writhziden
Closed by request.
The most recent crash indicates faulty or incompatible RAM as the most likely problem.
- If you are overclocking any hardware, please stop.
- Run the boot version of Memtest86+ paying close attention to Parts 2 and 3 of the tutorial. Also, in case Memtest86+ misses anything and comes up with no errors, run the extended version of the Windows Memory Diagnostics Tool for at least five passes. These you may want to run overnight since they take a long time to complete (run them an hour before bed each of the next two nights and check before going to sleep that they are still running).
WarningBefore you proceed with the following, answer these two questions: Are you still under warranty? Does your warranty allow you to open up the machine to check hardware? If you are unsure of the answers to these questions, contact your system manufacturer. :warn:WARNING: The steps that follow can void your warranty!!!
For Part 3: If You Have Errors: If you swap any memory components, follow these steps for ESD safety:- Shut down and turn off your computer.
- Unplug all power supplies to the computer (AC Power then battery for laptops, AC power for desktops)
- Hold down the power button for 30 seconds to close the circuit and ensure all power drains from components.
- Make sure you are grounded by using proper grounding techniques, i.e. work on an anti-static workbench, anti-static desk, or an anti-static pad. Hold something metallic while touching it to the anti-static surface, or use an anti-static wristband to attach to the anti-static material while working. If you do not have an anti-static workbench, desk, or pad, you can use your computer tower/case by finding a metal hold in it, such as a drive bay.
- We should check your RAM compatibility: Download and install CPU-Z and Upload screenshots of the CPU, Mainboard, Memory, and SPD tabs. In the SPD tab, upload an image of each slot.
Windows 7 Home Premium 64 BitIntel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz6.00 GB Hundai HMT125U6BFR8C-H9ATI Radeon HD 4850
- HP Pavilion e9110t
- Windows 7 Home Premium 64 Bit
- Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
- Motherboard
- Pegatron IPIEL-LA3
- 6.00 GB Hundai HMT125U6BFR8C-H9
- Graphics Card(s)
- ATI Radeon HD 4850
- Sound Card
- Realtek High Definition Audio/ATI High Definition Audio
- Monitor(s) Displays
- Acer AL2216W
- Screen Resolution
- 1680x1050
- Hard Drives
- Hitachi HDP725050GLA360 ATA Device 500 GB
- PSU
- Unknown/installed by HP
- Case
- HP generic case
- Cooling
- Intel Stock Cooling
- Keyboard
- HP Keyboard
- Mouse
- HP Mouse
- Internet Speed
- Download: 19.15 Mbps Upload: 1.67 Mbps
- Other Info
- Network Adapter Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
Network Adapter 802.11n Wireless PCI Express Card LAN Adapter
