Electric current felt over PC case - Need help
stuckkie
3:38 PM
I moved recently to a new place, and hooked up my desktop PC. However, for some reason, there now seems to be a faint electric current running over my PC case. If I press my finger against the metal case, I can feel a tingling sensation which becomes painful if I hold my finger against it for too long. I've never had this problem before.
I tried Googling my problem, and only found this thread: [Solved] Electric current felt all over the case - Power-Supplies-PC-Cases-Case-Mods - CPU-Components
I seem to be having the same problem as him. I also have the same case (Cooler Master nVidia edition chassis).
Does this have something to do with my case not being properly "grounded"? I'd like someone to explain what that means, and how I can fix this. Thanks.
Are power plug and power outlet both grounded?! Also extension cord if attached?
Microsoft Windows 7 Home Premium 64-bits 7601...Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHz4,00 GBATI Mobility Radeon HD 5400 Series
ACER ASPIRE 5742G
Acer Aspire 5742G
4,00 GB
WDC WD5000BEVT-22ZAT0
Do you only get this when your PC is running? Do you still get it if your PC is merely plugged into the mains, but without the socket being switched on? Do you get the same effect from any other appliances that you can try in the same socket (e.g. a toaster or kettle)?
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
The same electric current happens whether the PC is running or turned off, as long as it's plugged into the socket.
No, there is no current if it's plugged in with the socket switch off.
I tried connecting a TV to the socket, and it ran normally (I tried feeling the metal connectors on the back of the TV, no current).
Something is leaking current to computer case and case isn't grounded!
ACER ASPIRE 5742G
Acer Aspire 5742G
4,00 GB
Ok, but what does that mean? How do I "ground" the case? And how do I find out what is leaking?
In the picture of the electrical plug you can see 2 prongs and then a hole. That hole should be a third prong - which is the ground line. Does your plug have a ground prong? Does the wall outlet?
Home Built - Jan 2013
i7-3820
Asus P9X79-PRO - Bios 4608
GSkill F3-14900CL9Q - 16GB
On board Realtek ALC898
Acer S271HL
#1- Samsung 840 Pro Series
Corsair Obsidian 550D
MS KC-0405
Intellimouse 5-button
56 Mbits/Sec (on a good day)
Avast & Malwarebytes
Asus DVD - DRW-24B1ST 24X
In a normal PC setup all of the grounding goes to and through the power supply. The power supply is then connected to the building's ground wiring through the ground plug in the wall socket.
Some cases add a separate ground wire (Antec is one) to ground the case. Usually from the front panel connections to the normal grounding path. This separate ground is forward thinking to avoid any static electric charge from running through the motherboard.
If you have this separate case ground wire, but the power supply does not have a path (through the power cord) to the building ground, then the power supply could be grounding to the case, explaining the charge you can feel.
That said it is still not normal for a constant electric charge to be running to ground. This usually indicates a short circuit in a DC system or an "open neutral" in an AC system.
i7-3820
Acer S271HL
MS KC-0405
This is what the cable is connected to at the wall socket: Laptop Supermarket - Brighton Euro to uk plug / power adapter Computer accessories, peripherals, lowest prices
This is what the wall socket looks like: wall outlet socket , Manufacturers from Casenl Electrical Co., Ltd.
That indicates a fault with the socket. Can you test for the same symptoms on another socket in a different room?
Regards,
Golden
Golden Mk. I.4
EVGA NVidia GTX 560 1024MB
Realtek Integrated
1920*1080 and 1920*1080
1*Samsung 840 EVO 120GB SSD;
1*OCZ Vertex 2 60GB SSD;
1*Samsung F1 SpinPoint 1TB;
Logitech G110
Logitech MX518
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
When you moved, was it a Country type change, or just local where they use the same electrical system?
Windows 7 x64i7-2600K8 GGTX 480
Homebuilt
Windows 7 x64
i7-2600K
Asus P8Z77-v Pro
8 G
GTX 480
Onboard
LG W2753V
Crucial M4 128 G SSD
Regards,
Golden
I tested it in other rooms sockets, same problem. None of the other electrical items in my home have the same problem, even when plugged into the same sockets.
There have been several incidents with some Cooler Master cases where the front panel connectors are shorted out leading to static electricity grounding to the case. The symptoms are different than yours, but could be caused by the same issue. http://www.sevenforums.com/overclocking-case-mods/128058-haf-x-short-static-front-usb-panel.html
Thanks for the link. How can I check mine is effected by this?
Update: I jist tried disconnecting the top I/O panel, but the problem was still there.
I think at this point, we are all guessing. But, I would start looking inside the case for a bad connection, a frayed wire touching the case or a standoff that is in a place it shouldn't be or one that is loose. Due to the fact it started after a move, it sounds like there is some difference in the wiring in the new house or something shorted out on the computer during the move.
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
