help a nOOb buying pc parts
Gilly
Power User
2:53 PM
manchester ,England
i need some technical advise about buying some new parts for my
heres the graphics card i want
http://www.ebuyer.com/product/155497
it has alot of positive reviews (or is there better ATI gpu's than this for £100 on ebuyer
then i need a psu for 40£
but this is where i need most advise which one to get, what has right connections for this card
in my pc (bare in mind im new(total nOOb) to this) on my current psu i have ,one connection going to sata dvd drive with a four pin plug on the end of that what fits to something what im not to sure what it connects to
then obviously i have the 20 plus 4 what connects to motherboard then another one with 4 i think ,what also connects to mother board
and another one for sata drive and on the end of that theres a little white plug whats not connected to anything
i really dont want to buy psu and its totally got wrong conections
help muchly appreciated
"edit"..... will this one do the job?
http://www.ebuyer.com/product/124927
specs ,,,,, acer aspire m3201
9150e phenom quad core 1.8 ghz
2 gig ram 800 mhz
current psu 240 wat
7 RTM 64bitAMD Phenom 965 B3Corsair 4GB (2x2GB) DDR2 800MHz/PC2-6400 XMS2...PowerColour HD 5770 CF 16x-16x
7 RTM 64bit
AMD Phenom 965 B3
ASUS M3A79-T DELUXE
Corsair 4GB (2x2GB) DDR2 800MHz/PC2-6400 XMS2 Memory Kit CL5
32"
Hitachi
1tb 7200rpm
Be Quiet Straight Power 650wat
Asus TA-M series
CoolIT Eco ALC Water Cooling System
Microsoft wireless Keyboard
Microsoft wireless mouse
Hi Gilly,
I have bad news for you. You do need to buy another psu, not just for the missing connections, but I saw in your specs it's a 240watts.
That is never going to work for a Quad core, the new graphicscard and all the other stuff.
I recommend at least a 450 or 500 watts model.
They are not that expensive nowadays.
If you want further help on putting this together, please make pictures of all your parts, and I will write you a tutorial, ok?
You can PM me if you want.
Good luck,
Greetz.
Win7 Build 7600 x86Pentium II 300MHz32mb EDO RAMDiamond Viper
Win7 Build 7600 x86
Pentium II 300MHz
Asus
32mb EDO RAM
Diamond Viper
Soundblaster 16
14" AOC CRT 16K color
800x600
300mb Quantum fireball
110 Watts
Passive
Trust Ergonomic
Generic
256K u 128K d
7 RTM 64bit
AMD Phenom 965 B3
ASUS M3A79-T DELUXE
32"
Hitachi
1tb 7200rpm
Asus TA-M series
you are certainly right when you say you will need a new psu, at least 500W to be on the safe side.
see the picture below to see what needs to be plugged into your card - 2 x 6-pin power connectors.
all modern psu's will come with at least one as standard, and most graphic cards come with an adapter included in the box which will fit onto either a spare sata or molex cable from your psu.
the skinny black one is sata, the chunkier white is molex.
hope this helps!
(ps - i'm off to bed now as it's nearly 1am over here, so i can't reply for a few hours - but as you know, there are a lot of helpful folks here who can assist you :))
**oh, someone got there first - good luck**
ultimate 64 sp1i5 2500K [email protected]8 gigs GSkill Ripjaws 1600amd hd6950
mickey megabyte 1234
ultimate 64 sp1
MSI P67A-GD53
amd hd6950
creative x-fi gamer
samsung 24"
antec 550
antec three hundred
i'm a cooling fan
saitek eclipse ii
logitech g3
about 4 Mbps
i love win7
yes i know ineed psu thats what im asking for advise buying one from
Cheap Computer Power Supplies at Ebuyer - Huge Range In Stock Now!
this site but im unsure what connections i need
Ok, sorry, didn't get that from your question, I thought you were asking what the connections mean. lol :D
Mickey did a great job with the pictures.
Don't worry, like he said, all the modern PSU's have all the necessary connections.
But if I have to pick a few personal favourite brands, I would say Enermax, Coolermaster or Sharkoon.
Also make sure you buy some extra 9 or 12cm cooling fans (which ever suite your case), because with the new PSU, the Quadcore and the new Graphics, it's gonna get hot in there.
Good luck.
PM me if you need help putting it together.
Greetz
Win7 Build 7600 x86
Pentium II 300MHz
Asus
32mb EDO RAM
Diamond Viper
Soundblaster 16
800x600
110 Watts
Passive
Trust Ergonomic
Generic
256K u 128K d
7 RTM 64bit
AMD Phenom 965 B3
ASUS M3A79-T DELUXE
32"
Hitachi
1tb 7200rpm
Asus TA-M series
No extra cables required. (i assume the you already have the sata disk to mainboard cables).
After installing, check your temperatures, and install extra cooling fans that get the warm air out before it gets too hot in there.
Good luck.
Win7 Build 7600 x86
Pentium II 300MHz
Asus
32mb EDO RAM
Diamond Viper
Soundblaster 16
800x600
110 Watts
Passive
Trust Ergonomic
Generic
256K u 128K d
Good luck.
ok thanks, yes i have plenty sata disk in mainboard
im gonna get some fans
but havent got a clue where to fit them or what type of fan i need:o
7 RTM 64bit
AMD Phenom 965 B3
ASUS M3A79-T DELUXE
32"
Hitachi
1tb 7200rpm
Asus TA-M series
but havent got a clue where to fit them:o
No exit holes with four screwholes at the back of your case?
Maybe then you need another case too. This is a powerful machine you are putting together, and good cooling is necessary.
Win7 Build 7600 x86
Pentium II 300MHz
Asus
32mb EDO RAM
Diamond Viper
Soundblaster 16
800x600
110 Watts
Passive
Trust Ergonomic
Generic
256K u 128K d
yes i think so its like a grill with holes and 4 screw holes so i presume so:D
does that fan just fit in behind them holes inside the case?
7 RTM 64bit
AMD Phenom 965 B3
ASUS M3A79-T DELUXE
32"
Hitachi
1tb 7200rpm
Asus TA-M series
You have to measure the distance between two holes.
That tell you the size of the fan.
They can be 6,7,8,9 or 12 cm.
Make sure you measure for example the distance between left upper to right upper hole, or left upper to left lower lower. Not left upper to right lower.
I hope you know what i mean. :D
Like this o------o
or like this
o
o
Win7 Build 7600 x86
Pentium II 300MHz
Asus
32mb EDO RAM
Diamond Viper
Soundblaster 16
800x600
110 Watts
Passive
Trust Ergonomic
Generic
256K u 128K d
...or thinking about it, who needs a psu? :D Get fit instead! :p
ultimate 64 sp1
MSI P67A-GD53
amd hd6950
creative x-fi gamer
samsung 24"
antec 550
antec three hundred
i'm a cooling fan
saitek eclipse ii
logitech g3
about 4 Mbps
i love win7
Yeah, I considered that option. And surprisingly skipping quad cores and going non-sli with low end video cards seemed like a great option :D
Windows 7 Ultimate x64Intel Q9550 2.83Ghz OC'd to 3.40Ghz8GB G.Skill PI DDR2-800, 4-4-4-12 timingsEVGA 1280MB Nvidia GeForce GTX570
Self-Built in July 2009
23" Acer x233H
Intel X25-M 80GB Gen 2 SSD
Corsair 620HX modular
Antec P182
stock
ABS M1 Mechanical
Logitech G9 Laser Mouse
15/2 cable modem
