Solved EVGA GTX 780 SC TI Low Fps and Fps drops after system reinstall.
johnkuang123
4:21 PM
So I have run into a problem with the EVGA GTX 780 TI SC, Im getting constant fps drops after I have reinstall my system, before the reinstall, I maintain 100+ fps in BF4 no problem but after the reinstall, my frame have been droping really low, I would get around 40~60 fps at Siege of shanghai map ground level(with lots of action)when i used to get 70~80 and I get 60~90 fps on high elevation(less stuff to process) which I used to get 100~130 fps. My driver is the newest, CPU and ram is overclocked to the same speed as before I reinstalled. I need some help here, I don't know why my fps is droping so low like that.
Windows 7 Ultimate.FX-8350 overlocked to 4.5 Ghz.EVGA GTX 780 TI ACX SC
Windows 7 Ultimate.
Sabertooth 990Fx
23.5 Inch 1920X1080p
1920X1080p
1000W gold.
Antec 85.
johnkuang123, try some other games and see if they are having that too. BF4 is notorious for issues. They do have a big patch coming soon that may help you.
Windows 10 Pro X64Intel(R) Core(TM) i5-3570K CPU OC@ 4.5GHZ Turbo8.00 GB DDR3 1600MhzMSI Gaming X GTX 1070
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Realtek High Definition
Dell S23O9W, HP L1710
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
MSI DS100 Interceptor
50 down and 5 up
Chrome, IE 11
Logitech X-620 Speakers
i have tested more maps, As what Im seeing now, every single map laggggg.
Windows 7 Ultimate.
Sabertooth 990Fx
1920X1080p
1000W gold.
Antec 85.
Every map im getting 40~60 fps, that is not normal with my setup...
Windows 7 Ultimate.
Sabertooth 990Fx
1920X1080p
1000W gold.
Antec 85.
No it's not normal but I believe it is the game and not your hardware. Try testing another game.
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
50 down and 5 up
Chrome, IE 11
Yeah I tested other games, its running very smooth like Cs.GO, highest setting im running at 300~400 Fps.
Windows 7 Ultimate.
Sabertooth 990Fx
1920X1080p
1000W gold.
Antec 85.
Yeah, it's BF4. I hope the new patch fixes it.
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
50 down and 5 up
Chrome, IE 11
But how comes I get like 100+ fps on September/20/2014, thats only 8 days ago... Do you think its because Im missing drivers like VC++, Direct X and ect? Cause its a new install so I might have miss some of those driver.
Windows 7 Ultimate.
Sabertooth 990Fx
1920X1080p
1000W gold.
Antec 85.
You could give it a try.
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
50 down and 5 up
Chrome, IE 11
Windows 7 Ultimate.
Sabertooth 990Fx
1920X1080p
1000W gold.
Antec 85.
That's a good score, nothing wrong with you gpu
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
50 down and 5 up
Chrome, IE 11
Yeah Im very happy with the fact that is not cause of a faulty card, I will see how the patch helps then we will go on further as I might need more help.
Windows 7 Ultimate.
Sabertooth 990Fx
1920X1080p
1000W gold.
Antec 85.
Well just tested out the BF4 update, it seem like it didin't help at all...
But I did find out that older version of Nividia Drive have improved the performance, but creates lots of problem for my game.
Windows 7 Ultimate.
Sabertooth 990Fx
1920X1080p
1000W gold.
Antec 85.
I haven't played BF4 in a while but the latest driver is good
I been playing Max Payne 3 again and pretty much flawless gameplay
Enthod Pro Full Tower
Logitech wireless keyboard
Logitech wireless mouse
Cox Cable 100+ mb
IE-10, Chrome, Opera
GPU GTX Gigabyte 970G1
Im just getting low performance :( I dont know how to fix it though...
Windows 7 Ultimate.
Sabertooth 990Fx
1920X1080p
1000W gold.
Antec 85.
