Solved Color Problem Help?
tythebuilder
12:35 AM
Toronto, Ontario
This is what happened to my pc after A random restart. How do I fix it?
As you can see the gradient is weird. Look at the background?
HP Pavilian
Windows 7 ultimate 64bit
AMD Phenom(tm) 8550 Triple-Core Processor 2.20 GHzz
4.00 GB (3.75 GB usable)
Geforce 9100
32" Insignia LED HD TV
500 GB
Hello,
I'm unable to see the image clearly as i'm on mobile. But from what i can see, are you talking about the basic taskbar? Or something else?
If the whole display has problem, under your graphic card's control centre, there should be an option to restore default settings? Have you tried that?
For ATI, it's under CCC>Preferences>Restore factory defaults.
Also, update your card's driver if you haven't already.
HCL
Winbdows 7 ultimate x64 | Ubuntu 12.04 x64 LTS
Core 2 Duo e7400 @ 2.90GHz
Gigabyte G31M-ES2L
3GB DDR2
Asus Nvidia GTX 560Ti 1GB
On-board
HCL eZeeBee 18.5" LCD
1366x768 @ 60Hz
Western Digital 320GB
Corsair CX500 V2 500W
15-25kBps D/L | 10kBps U/L | Hey Don't laugh
Are you referring to the stair stepping in the color gradient, particularly in the upper right? If so, that looks as though you've changed the screen bit depth from 32 bits to say 8. Look in Control Panel > Display > Adjust Resolution > Advanced Settings. In the Monitor tab you should see a control called Colors. It should be set to True Color (32 Bit). Look at the picture in the attachment.
Andacar
Custom machine
Windows 7 Professional 64 bit
i7 920
ASUS P6T Deluxe V2
6 gigabytes
nVidia Quadro FX 1800
Creative SB Audigy 2
IBM 21" CRT
1600 x 1200
Hitachi 1 TB Main Drive
Western Digital 1 TB Storage
Western Digital 2 TB Projects
Logitec Access 600
Logitec M100
Thanks for your help but it ended up just being that is was set to 16 bit so i changed to 32 And works fine.
HP Pavilian
Geforce 9100
500 GB
Glad you got it sorted. And thanks for the update. :)
HCL
Gigabyte G31M-ES2L
3GB DDR2
On-board
1366x768 @ 60Hz
That's what I figured...
Custom machine
i7 920
ASUS P6T Deluxe V2
6 gigabytes
IBM 21" CRT
1600 x 1200
Logitec Access 600
Logitec M100
