PC case upgrade gone wrong, need help. Hardware/software problem.
ok this might sound stupid, check your motherboard standoffs, if one is not correctly in place it could be shorting the board.
For me, mine would boot up for 20secs or sometimes 2 mins before loosing power shutting off, after a day or so off messing about trying to find the solution it came to me when unplugged the whole lot.
I could see one standoff not screwed in properly, as soon as i did, everything was working fine...
Define properly. In my old case I lost some screws and mobo was being held with just 3 not best screwed ones. Now it's 6 from the new case package. Checked. :cry:
Intel 2600K Sandy Bridge
Asus P8P67 EVO B3
Kingston KVR1333D3N9K2/4G two kits of two 2GB sticks.
Palit 680 Jetstream 4gb version
Acer GD245HQ
2x Seagate Barracuda ST1000DM003
Cooling Master GX 550w
Corsair 650D
Cooler Master Hyper 212 on CPU, other stock
Update 2: Tried using SeaTools for Windows by Seagate, their diagnostic utility. Tried short Generic test, it passed. Short drive self test (DST) failed. Both passed on my newer 1TB drive I just bought for storage. Should I take more tests or just try to fix it with the utility? Or just screw it and get a new drive instead of this one? I really don't want to do that.
Download the Dos test - burn to cd - this is a very comprehensive test.
Run the LONG test.
SeaTools | Seagate
Self-Built
Windows 7 Professional X64
Core i7 (2nd gen) i7-2600K / 3.40GHz
ASUS P8Z77-V Intel 7 Series Motherboard
DDR3 2400MHz (OC) 16gb
Intel(R) HD Graphics 3000, -1988 Mb
8 ChannelsAudio Chipset Realtek ALC892
LG 29UM65 Black 29"
2560 x 1080
840 EVO 250 GB SSD ;2tb (2);Seagate;1tb Seagate; 750 gb Seagate; wd ext (2) 750 gb,WD 2tb X 2;WD 3TB Black
750 watt
Thermaltake RX -1
2120mm Fans Included 1Other Fan Ports 5x 200mm Fan Ports
Microsoft Digital Media Pro
Microsoft Wireless 6000
U-verse 18 mbps
Firefox, Chrome and my favorite: Pale Moon
HdHomerun Dual Tuner.
SRS Audio Lab,
Pioneer BDR 208-DBK
PS3-What a difference in my Surround Sound Receiver!
HP 4540s - My new Toy.
Epson R280 Printer- To personalize my Dvds.
Canon MP 560 - For scanning.
Run the LONG test.
SeaTools | Seagate
A bit late for that, I'm in Germany atm, aka not at home. Decided to get a new Windows install and new HDD anyway, just in case it all gets fixed 100%.
I still want to know what that Windows backup thing does. Do I get a full copy of my HDD, meaning I can copy it to another HDD and then just remove this one booting from the new one?
Asus P8P67 EVO B3
Acer GD245HQ
Corsair 650D
Most think Windows backup is not the most refined tool of its type---it's not particularly flexible and has some peculiarities compared to competing applications.
It creates an image file that can later be restored to another drive---not to be confused with copied to another drive.
It usually works. Sometimes it doesn't.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
The best program to use for backup is Macrium Reflect FREE Edition - Information and download It is free and does a very good job. It will automatically make a backup to another drive. If your OS should become corrupt, you can just restore, which takes a short time and you are good to go again.
Intel Core i3-2120 3.30Ghz
Kingston 4 GB DDR3 1333 mhz
AMD Radeon HD6670
Asus VE228
1440 X 900
Corsair CX600M == 600 Watt
Three 120 mm Fans
Microsoft Natural 4000
Microsoft Custom Optical 3000
Main question is, will it also copy all data besides Windows? If not I might as well copy it all myself and just do a clean install, doesn't take that long anyway.:sarc:
Asus P8P67 EVO B3
Acer GD245HQ
Corsair 650D
It will include everything in the partition, regardless of what it is. You can image one or more partitions, separately or in one single image.
Since imaging programs aren't foolproof, they are a poor way to backup personal data.
1600 x 900
Antec Solo II
Pale Moon
I'm still a bit confused, image? Isn't it supposed to be burnt on DVD or something? What I mean is is there a way to simply insert another 1TB HDD and clone my main one (has just one partition) there, then boot from it and have it all working? Or will it be easier to just copy all the files and clean install?
Asus P8P67 EVO B3
Acer GD245HQ
Corsair 650D
Images are typically about half the size of the occupied space on a partition and thus would not fit on a single DVD.
You can use multiple DVDs to hold images, but they are much more problematic than hard drives for restoration purposes. Highly not recommended.
Cloning and imaging are 2 different things. Macrium can do both.
Cloning and imaging can both fail. It's up to you to make a wild ass guess as to whether you want to bother with it. Success rate?? Probably above 90%, plus whatever time you have to spend figuring out how to do it.
If in doubt, do a clean.
Clean is more reliable.
The only reason to do cloning or imaging is that they might save you some time--by avoiding the time to configure a clean install. But they don't always work. Take your pick.
1600 x 900
Antec Solo II
Pale Moon
Run the LONG test.
SeaTools | Seagate
I use the Acronis Discwizard ( link I sent you).
It is fast and accurate.
It will backup your OS and settings and you can restore it and have everything you had before.
Burn the DOS test to a cd and in the future you can check the health of your hdds.
Self-Built
LG 29UM65 Black 29"
2560 x 1080
750 watt
Thermaltake RX -1
U-verse 18 mbps
SRS Audio Lab,
Pioneer BDR 208-DBK
Run the LONG test.
SeaTools | Seagate
I use the Acronis Discwizard ( link I gave you).
It is fast and will backup the drive and allow you to restore your system in case of a failure or corruption.
Self-Built
LG 29UM65 Black 29"
2560 x 1080
750 watt
Thermaltake RX -1
U-verse 18 mbps
SRS Audio Lab,
Pioneer BDR 208-DBK
Well, clean install is no problem so I guess I'll just do that. Buy another HDD and copy data there, then return mine and get another like that, will even have a new HDD after all this. At least something positive I guess.
Asus P8P67 EVO B3
Acer GD245HQ
Corsair 650D
Alright, came back home yesterday, did a clean install today. New HDD, new Windows, it seems to be working for now at least. I only got this question, how do I change system language? I have my old German install disk and while I change most of the text using the language pack, I remember having trouble changing ALL of it. For example, Windows Update section is still all German, and I can't delete it from packs because it says "system language". I totally got rid of it before though, but now can't seem to find a solution on Google for some reason. Anyone knows a way?
Update: Solved itself. Language simply changed to English after yet another update-reboot. All working fine now, so I'm guessing it really was the HDD. Thanks for the help to everyone!
Asus P8P67 EVO B3
Acer GD245HQ
Corsair 650D
