Creative SB Audigy SE sound problem
dmy
7:04 AM
Hi, I had a problem with my old sound card. It was not working at all. So i bought a new one Creative SB Audigy SE installed the drivers and everything that was given with the sound card and the sound is really weak. I have all the volume up to 100% everywhere and it''s playing music like it is 50% or less. When I put my headphones on my phone the sound is louder 2 times or more. What could be the problem?
windows 7 ultimate 32bit
What was the old sound? Built in (on the motherboard)? or a separate sound card? If it was the built in sound, disable it in the BIOS so it does not potentially interfere.
Also did you move the front panel headphone/mic jacks to the new Audigy SE sound card? If not, you are hearing the old PC's sound card sound in the hadphones.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I think it was built in on the motherboard.
I plug in my headphones directly to the new sound card from the back of the computer.
I just disable the built-in sound card it is called "azalia codec". The sound is the same.
Did you disable it in the BIOS or the Device Manager? Best to do it in the BIOS.
Since you are plugging into the rear jack and its apparently loud with the headset, there must be a problem with the speakers?
Plug the speakers back into the GREEN speaker jack. Then go to the Control Panel/Hardware and Sound and finally the Sound Panel. Your "Speakers" (the Audigy) should be set as the default playback device. Click on the Icon for the speakers to highlight it and then click the Configure button. Make sure you have the correct speaker type set and then you can test the speakers in the Configuration panel. See how that works out.
If its still low, power off the PC, open the case and reseat the SoundBlaster card (unplug then plug back in, making sure its fully and correctly seated). Then try again.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Yes i disable it from the BIOS.
You didin''t understand. When my headphones are plugged in the computer the sound is weak and when i plug the same headphones to my telephone the sound is like 2 or 3 times better.
I don''t have any speakers only headphones. But I did the thing you told me in the sound panel. Nothing helped.
The card is seated properly, I checked it 2 times.
What headphones do you have? If you have iPhone headphones, some of these do not work or work properly on a PC.
Here is the connection diagram of the SE. Make sure you are connecting to the GREEN (#2) jack.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Im using acme headphones. They were playing loud with my old sound card until it stopped working.
Yes my headhpones are connected to the green jack.
Could it just be that this is a lame sound card and it is giving maximum sound?
Sadly it does sound like a defective card. Can you return it for replacement, either where you bought it or under warranty with Creative. I used an Audigy SE for a long time on an old Dell, first with XP and then with Vista 32 bit.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Ill try to return it. Thanks for your help.
It may not be the problem, but its the prime suspect.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Yes, it could be something else, but I still got warranty for the sound card so it''s worth to try.
Hi! I just wonder where can I connect the PC tower front jacks. Because I have to reach the back of the PC each time I have need to switch between headphones and stereo speakers. Please help! Cheers in advance, Miguel.
CB
Windows 10 X64
AMD
ASUS
DDR3
GForce
