Display Settings and Power Consumption Question!
boogieboy
Mmmmeeeh!
4:27 PM
Lahore, Pakistan
Hello all :)
I have 2 Samsung Displays in my room. 1 that is connected with my PC is a Samsung LCD Monitor that has native 1440x900 (16:10) resolution and the 2nd one is a new Samsung LED Monitor that has a native 1600x900 (16:9) resolution that is just connected with my PS3 which I hardly use.
Now as I have noticed the power consumption of my LCD is 34watts typical and LED is 14watts typical (on official specs on the website). I have a small factor UPS connected to my PC as we have frequent power outages/black outs in our country and I was wonder if I swap both displays and connect the LED with my PC it will save at approx. 20watts straight according to the official specs also not that the LED comes with a 12v adapter. So will it help?
Also if I swap display will it shuffle my desktop settings as in icons, gadgets etc.? :D just asking out of curiosity as I have some custom settings on the desktop which I don't want to mess around with for a time being :eek:
Windows 10 Pro
Core i5 9600K
ASUS ROG Strix Z390-F Gaming
Corsair Vengeance Pro 2x 8GB (16GB) 3200MHz DDR4
MSI GTX 1070 Gaming X 8GB
ASRock A-Style Purity Sound
ASUS VX239H IPS
XPG SPECTRIX S40G 2566GB M.2 NVMe | Patriot P210 512GB SSD | Seagate BarraCuda 4TB 5400RPM
Thermaltake Smart 600w RGB 80Plus
NZXT H500 with 3x Corsair HD120 RGB w/Node Pro
Cryorig H7
Corsair K70 RapidFire RGB (Cherry MX Speed)
Logitech G402 Hyperion Fury
20MB Cable Broadband
Corsair MM300 Extended Anti-Fray Mouse Pad | Edifier C2 2.1ch Sound System | XBOX One S Controller | XBOX 360 Wireless Controller for Windows | APC SUA1000i Smart-UPS | PS4 Slim 500GB [Region 1 - USA]
Ok BB mate I think as long as the machine's hardware supports the LED monitor / screen then there should not be an issue. Now that does seem like a fairly low res for monitors these days - any reason??
I don't see why the icons should be shuffled around either because the machine is generating them not the monitor that is receiving the signal.
Now you mention the LED does not come with a 12v adaptor and I ma wondering why that should be an issue as long as it is powered from somewhere it should have no relevance to it operating normally.
It is good though that you save on the power and I guess you know already but it is due to the use of LED's to light the screen as opposed to a fluorescent tube/s. Again you probably know already that the current draw of an LED is typically very small compared to other forms of lighting.
This very simplistic but to the point Difference Between LED & LCD | eHow
1920x1080 D1 & D2 & Laptop 1
Desk1 Samsung 120GB 830 SSD
Asus ROG 256GB 850 Pro SSD
Desk2 Samsung 840 256 SSD
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Thanks for replying ICit2lol :)
The LED does come with a 12v adapter :) i mistakenly wrote "not" instead of "Note".
My mai concern with the desktop settings related with default positions of applications as i like to see everything right in the middle of screen for instance when i open Steam or WMP they are perfectly aligned to center of the screen so i was wondering if icons shuffle so will it change the center window settings for several other apps too? I have many apps which are open centered by default.
Windows 10 Pro
Core i5 9600K
ASUS VX239H IPS
Cryorig H7
Well I don't see why you cannot set it as the default and that should by logic coming from the machine unless I am hopelessly wrong. I say that because any graphics have to be driven by the graphics chip or card whichever one has and that is driven by the OS. But I stand to be corrected but it makes sense to me:)
For example the taskbar is set at the bottom by default and one has to change the settings to get it in different spots and that is an Windows OS feature :)
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
So will it help?
Will it help what? Save in energy costs? Yes, a little. But hitting the monitor's power switch to turn it completely off (instead of just sleep/standby mode) will help save more.
As for your icons, they WILL move when changing resolutions. But they should not "shuffle" around. That is, they may move out further or closer to the center. But that will be a one time thing - unless you keep swapping monitors.
BrightWorks Systems B4
Windows 7 Profession 64-bit
Intel Core i7-860 Quad
Gigabyte P55-UD4P
Mushkin 4x2Gb PC12800
Gigabyte GTX260 896Mb
Integrated 7.1 HD Dolby
2 Samsung 2220wm-HAS 22"
1680 x 1050 | 1680 x 1050
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless Comfort 5000
MS Wireless 5000
Cable and pretty darn fast
So will it help?
Yes Itaregid that is a fair comment re resolution and I know what you mean but the OP was only asking a simple question and what he does with his equipment is not really the issue.
Me personally shut my machines down after each use as I am not a fan of leaving them on 24/7 like some. I think that practice is wasteful and highly susceptible to damage from heat or power supply brown outs or surges even with surge protection in place.
But once again what you have posted is a valid point on the res and swapping monitors around.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Huh? What he does with his equipment??? I don't know what you are talking about.
He clearly is asking about power consumption AND resolution settings - as both the topic title and post content illustrate.
So the issue is clearly about power consumption and about saving energy with his equipment. So it IS all about what he does with his equipment.
Gigabyte P55-UD4P
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless 5000
