Crash Problem with my pc ... pls help! :)
roki994
10:20 PM
I have a problem with my pc...it gives blue lines on my monitor and then crashes to blue screen! :(
I've attached files from C:/Windows/Minidump , so if you could pls help me.
Windows 7 Ultimate 32bit
Windows 7 Ultimate 32 bitIntel(R) Pentium(R) 4 CPU 3.00GHz2.50 GB RAMNVIDIA GeForce 7600 GS
Home built
ASUS P4P800-VM Motherboard Chipset: Intel 865G + ICH5
2.50 GB RAM
SoundMax Integrated Digital Audio (Chip)
ViewSonic VX 1962 wm
1680 X 1050
Seagate Barracuda 7200.10 80 GB
ST380215A ATA Device 18.6 GB
Western Digital "My Book" external hard drive 750 GB
Fan based
Microsoft Comfort Curve Keyboard 2000 v10 USB
Logitec optic USB
3.01 Mb/s download 0.64 Mb/s upload
here is first ... but the second one i've couldn't run it ... it shows me An error occured while attempting to generate the report.
The system cannot find the path specified.
That's OK; this will work fine. I think the perfmon report may not have worked because you are using SP1. Thanks much. All of your dumps blame nvlddmkm.sys, nVidia Video driver. You have three different error codes. One of them is a video card error. Your video driver is out of date. Update this driver from the link provided.
nvlddmkm.sys Thu May 14 16:32:27 2009 - nVidia Video driver. Drivers - Download NVIDIA Drivers.
You also have another out of date driver. Update this driver also.
Rt86win7.sys Thu Feb 26 04:04:22 2009 - Realtek 8101E/8168/8169 NDIS 6.20 32-bit Driver. Latest PCIe GBE (GigaBit Ethernet) drivers here: Realtek.
Update these two drivers and see if helps your system. Post back and let us know.
Windows 7 Kernel Version 7601 (Service Pack 1.721) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17105.x86fre.win7sp1_rc.100929-1730
Machine Name:
Kernel base = 0x8281c000 PsLoadedModuleList = 0x82965850
Debug session time: Thu Dec 30 12:48:41.300 2010 (GMT-5)
System Uptime: 0 days 0:00:28.329
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {e, 2, 1, 8de99205}
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+85205 )
Followup: MachineOwner
kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000e, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 8de99205, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 82985718
Unable to read MiSystemVaType memory at 829651a0
 0000000e
CURRENT_IRQL:  2
FAULTING_IP:
nvlddmkm+85205
8de99205 6689500e        mov     word ptr [eax+0Eh],dx
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xD1
PROCESS_NAME:  dwm.exe
TRAP_FRAME:  8078ae2c -- (.trap 0xffffffff8078ae2c)
ErrCode = 00000002
eax=00000000 ebx=85956d28 ecx=85956d28 edx=00000000 esi=85956bc0 edi=00000000
eip=8de99205 esp=8078aea0 ebp=8078aeb4 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
nvlddmkm+0x85205:
8de99205 6689500e        mov     word ptr [eax+0Eh],dx    ds:0023:0000000e=????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 8de99205 to 8285321b
STACK_TEXT:
8078ae2c 8de99205 badb0d00 00000000 00000020 nt!KiTrap0E+0x2cf
WARNING: Stack unwind information not available. Following frames may be wrong.
8078aeb4 8de9c66e 850db000 850db000 850dfcb0 nvlddmkm+0x85205
8078aef8 8de6e117 850a6010 850db000 82948600 nvlddmkm+0x8866e
8078af10 8de1ec60 852969d8 8078af28 8dec0997 nvlddmkm+0x5a117
8078af1c 8dec0997 8de1ec2f 8078af48 8d6e4413 nvlddmkm+0xac60
8078af28 8d6e4413 850db000 85296d10 858dfb6c nvlddmkm+0xac997
8078af48 82891869 85296d10 85296920 00000000 dxgkrnl!DpiFdoDpcForIsr+0x28
8078afa4 828915ab 82946d20 858dfae8 00000000 nt!KiExecuteAllDpcs+0xf9
8078aff4 8288a89c 8a749980 00000000 00000000 nt!KiRetireDpcList+0xd5
8078aff8 8a749980 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2c
8288a89c 00000000 0000001a 00d6850f bb830000 0x8a749980
STACK_COMMAND:  kb
FOLLOWUP_IP:
nvlddmkm+85205
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nvlddmkm+85205
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a0c7fdb
FAILURE_BUCKET_ID:  0xD1_nvlddmkm+85205
Debug session time: Thu Dec 30 11:53:13.471 2010 (GMT-5)
System Uptime: 0 days 0:00:58.500
kd> !Analyze
BugCheck 116, {85d37008, 8dedda80, 0, 2}
Probably caused by : nvlddmkm.sys ( nvlddmkm+aca80 )
kd> !analyze -v
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: 85d37008, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: 8dedda80, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 00000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 00000002, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
nvlddmkm+aca80
8dedda80 55              push    ebp
DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
BUGCHECK_STR:  0x116
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
8a9edb74 8d2fbf3d 00000116 85d37008 8dedda80 nt!KeBugCheckEx+0x1e
8a9edb98 8d2eef76 8dedda80 00000000 00000002 dxgkrnl!TdrBugcheckOnTimeout+0x8d
8a9edbbc 8e79d92c 00000000 00000102 85c5f788 dxgkrnl!TdrIsRecoveryRequired+0xb8
8a9edc34 8e7c7a32 fffffcfb 00000d8c 00000000 dxgmms1!VidSchiReportHwHang+0x3c0
8a9edc5c 8e7c8153 00000000 00000000 00000000 dxgmms1!VidSchiCheckHwProgress+0x68
8a9edc98 8e7a48f0 8a9edc90 828b8ad3 85c5f788 dxgmms1!VidSchiWaitForSchedulerEvents+0x1b1
8a9edd28 8e7c94b7 85c5f788 828b8ad3 85c5f788 dxgmms1!VidSchiScheduleCommandToRun+0xaa
8a9edd3c 8e7c9573 85c5f788 00000000 85c63d48 dxgmms1!VidSchiRun_PriorityTable+0xf
8a9edd50 82aaee9d 85c5f788 9e9474ef 00000000 dxgmms1!VidSchiWorkerThread+0x7f
8a9edd90 828f9a99 8e7c94f4 85c5f788 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
nvlddmkm+aca80
SYMBOL_NAME:  nvlddmkm+aca80
FAILURE_BUCKET_ID:  0x116_IMAGE_nvlddmkm.sys
Debug session time: Thu Dec 30 11:54:40.905 2010 (GMT-5)
System Uptime: 0 days 0:00:50.934
kd> !Analyze
BugCheck 50, {89075a20, 0, 8e184b9d, 0}
Could not read faulting driver name
Probably caused by : nvlddmkm.sys ( nvlddmkm+34cb9d )
kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: 89075a20, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: 8e184b9d, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 00000000, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 829ad718
Unable to read MiSystemVaType memory at 8298d1a0
 89075a20
FAULTING_IP:
nvlddmkm+34cb9d
8e184b9d 8b1c9e          mov     ebx,dword ptr [esi+ebx*4]
MM_INTERNAL_CODE:  0
BUGCHECK_STR:  0x50
CURRENT_IRQL:  0
TRAP_FRAME:  8a9f880c -- (.trap 0xffffffff8a9f880c)
ErrCode = 00000000
eax=00000000 ebx=000ffe88 ecx=00000001 edx=00000000 esi=88c76000 edi=841be008
eip=8e184b9d esp=8a9f8880 ebp=8a9f8898 iopl=0         nv up ei pl nz na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010206
nvlddmkm+0x34cb9d:
8e184b9d 8b1c9e          mov     ebx,dword ptr [esi+ebx*4] ds:0023:89075a20=????????
LAST_CONTROL_TRANSFER:  from 8287b028 to 828bb379
STACK_TEXT:
8a9f87f4 8287b028 00000000 89075a20 00000000 nt!MmAccessFault+0x106
8a9f87f4 8e184b9d 00000000 89075a20 00000000 nt!KiTrap0E+0xdc
8a9f8898 8e1852a0 00000003 000ffe8a 841be008 nvlddmkm+0x34cb9d
8a9f8958 8e184061 841b36a0 000ffe8a 00000000 nvlddmkm+0x34d2a0
8a9f898c 8e17ee7f 00000000 841b5a10 85ba1008 nvlddmkm+0x34c061
8a9f89c4 8df68571 841be008 841b5a10 c1d00041 nvlddmkm+0x346e7f
8a9f89f0 8df68657 c1d00041 ff020000 85ba7170 nvlddmkm+0x130571
8a9f8a20 8df2d2ef c1d00041 ff1fe045 8501a008 nvlddmkm+0x130657
8a9f8a54 8df2d57a 85ba7148 c1d00041 ff1fe045 nvlddmkm+0xf52ef
8a9f8aa4 8dec458d 8a9f8ac4 850a8eec 8dec455d nvlddmkm+0xf557a
8a9f8ab8 8dec664f 8a9f8ac4 c1d00041 c1d00041 nvlddmkm+0x8c58d
8a9f8ad4 8de61700 c1d00041 ff1fe045 8a9f8b00 nvlddmkm+0x8e64f
8a9f8ae4 8de4c972 ff1fe045 850a4000 850a482c nvlddmkm+0x29700
8a9f8b00 8de4eff2 850a4810 850a4810 850a4000 nvlddmkm+0x14972
8a9f8b20 8decf91a 85b05000 850a4000 828126ee nvlddmkm+0x16ff2
8a9f8b38 8e311012 85b05000 85b05000 8a9f8b54 nvlddmkm+0x9791a
8a9f8b48 8e313327 8e310fe8 8a9f8b78 8d53f1b2 nvlddmkm+0x4d9012
8a9f8b54 8d53f1b2 850a4000 8607b2e8 85b05000 nvlddmkm+0x4db327
8a9f8b78 8d53f358 85ba8008 8607b2e8 00000000 dxgkrnl!DXGADAPTER::DdiResetFromTimeout+0x42
8a9f8ba0 8d53f00d 8607b2e8 8607b2e8 82e2207e dxgkrnl!DXGADAPTER::PrepareToReset+0xdb
8a9f8bbc 8e7a492c 00000000 00000102 85ba8008 dxgkrnl!TdrIsRecoveryRequired+0x14e
8a9f8c34 8e7cea32 fffffcfb 00000bc7 00000000 dxgmms1!VidSchiReportHwHang+0x3c0
8a9f8c5c 8e7cf153 00000000 00000000 00000000 dxgmms1!VidSchiCheckHwProgress+0x68
8a9f8c98 8e7ab8f0 8a9f8c90 85be9d08 85be73c8 dxgmms1!VidSchiWaitForSchedulerEvents+0x1b1
8a9f8d28 8e7d04b7 85ba8008 828b8ad3 85ba8008 dxgmms1!VidSchiScheduleCommandToRun+0xaa
8a9f8d3c 8e7d0573 85ba8008 00000000 85bb6948 dxgmms1!VidSchiRun_PriorityTable+0xf
8a9f8d50 82aaee9d 85ba8008 9d6ba601 00000000 dxgmms1!VidSchiWorkerThread+0x7f
8a9f8d90 828f9a99 8e7d04f4 85ba8008 00000000 nt!PspSystemThreadStartup+0x9e
STACK_COMMAND:  kb
FOLLOWUP_IP:
nvlddmkm+34cb9d
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nvlddmkm+34cb9d
FAILURE_BUCKET_ID:  0x50_nvlddmkm+34cb9d
kd> lmtsmn
start    end        module name
86a9b000 86ae3000   ACPI     ACPI.sys     Thu Sep 30 00:36:08 2010 (4CA413B8)
8d254000 8d2ae000   afd      afd.sys      Thu Sep 30 00:37:02 2010 (4CA413EE)
8d3e5000 8d3f7000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
86bec000 86bf5000   amdxata  amdxata.sys  Fri Mar 19 12:19:01 2010 (4BA3A3F5)
86bc0000 86bc9000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
86bc9000 86bec000   ataport  ataport.SYS  Thu Sep 30 00:36:13 2010 (4CA413BD)
86fef000 86ff6000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8d47e000 8d48c000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
82eca000 82ed2000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
912f1000 9130a000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
91090000 910ae000   cdd      cdd.dll      unavailable (00000000)
86e00000 86e1f000   cdrom    cdrom.sys    Thu Sep 30 00:36:18 2010 (4CA413C2)
82f14000 82fbf000   CI       CI.dll       Thu Sep 30 02:36:07 2010 (4CA42FD7)
86f9a000 86fbf000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
82ed2000 82f14000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
86d99000 86df6000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
8d3d8000 8d3e5000   CompositeBus CompositeBus.sys Thu Sep 30 01:09:21 2010 (4CA41B81)
8b9e7000 8b9f4000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
8d402000 8d466000   csc      csc.sys      Thu Sep 30 00:39:12 2010 (4CA41470)
8d466000 8d47e000   dfsc     dfsc.sys     Thu Sep 30 00:38:36 2010 (4CA4144C)
8d3a7000 8d3b3000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
87008000 87019000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
8b9ce000 8b9e7000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
8b800000 8b809000   dump_atapi dump_atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
8b9f4000 8b9ff000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
8b809000 8b81a000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
86fd6000 86fe0000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
8d4bf000 8d576000   dxgkrnl  dxgkrnl.sys  Thu Sep 30 00:51:24 2010 (4CA4174C)
8e79e000 8e7d7000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
8d5d0000 8d5db000   fdc      fdc.sys      Mon Jul 13 19:45:45 2009 (4A5BC729)
86a00000 86a11000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
8b934000 8b93e000   flpydisk flpydisk.sys Mon Jul 13 19:45:45 2009 (4A5BC729)
82fbf000 82ff3000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
86c0e000 86c17000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
86f68000 86f9a000   fvevol   fvevol.sys   Thu Sep 30 00:37:17 2010 (4CA413FD)
8716c000 8719d000   fwpkclnt fwpkclnt.sys Thu Sep 30 00:36:41 2010 (4CA413D9)
8280d000 82844000   hal      halmacpi.dll Thu Sep 30 00:36:00 2010 (4CA413B0)
8e7d7000 8e7f6000   HDAudBus HDAudBus.sys Thu Sep 30 01:14:07 2010 (4CA41C9F)
8b94f000 8b99f000   HdAudio  HdAudio.sys  Thu Sep 30 01:14:38 2010 (4CA41CBE)
8b825000 8b838000   HIDCLASS HIDCLASS.SYS Thu Sep 30 01:14:12 2010 (4CA41CA4)
8de30000 8de36480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
8b81a000 8b825000   hidusb   hidusb.sys   Thu Sep 30 01:14:12 2010 (4CA41CA4)
9126c000 912f1000   HTTP     HTTP.sys     Thu Sep 30 00:37:15 2010 (4CA413FB)
87000000 87008000   hwpolicy hwpolicy.sys Thu Sep 30 00:35:59 2010 (4CA413AF)
8d3b3000 8d3cb000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
86b95000 86b9c000   intelide intelide.sys Mon Jul 13 19:11:19 2009 (4A5BBF17)
8d4ad000 8d4bf000   intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
8d3cb000 8d3d8000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
80bce000 80bd6000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
8b8ae000 8b8e2000   ks       ks.sys       Thu Sep 30 01:09:10 2010 (4CA41B76)
86d86000 86d99000   ksecdd   ksecdd.sys   Thu Sep 30 00:36:35 2010 (4CA413D3)
86f16000 86f3b000   ksecpkg  ksecpkg.sys  Mon Jul 13 19:34:00 2009 (4A5BC468)
91249000 91259000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
9122e000 91249000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
82e34000 82eb9000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Thu Sep 30 02:32:12 2010 (4CA42EEC)
91223000 9122e000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
8d5f3000 8d600000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
86baa000 86bc0000   mountmgr mountmgr.sys Thu Sep 30 00:36:18 2010 (4CA413C2)
9130a000 9131c000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
9131c000 9133f000   mrxsmb   mrxsmb.sys   Thu Sep 30 00:38:50 2010 (4CA4145A)
9133f000 9137a000   mrxsmb10 mrxsmb10.sys Thu Sep 30 00:39:00 2010 (4CA41464)
9137a000 91395000   mrxsmb20 mrxsmb20.sys Thu Sep 30 00:38:56 2010 (4CA41460)
86a11000 86a1c000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
86aec000 86af4000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
86d5b000 86d86000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
8d39d000 8d3a7000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
871ed000 871fd000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
86e21000 86ed8000   ndis     ndis.sys     Thu Sep 30 00:36:58 2010 (4CA413EA)
8d218000 8d223000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
8b83a000 8b85c000   ndiswan  ndiswan.sys  Thu Sep 30 01:17:45 2010 (4CA41D79)
8b93e000 8b94f000   NDProxy  NDProxy.SYS  Thu Sep 30 01:17:36 2010 (4CA41D70)
8d306000 8d314000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
8d2ae000 8d2e0000   netbt    netbt.sys    Thu Sep 30 00:36:51 2010 (4CA413E3)
86ed8000 86f16000   NETIO    NETIO.SYS    Thu Sep 30 00:37:12 2010 (4CA413F8)
8d223000 8d231000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
8d393000 8d39d000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
82844000 82c55000   nt       ntkrpamp.exe Thu Sep 30 00:40:18 2010 (4CA414B2)
86c2c000 86d5b000   Ntfs     Ntfs.sys     Thu Sep 30 00:36:46 2010 (4CA413DE)
86fe8000 86fef000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
8de38000 8e79d940   nvlddmkm nvlddmkm.sys Thu May 14 16:32:27 2009 (4A0C7FDB)
8d2e7000 8d306000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
8d5db000 8d5f3000   parport  parport.sys  Mon Jul 13 19:45:34 2009 (4A5BC71E)
86b29000 86b3a000   partmgr  partmgr.sys  Thu Sep 30 00:36:21 2010 (4CA413C5)
91395000 9139c000   parvdm   parvdm.sys   Mon Jul 13 19:45:29 2009 (4A5BC719)
86af4000 86b1e000   pci      pci.sys      Thu Sep 30 00:36:10 2010 (4CA413BA)
86b9c000 86baa000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
86c00000 86c0e000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
92025000 920bc000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
8b99f000 8b9ce000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
82eb9000 82eca000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
8d200000 8d218000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
8b85c000 8b874000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
8b874000 8b88b000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
8b88b000 8b8a2000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
8d352000 8d393000   rdbss    rdbss.sys    Thu Sep 30 00:38:56 2010 (4CA41460)
8b8a2000 8b8ac000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
86ff6000 86ffe000   RDPCDD   RDPCDD.sys   Thu Sep 30 01:24:47 2010 (4CA41F1F)
86c23000 86c2b000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
86df6000 86dfe000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
86f3b000 86f68000   rdyboost rdyboost.sys Thu Sep 30 00:46:28 2010 (4CA41624)
91259000 9126c000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
8de00000 8de25000   Rt86win7 Rt86win7.sys Thu Feb 26 04:04:22 2009 (49A65B16)
920bc000 920c6000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
8e7f6000 8e800000   serenum  serenum.sys  Mon Jul 13 19:45:27 2009 (4A5BC717)
8d314000 8d32e000   serial   serial.sys   Mon Jul 13 19:45:33 2009 (4A5BC71D)
871e5000 871ed000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
92143000 92194000   srv      srv.sys      Thu Sep 30 00:39:26 2010 (4CA4147E)
920f4000 92143000   srv2     srv2.sys     Thu Sep 30 00:39:07 2010 (4CA4146B)
920c6000 920e7000   srvnet   srvnet.sys   Thu Sep 30 00:39:02 2010 (4CA41466)
8b8ac000 8b8ad380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
87022000 8716c000   tcpip    tcpip.sys    Thu Sep 30 00:38:05 2010 (4CA4142D)
920e7000 920f4000   tcpipreg tcpipreg.sys Thu Sep 30 01:17:23 2010 (4CA41D63)
8d248000 8d254000   TDI      TDI.SYS      Thu Sep 30 00:36:46 2010 (4CA413DE)
8d231000 8d248000   tdx      tdx.sys      Thu Sep 30 00:36:42 2010 (4CA413DA)
8d341000 8d352000   termdd   termdd.sys   Thu Sep 30 01:24:07 2010 (4CA41EF7)
91060000 91069000   TSDDD    TSDDD.dll    unavailable (00000000)
8d48c000 8d4ad000   tunnel   tunnel.sys   Thu Sep 30 01:17:16 2010 (4CA41D5C)
8b8e2000 8b8f0000   umbus    umbus.sys    Thu Sep 30 01:14:37 2010 (4CA41CBD)
9120f000 91222b00   usbaudio usbaudio.sys Thu Sep 30 01:14:21 2010 (4CA41CAD)
86fbf000 86fd6000   usbccgp  usbccgp.sys  Thu Sep 30 01:14:25 2010 (4CA41CB1)
8b838000 8b839700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
8d5c1000 8d5d0000   usbehci  usbehci.sys  Thu Sep 30 01:14:20 2010 (4CA41CAC)
8b8f0000 8b934000   usbhub   usbhub.sys   Thu Sep 30 01:14:43 2010 (4CA41CC3)
8d576000 8d5c1000   USBPORT  USBPORT.SYS  Thu Sep 30 01:14:28 2010 (4CA41CB4)
8de25000 8de30000   usbuhci  usbuhci.sys  Mon Jul 13 19:51:10 2009 (4A5BC86E)
86b1e000 86b29000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
86c17000 86c23000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
82e00000 82e21000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8719d000 871a5380   vmstorfl vmstorfl.sys Thu Sep 30 00:54:29 2010 (4CA41805)
86b3a000 86b4a000   volmgr   volmgr.sys   Thu Sep 30 00:36:16 2010 (4CA413C0)
86b4a000 86b95000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
871a6000 871e5000   volsnap  volsnap.sys  Thu Sep 30 00:36:20 2010 (4CA413C4)
8d32e000 8d341000   wanarp   wanarp.sys   Thu Sep 30 01:17:43 2010 (4CA41D77)
82e21000 82e2e000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
86a1c000 86a8d000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
86a8d000 86a9b000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8d2e0000 8d2e7000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
90e00000 9104c000   win32k   win32k.sys   unavailable (00000000)
86ae3000 86aec000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
Unloaded modules:
86fbf000 86fcc000   crashdmp.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
86fcc000 86fd7000   dump_ataport
    Checksum:  00000000
87019000 87022000   dump_atapi.s
    Checksum:  00000000
86fd7000 86fe8000   dump_dumpfve
    Checksum:  00000000
Home built
2.50 GB RAM
1680 X 1050
Fan based
Logitec optic USB
thanks , after updating my ethernet driver my pc works good...i have been working for 4 hours without a crash :))
You are welcome. That is great news. Update us again in a couple of days. If you are still BSOD free, we will ask the moderators to mark this thread as solved.
Home built
2.50 GB RAM
1680 X 1050
Fan based
Logitec optic USB
it is still showing but now much less times ... since that it showed me blue screen two times , first time was Attempt to reset the display driver and recover from timeout failed and second time was memory_managment error..what does it mean ???
