The Motherboard in question should atleast admit a beep of some sort when it has power
if there was no beep there is something wrong the connections are secure the next step he can try it in another rig
and see if he can get it started if not i would think the PSU doesn't have enough power and he needs to replace it with something that can
OK,if you would just read my previous posts instead of only reading the very last post,you would understand the predicament,and not suggest something that has been tried and testet.
Please understand, there is NOTHING wrong with the psu,the psu works on 2 other computers,it works when tested with multimeter. The psu in question does however NOT work with the gigabyte mainboard,which is why i am confused,as it should work fine unless mainboard is fried.
I can get psu fans and everything to spin if i short pin9 and a groundwire,but as soon as 4pin 12v atx and 24pin power is connected to mainboard nothing happens,not a single beep or anything
If you do not know if the mainboard is fried, I cannot understand why won't you test another PSU on the motherboard, NOT the PSU, test the motherboard with another PSU. I don't get why that is so hard to understand.
Anyway I still stand by what I told you before your MB might be underpowered by that Unit just because it came on with others doesn't mean it still is underpowering the one you are using
I have had this happen to me when i couldn't get my unit on with a 450 psu and running a 1 gb 5670 even though i met the requirments it was still under powered
I went and bought a 600w coolermaster and it came on like christmas none of us were trying to give you redundent answers but just because it says 500 watt doesn't mean it will put it out
- Computer type
- PC/Desktop
- CoreI7-6700K MrFingerIII Special Builds
- Windows 10 Home Premium 64bit sp1
- Intel I7-6700K @ 4.6 Ghz 1.344 volts everyday OC
- Motherboard
- Asrock Fatality K6 Z170 Socket 1151
- 32GB G-Skill TridentZ 3200mhz 16-18-18-38 DDR4
- Graphics Card(s)
- Sli Gigabyte Windforce GTX 980 G1
- Sound Card
- AC97 Creative Rage Tactic 3D Headphones Bluetooth
- Monitor(s) Displays
- 27" Asus ROG Swift PG278Q G-Sync 48" Vizio Smart HD TV
- Screen Resolution
- 2560x1440p 27"- 48" Currently Gaming at 2560x1440p Res 2K
- Hard Drives
- 250GB Samsung Evo840SSD Seagate baracuda 500 GB WD Mybook 500Gb 1TB Seagate Barracuda
- PSU
- HX1050w Corsair Silver 80plus certified crosfire/sli
- Case
- Enthod Pro Full Tower
- Cooling
- Corsair H110i GT 280 mm High Performance WaterBlock
- Keyboard
- Logitech wireless keyboard
- Mouse
- Logitech wireless mouse
- Internet Speed
- Cox Cable 100+ mb
- Antivirus
- WebRoot Spysweeper with Antivirus
- Browser
- IE-10, Chrome, Opera
- Other Info
- My Other Rig is a AMD FX8320E @4.6Ghz 16GB Ballistic Sport Ram
GPU GTX Gigabyte 970G1
