general connection problem
letardo
3:05 AM
Hi guys
I have a problem with my connection to internet, this what happened:
Like a week ago i was attacked by "win 7 antimalware 2010" malware, and i manually removed following this steps
http://www.spywarevoid.com/remove-win-7-an...10-removal.html
when i finished i had a problem with all my programs (sorry didnt save the error code), which I solved creating a new administrator account. The only problem is that my internet conection is down for all (skype, IE 8, firefox, utorrent, etc) except 1 program: KTrader Version 4.00 Build 225 .
i already tried to reinstall windows 7 but it appers an error saying that i have to restart my computer to do the reinstall
Plz i really need help with this I dont know what to do
windows 7
Hi, two things to try to start off with:
Make sure your LAN/WLAN drivers are up to date (this is almost certainly not the problem but worth doing anyway)
Do a system restore to before your PC was infected.
Post back with any developments.
Oli
Apple MacBook 5,1
Windows 7 Profesional x86, Mac OS X 10.6 Snow Leopard
Intel Core 2 Duo 2.4Ghz
4GB DDR3
Nvidia 9400m
13.3" Internal + 22" DVI + 21.5" USB
1280x800 + 1920x1080 + 1920x1080
Internal SATA 2.5" 500GB (395GB Mac HFS+, 105GB Windows NTFS)
2.48TB RAID consisting of 5 disks (HFS+)
Aluminium Unibody
Apple Late 2009 Wireless Keyboard (US)
Apple Magic Mouse
6.33Mb/s up. 0.36Mb/s down.
Harman Kardon Soundsticks II Speakers
i reinstalled all my drivers and i only have a backup point when my computer was infected.
any suggestions?
windows 7
Maybe not everything is removed!
Run Malwarebytes (free download) in Safe Mode!
Hijjackthis can also be of some help.
WIN 7 x64
Apple MacBook 5,1
4GB DDR3
Nvidia 9400m
Aluminium Unibody
Apple Magic Mouse
ok did all that but my computer is malware free, i have the windows 7 DVD maibe i have to format?
windows 7
Don't format your hard disk yet.
Try opening an elevated command prompt (Search in the Start Menu for CMD, Right click on the first result and click open as administrator)
Type 'netsh winsock reset' without the quotes into command prompt and press enter.
Restart your PC.
Hopefully this will do the trick.
Oli
Apple MacBook 5,1
4GB DDR3
Nvidia 9400m
Aluminium Unibody
Apple Magic Mouse
I reseted the netsh winsok succesfully restrted and nothing
windows 7
maybe need reenter firewall exceptions, try remove all that programs from firewall list, and when open program, firewall should ask for unblock
hi....
Open CMD....
Reset WINSOCK entries to installation defaults by typing: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults by typing: netsh int ip reset reset.log
Restart your PC
and
what do you mean by this ?
windows 7 ultimate 64 bit,Windows 7 ultimate 32 bit,Windows XP sp3 home
Sorry for my bad english, i mean windows can repair it self by reinstall or thats what someone told me. When i try to reinstall something goes wrong and the setup tells me that i need to restart my computer.
Ok, did all the winsocks resets and nothing.
My firewall is off
windows 7
My firewall is off
reinstall is different from repair install ...as you have mentioned earlier ...
scanners come clean....winsock didn't help ...so you should go for http://www.sevenforums.com/tutorials/3413-repair-install.html
Sorry for my bad english, I mean someone told me to reintall windows 7, but the setup sends an error saying that i have to restart windows to it, when i restart the same error appears.
I did all the resets and nothing
my firewall is off
windows 7
hello.........you should go for....http://www.sevenforums.com/tutorials/3413-repair-install.html
detailed instructions are provided in the tutorial go through them ...its your best bet if you want to avoid format and reinstall.
myfirewall is off
ummm...have you disabled it?
before repair install go to safe mode with networking and check for net connectivity plus scan with mbam in safe mode once.
how to go to safe mode:
1.To begin entering Windows 7 Safe Mode, turn on or restart your PC.
Just before the Windows 7 splash screen press the F8 key to enter Advanced Boot Options.
2.choose...Safe Mode with Networking and press Enter
nothing happened, i tried to do the reinstall but I cant maibe the versions r not the same (its not the same DVD) i tried to format but i changed the boot priority in BIOS and windows starts anyway.
I hate knowing nothing about PCs...
windows 7
that might explain the error on repair install...
i tried to format
remember if you install a different version you need a separate/new key for getting it activated
that is because the first boot option might be set as hdd...to change
start/restart pc....press Del or F2 key(press repeatedly) to enter bios setting..go to boot order/option setting....change the boot order to dvd drive..save and exit
for detailed instruction see here..Boot Order - How to Change the Boot Order in BIOS - BIOS Boot Order
same here:p
