspire
Philips 192E
1368 x 766 (Recommended)
HDD 1TB
110MB/S (11 - 12MB Download per second.)
Please can someone help...So i switched all parts from Acer Aspire x1301 to that new case there + i added the new PSU. But the PSU's black big plug in thing is too big for my motherboard :(
Acer Aspire X1301
Windows 7 64 bit
Acer Aspire
Philips 192E
HDD 1TB
Acer Aspire X1301
Windows 7 64 bit
Acer Aspire
Philips 192E
HDD 1TB
Some MOBO's only require a 20 pin in stead of a 24 pin cable. With most PSU's these cables are made so you can detach the 4 pins that are to much
Windows 7 Ultimate x64Intel Core i7 2600k @ 4.5 Ghz6 GB kingston hyperX memory 1600 MhzASUS GTX 570 Direct CUII
Me
MSI P67A-GD65
On board
Digimate 22" 16:10 1680x1050
Seagate Momentus XT 250 GB
WD 500 GB Green HDD
Corsair 750W Professional
Antec DF-85
Corsair H70
Logitech G510
Logitech G700
D: 40 Mbps - U: 1.5 Mbps
The connector from the pwoer supply is 24 pin and the motherboard is only 20 pin, not a problem though. This is the connector from the power supply,
the extra 4 pin connector on the end (circled in red) is made to come off so that it will fit/work with 20 pin motherboards. As for it not starting up, did you remember to connect the additional 4 pin power connector to the motherboard?
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
I'm gonna try this, thanks for the picture just the way i want so i can understand easily :) CAn you also check my other thread in Hardware Devices of the (START) Button pins
Acer Aspire X1301
Windows 7 64 bit
Acer Aspire
Philips 192E
HDD 1TB
Here is the picture after all hard work :D Valokuva0254.jpg
So can you show with paint or somehow where i put each wire? :) I appreciate your all help! :)
And btw you said i should plug in the last 4 pins in the 24 pin cable to the white slot...I don't think the 4 ''add'' pins gonna reach there :D
Acer Aspire X1301
Windows 7 64 bit
Acer Aspire
Philips 192E
HDD 1TB
There should be an 8 pin connector from the power supply that is really two 4 pin attached together. Once you find it, you split it apart just like the 24 pin main connector and only use one of the two 4 pin.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Okay...But what about the START button so my computer goes on? That picture where i've typed orange & white ... etc... Comes from the start up button...Where do i put them?
EDIT: In other thread i saw that picture i'll try it on the morning. :)
Acer Aspire X1301
Windows 7 64 bit
Acer Aspire
Philips 192E
HDD 1TB
