Solved Corasir Liquid cooling unit louder and hotter than two fan Noctua
TanyaC
5:51 PM
Melbourne, Australia
Following on from my case upgrade I installed a Corsair H100 liquid cooler.
With it set to performance, the fans are spinning at 2160 RPM. Sadly, they do not respond to the controls on the Lamptron Touch. At 0% (0v) they still spin at 2160rpm.
At 2160RPM the system is 5c hotter than it was on the Noctua NH-U9B-SE2 cooler.
It is also substantially louder.
On the slowest setting the fans spin at 2160.. Ok, so it looks like the lapmtron is telling fibs... The noise is less, but still somewhat louder than it was.
The temperature on the lowest setting is 7c hotter than on the noctua.
Instead of reducing noise and temps, I;ve actually gone backwards...
As per instructions on the Corsair video - I have set the fans to pull air into the case through the radiator.
These figures are at idle.
What am I doing wrong?
thanks
Tanya
Linux Mint 17 Cinnamon | Win 7 Ult x64Intel I7-3770K @ 4.2ghz32GB G-Skill C10QEVGA GTX 670 2GB SC
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
Creative Fatality ExtremeGamer
LG E2742V x 2
256GB Vertex 4 SSD
2TB Seagate ST2000DM001
1TB Seagate ST1000DM003
Corsair HX 650
HAF 932 advanced
Corsair H100i liquid cooler
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
Router: Sagemcom F@st 3846 Crippled by Optus.
This sounds quite weird to me, I have read that the H100 gives really good temps and a lot of people on the forum is using one, I am using a H80 one myself, are you using the default black corsair fans that comes with the unit because I tried those and they are insanely loud so mine is using 2 noctua fans and thats what the other peoples here do also, the newer corsair fans are nice and performce the same as noctua fans but you get 2 fans for the price of 1.
What I would do thou is to turn the fans around so the fans pull the air out of the case and tried it like that instead to get rid of hot air building up in the case, and perhaps going over the screws again and see if it sits loose over the cpu area
Windows 7 Home Premium x64Intel Core i7 860 (Lynnfield)Corsair Vengeance 9,9,9,24 1600Mhz 1.50v 2x4GAsus nVidia 560 GTX
Asus P7P55D (LGA1156)
Asus nVidia 560 GTX
Asus Xonar DG
Acer P235H & NEC E201W
1920x1080 & 900x1600
Corsair 650 Modular
Corsair 800D
Corsair H80 with Noctua fans
Ducky Shine
tT Theron
IE10
thanks
Tanya
TanyaC I don't think your ears are fibbing, but the Lamptron may be doing so and I wonder if not with both the temps and RPMs. I don't know if you've read it or not but a review on the Lamptron speaks of some problems with the RPM readouts anyway (under the heading One Minor Quibble). If you go into it at boot, what does your BIOS say the temps are?
Windows 10 Pro 64 bitCore i7 6700K Skylake 4.0GHzCorsair Vengeance LPX DDR4 32GB 3000MHzAsus Radeon RX480 Strix 8GB
Wordsworth 5000
Asus Z170 Pro
Asus Xonar DSX
HP 2709m
Intel 600p M.2 PCIe NVMe SSD 512GB; Intel 335 SSD 240GB ;Western Digital Caviar Black 1TB
Thermaltake Toughpower Grand Platinum 850W
Lian Li PC-B70
CPU-Noctua NH D15, GPU-Stock, Case-Noctua 2x140, 2x120
Microsoft Natural Ergo 4000
Microsoft Wireless Optical 1000
Cable
HP bd 340,
HP bd 240,
Klipsch Promedia 5.1 THX
The noctua fans are just made in a very superior manner.
The materials used are specifically made to decrease noise.
My solution, put the noctua fans on the corsair radiator.
They may be ugly to look at , but they really are probably the best made computer fans on the planet.
Windows 7 x64Intel i7 2600kG.skill Ripjaw 16gigs @ 1866Nvidia gtx580 (evga)
Insane hobo technologies. ;-)
Windows 7 x64
Intel i7 2600k
Asrock z68 extreme 4 gen 3
Integrated HD audio + hdmi
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA)
Zalmann
Microsoft wireless 3000 (v2)
:ditto: My experience is the same as yours, TanyaC. I have a system with a Noctua NH-D14 and had another with a Corsair H100. The fans on the H 100 were unbearable. I changed the fans in every configuration possible. I go rid of the noise by using Noctua fans, but the H100 never kept my CPU as cool as the D14 did. I know a lot of others swear by the H100, but my experience is different. And if you go with the Noctuas, forget the Lamptron. Connect them to the PSU. You won't need a fan controller.
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Hi all. The Noctua fans are 90mm fans, and don't fit the cooler. But I can always go and buy some 120mm fans.. They are only $29 AUD each.
I turned them around, so that they are blowing the hot air out the case through the radiator, as suggested. Temps are down 3 degrees celcius @ CPU 32c / M/B 30c.
All fans are on half speed, the H100 fans are set to the lowest setting. The noise is much better, but still not as quiet as it was before, so I'll go and pick up a couple of fans tomorrow.
@Wordsworth: When I quote temps I always quote from what the BIOS says. I typically don't rely on readings from third party programs, even the ASRock utility. The Lamptron is great for all other fan/temp readings. It wasn't really a surprise that the H100 couldn't be controlled. it has a Digital link controller, which of course, is sold separately, and can be used to manage the H100.
The only thing I don't like about this cooler is that when the system starts up or resumes from sleep it makes a noise like a jet plane taking off for about 30 - 40 seconds.
Scared the hell out of me at 4am this morning when my system woke up to do it's overnight maintenance
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
Just so you know the asrock utility IS using the bios data to give you the temps.
Just fyi. The reason it loads slowly for such a small program is because it has to grab all the data from the bios to work.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
I'm using an H80 with my new i7 3770 build. I too had problems with the noisy OEM fans and have installed Nexus "Real Silent Case Fans". I can now use the new PC in my recording studio (what I built it for).
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
No Drama. Interestingly, the temps reported by the ASXTU are allways 3-4c lower than what the bios reports. Speedfan and coretemp also report pretty much the same as ASXTU.
So I go by the highest reported temp and work on lowering that :geek:
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
That's odd I have an asrock board and the temps have generally been dead on.
Then again your board is a generation above mine.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
I have never used Real Silent Case Fans but looks like a good fan system if it works well in fireferd's recording studio. As you can see in My Specs I use Noctua fans all over my computer. No fan controller needed just run them 100% off the motherboard or power supply. The CPU pump is hook to the Cpu fan connection on the motherboard and runs at 1450 rpm all the time with no noise. The only thing I have noticed with my H50 is the idle/low load temps are always 23c above ambient (19c +23 = 42c) but under 100% load mid to high 60c is reached O/C to 4.1. Here is a little trick I use. The O.E. case fan on top with push/pull Noctua fans on top blow around and through my DSL modem and router keep them a lot cooler, 2c above ambient. Seem like the router and modem are the only 2 things people never cool.
My case is heavy on fans but the noise is fairly low.
The graphics card gets noticeable under load, but only because I've set it not to get above 65c.
This is amazingly accomplished without ever going above 70% on the fan though.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
It is always better to use good quality aftermarket fans with a sealed waterblock
I have the Antec 620 Khuler it was running smooth when first set but temps started flexuating
I dumped the stock fans that Antec gave with the product and bought some mugen sythe slipstream fans my temps have been great ever since
Better off using the quality fans you already have then trusting the package product fans my experience with sealed blocks the fans they provide are not worth putting on IMHO they are just cheap fans with there logo on it that's all
Enthod Pro Full Tower
Logitech wireless keyboard
Logitech wireless mouse
Cox Cable 100+ mb
IE-10, Chrome, Opera
GPU GTX Gigabyte 970G1
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
For those still looking for quality quiet fans I know the feeling. I like many others I would think did a lot of homework studying a lot of reviews and reading a lot of specs before paying the big bucks for Noctua fans. You can live without them but once you get them you will wonder why you did. The color grow on you in about a year. Because I bought mine through a local dealer I payed premium price of $28.00 apiece. They are worth it to me still today. You can buy them over the net cheaper.
Just for clarification, I have all the fans in my desktop, running at lowest speed (and still runs "cool"). I have the H80 set to lowest speed, and the three case fans in my Corsair Carbide 500R case at low speed (two in front and one on the side). My power supply is an Antec High Current Gamer HCG-620M Modular and it too is a "quiet fan" power supply.
RealTemp GT shows CPU temps mostly around 35C, under heavy recording use they will jump up to around 41C.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
With the Noctua's run them wide open with no speed limitation and if possible run them off the PSU and not off the mobo to keep the voltage off the board.
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
Definately going to get the Noctuas. I have the fans turned down low, and system is still at 30C. And now I hear the Corsair fans rattling. I've never had a Noctua that rattles, so I'll be off the local shop agin in a few mins.
I can connect them to the Lamptron. That has it's own power from the PSU. The fans have a 3 pin connector, and I'd prefer not to be adding redundant molex connectors when I don't need to. The fewer cables the better is my motto.
Prior to upgrading case and cooler my system was at 34C and when encoding media it jumped to 63C. I haven't done any encoding since upgrading, I'll get to that in the next day or two and will revert with temps.
Interestingly, this upgrade was not orginally about cooling. It was that my Antec 900-2 case had too many design flaws that irritated me, most notably the drive cages.
As always I am grateful for all the support and assistance. It is wonderful to be able to come here and get such good advice and feedback. Thank you.
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
If you are going to be using them for the rad, you may look at the Noctua NF-F12's rather than the NF-P12's. The F12's are 'focused flow fans' and will penetrate the rad better I believe, although the P12's do a good job.
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Yes, I have purchased the F12's. Had a look online before I went out. They also have anti vibration pads, and a 200rpm higher max spin (which I hopefully won't need), and they were the same price as the P12's.
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
