Solved Fan Cooling Vs Water Cooling
  • Air
    Votes: 14 70.0%
  • Water
    Votes: 6 30.0%
  • Total voters
    20
YTBOY83
Pro User
1:34 PM
What do you think is best Fan Cooling Or Water Cooling????????:D
Windows 7 64Bit Ultimate Edition SP1AMD Phenom II X5 955 @ 3200 MhzG.Skill 12GB DDR3 1333MHzPalit GeForce GTX 550 Ti OC Sonic 1GB
Customised
Asus M5A99X EVO
Onboard
LG 32" HDTV
1920x1080 @ 60Hz
Internal 250GB SATA 3.0 Western Digital WDC WD25 00AAKX-001CA0
Internal 500GB SATA 2.0 Seagate ST350041 3AS
Internal 500GB SATA 2.0 Western Digital WDC WD50 00AAKS-00WWP
External 1TB USB 2.0 Western Digital
External 2TB USB 2.0 Buffalo
Colors-IT 750w BLACK 12CM Silent
Xigamatek CPC-T45UB-U01 Asgard Chassis
4 120mm Fans In Total
ADVENT Illuminated Keyboard
Genius
30MB
CPU Cooler - Cooler Master Hyper 212 Plus Cooler
Air cooling because i believe that water cooling is a pain to deal with. just have some extra fans, and your good to go.
Windows 8.1 Pro x64Intel Core i5-4570 CPU @ 3.20GHz8GB DDR3-1596 - Dual ChannelNVIDIA GeForce GTX 750 Ti SC
Windows 8.1 Pro x64
Gigabyte Z87-D3HP-CF
Onboard
Samsung
SSD - 120GB
Second - 1TB
  • Like
Reactions: JMH
I read this:
Fans work and so does liquid but think about it electronics and water don't mix. If you have a leak or some issue with connections you can destroy the entire machine. If a fan goes bad it just goes bad and maybe it goes bad and you lose a processor. Water can take out the whole board and supply and all. If you do it its expensive and needs to be done by someone who knows what they are doing unless they will pay to replace everything. Liquid has a lot of advantages being that it will have a constant movement of liquid across the components which will reduce heat tremendously. The price is a bit steep for a good system but if you are a gamer or designer of some sort then it is pretty good. If you get these new fans with the cooling pipes to disperse heat and the fan regulators to adjust for the environment. Thermaltake is pretty good with them. I have a home server and i put a Thermaltake Blue ORB in the machine its massive but my machine hardly gets hot at all. The new processors will get hot quickly because of their capabilities. If you have fans/coolers on each component, intake fans on the case, and and exhaust fans on the case so you can remove the hot air from the case so it isn't just swirling around. Intake should be on the front and the side but at least the front. Exhaust should be 2 fans on the back without being butted up to something. If you have the workstation in a closed compartment or area where it isn't opened then it will cause you machine to overheat quickly. I used to run mine in a desk cabinet and i could open it and cook eggs. I recommend having it out in the open off the floor with nothing at least 8+inches from the intake/exhaust fans.
Customised
Asus M5A99X EVO
Onboard
LG 32" HDTV
1920x1080 @ 60Hz
Genius
30MB
  • Like
Reactions: JMH
Thats an extremely good point. With that in there i definitely go with fans XD
Windows 8.1 Pro x64
Onboard
Samsung
SSD - 120GB
Second - 1TB
Fans and fins can only do so much. Water and alternate methods run the whole gambit from wild external radiators to small sealed systems like my H50. If your concerned that a leak could happen and you have low or no sights on OC'g then go with fans. Water is maturing into a affordable tour de force for the extreme gamer but great thought must be given to the rewards vs risk.
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
Water cooling is generally better as it's more effective. However, it has serious drawbacks like complexity, and cost.
For me personally, I'm all air cooling. And I typically just stick with whatever the case comes with (in the case of my Antec P182...it's 3 x 120mm case fans). I use the stock cooler on my Q9550 quad core and I run a small overclock (from 2.83ghz to 3.20ghz). Everything is just fine with that setup. Heat has never been an issue.
Windows 7 Ultimate x64Intel Q9550 2.83Ghz OC'd to 3.40Ghz8GB G.Skill PI DDR2-800, 4-4-4-12 timingsEVGA 1280MB Nvidia GeForce GTX570
Self-Built in July 2009
23" Acer x233H
Intel X25-M 80GB Gen 2 SSD
Corsair 620HX modular
Antec P182
stock
ABS M1 Mechanical
Logitech G9 Laser Mouse
15/2 cable modem
Sometimes less is more. And sometimes more is more. lol
One other point is fans draw in lots of dirt and dust so regular cleaning of the fins, fans and components is a must.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
Ha ha, that totally sucks when i have to do that, but compressed air helps lol. Wonder if Deodorant would work lol.
Customised
Asus M5A99X EVO
Onboard
LG 32" HDTV
1920x1080 @ 60Hz
Genius
30MB
Water cooling isn't.. unless you're foolish enough to use water as a cooling medium.. if there's a leak it can destroy your system. It's safer to use a silicone based transformer coolant or even cooking oil
Excellent point it should actually be called liquid cooling as most all in the know use a non conductant liquid.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
Tis why I insist on running cases with air filters.
This is what my CPU fan looked like and my rear case fan on my Antec P182 after 8 months of use, sitting on a carpeted floor in my basement; And before anybody asks, no I did not clean it out with air first. I only cleaned my air filters in my case at the beginning of each month.
23" Acer x233H
Antec P182
stock
ABS M1 Mechanical
15/2 cable modem
Does not even look that bad man.
Customised
Asus M5A99X EVO
Onboard
LG 32" HDTV
1920x1080 @ 60Hz
Genius
30MB
I know...it's because I run a case with air filters and that garbage doesn't make it into my PC.
That's my point..with good filters...you don't have to clean regularly...as it doesn't get dirty.
23" Acer x233H
Antec P182
stock
ABS M1 Mechanical
15/2 cable modem
It also help if your case comes with some fans. Sure, that will mean you need a tad bit bigger power supply, but it is all worth it in the end. Especially if you have a high-end server, or gaming computer.
Windows 8.1 Pro x64
Onboard
Samsung
SSD - 120GB
Second - 1TB
pparks1,
Very impressive, I use filters as well but still get a build up after 3-4 months. I think a lot of component issue are directly connected to dust build up and heat, I hear enough dust can actually conduct current.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
Air is the better way to go. Like others said, dust is about the only problem. If you want to overclock on air, I would definitely recommend the thermaltake frio if you can fit it in your case. It's cheap and keeps my cpu less than 45c under load at 4ghz.
Windows 7 Pro x64, Windows 8.1 x64i7 960 @ 4.0ghz, i7 5820k12gb corsair 1600mhz, 32gb corsair vengeance ...EVGA GTX 480's SLI, EVGA GTX 980's SC SLI
Asus P6X58D-E, EVGA X99 FTW
12gb corsair 1600mhz, 32gb corsair vengeance @ 2666mhz
Intergrated 7.1, Intergrated 7.1
Samsung 46", I-inc 28"
1920x1080/ 1920x1200
2x Kingston 120gb SSD raid 0 and 2 1tb WD Black HDD's, 2x Kingston 120gb SSD raid 0 and 2x Kingston 240gb raid 0
Xion 1000w, EVGA 850gs
Cooler Master HAF 932, Cooler Master HAF X
Thermaltake frio, Thermaltake Water 3.0
Logitech MK 700
Logitech MK 705
Comcast 50mbps
2 Laptops, ASUS G50vt-x5, ASUS G750jw
I believe there is no right or wrong way comparing todays sealed water system with air cooling. It all boils down to a person preference. I was air and now I prefer water or liquid cooling. The non sealed liquid systems are the best of the best, but best if left to true enthusiast as they require vast amounts of installation and maintenance knowledge which slots nicely with extreme OC'g and gaming !
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
Eh...My cousin has ruined 2 complete systems from his liquid cooling either rupturing or failing and he had both 'professionally' installed. One ruptured when he went to swap out his GPU and ended up nudging a hose the wrong way. The 2nd time he left his PC on during the summer with his door closed from the central air and it just plain overheated, caused the PSU to spark and shorted out the MoBo, all his RAM, the CPU, everything lol. This last system he bought he went with liquid cooling again and I'm just waiting to add another story to the mix.
Get a good, big, open case. Several nice big ole fans. A V8 fan for the CPU and you should be set. I don't ever plan to run liquid cooling in something I sunk a grand worth of hardware into. EVER.
Windows 7 Pro 64 bit RTMAMD Phenom II 965 Black edition8GB (4X2GB) DDR3 1600 Kingston HyperXEVGA DS SuperClocked 01G-P3-1567-AR GeForce G...
CyberpowerPC
MSI NF750-G55
EVGA DS SuperClocked 01G-P3-1567-AR GeForce GTX 560 Ti (Ferm
Onboard Realtek 7.1 HD audio w/5.1 surround sound set-up
42" LG m4225c
320GB SATA-II 3.0Gb/s 16MB Cache 7200RPM
700 Watts Power CoolerMaster Silent Pro
Apevia X-Cruiser 2 w/12 inch Cold Cathode lighting (blue)
CoolerMaster V8 w/2 12mm case fans (front/back)
Someday I'm going to try to build an immersed system..overclocked dual socket mobo and triple or quad SLI in the smallest home built box that will hold it, pump the coolant through a heavy duty transmission cooler radiator to keep the system at or just above room temperature... might even double as a space heater for the 6 months of winter we get every year where I'm at. 1500 watts is 1500 watts whether it's going through heating coils or silicone. That's a lot of heat to get rid of.
