factory sound card VS SoundBlaster USB sound card
carputer93
Power User
10:16 PM
san diego
windows 7Intel Atom 1.66GHZ Dual Core1gINTEL GMA 3150
windows 7
1g
INTEL GMA 3150
iMo Pivot 7" touch
SATA 2.5' 250g Samsung Hard Drive
touch screen
touch screen
300 mbps wifi
As you have a USB connected SoundBlaster, disable the internal sound "card" in the BIOS and then connect and install the SoundBlaster and try it.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Depends on your needs. If you want good sound quality - USB Soundblaster will be much better choice of course.
Win7
Win7
Well the reasoning is I have my PC connected to a 4 channel amp and usually after a hour of continued play my PC stops playing audio but wmp is still playing and I'm thinking if I add the sound blaster it might stop that from happening
windows 7
1g
INTEL GMA 3150
iMo Pivot 7" touch
touch screen
touch screen
300 mbps wifi
Possibly. May be some other issue, but if the SoundBlaster does not cut out then that proves its a problem with the internal sound chip. However, if the SoundBlaster also cuts out, its back to the "drawing board" as its a PC problem (hardware or software).
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Yes true the think is it will cut out I will close WMP open it back up again and it works ....the reason I asking rather than just plugging it up it. Is that the PC is installed under the dashboard and I have to get another screen (I already ) have because my main screen is a USB driven touch screen.I just wanted a would Anwser or personal reviews on what people think about the sound blaster before I take the car apart again
windows 7
1g
INTEL GMA 3150
iMo Pivot 7" touch
touch screen
touch screen
300 mbps wifi
There are opinions both ways on whether the SoundBlaster's (mostly PC cards not USB) are better than the built in sound "cards" (chips). In the past the SB's were better. Modern built in sound has come a long ways and many equal the SB's.
My own opinion the USB SB is probably better than the built in, in the small Atom based mini laptops, but it may not fix the dropout problem.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
So your saying in general because of how the computer was built I can't put a band aid on how it cuts off after a hour..
windows 7
1g
INTEL GMA 3150
iMo Pivot 7" touch
touch screen
touch screen
300 mbps wifi
No, I'm not saying its the way it was built - the problem could happen in any PC. Just that a different sound "card" may not make a difference and there could be some other reason it cuts off (If it still does with the SoundBlaster I would look at the other programs that are loaded at start up and running, as potential causes).
I had a Samsung Netbook with an Atom CPU. It had limited memory (I think 2GB) which doesn't leave much memory for mutiple applications to run at the same time.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Well I Dont have any programs loaded. It has 1gb of ram. The usual function for this computer is just to play music .if its not turn all the way up it won't cut off . It may have programs running in the background that aren't being used but just load on start up.
windows 7
1g
INTEL GMA 3150
iMo Pivot 7" touch
touch screen
touch screen
300 mbps wifi
