Hey ZigZag,
Thx for the reply. BEen running without Kaspersky (used kasp. removal tool) and MSE installed 2 days now. Improved stability a liottle an extended time between BSOD. But after that and some driver verifier runs, the stop code changed from 0xd1 to 0xa not quite shure what i did to make the transition. Nearly finished with Back up, win7 cd is ready to format.
I was wondering will this help? What i mean is: I reinstall baseically the same software ( since im not quite sure which driver cause d the problem) and drivers (since all my drivers were basically up to date), how likely is it to get the same BSOD errors again? If revert my system in much the same state, but in systematical manner and without unecessary software, will my system likely be stable?
Thx!
Thx!
Windows 7 Professional 32bitIntel Core 2 Duo E6400 2.1 MHzCorsair XMS2 2 GB DDR2-800 DDR2 SDRAMATI Radeon HD 5700 Series (1024 MB)
- Windows 7 Professional 32bit
- Intel Core 2 Duo E6400 2.1 MHz
- Motherboard
- Gigabyte GA-965P-S3
- Corsair XMS2 2 GB DDR2-800 DDR2 SDRAM
- Graphics Card(s)
- ATI Radeon HD 5700 Series (1024 MB)
- Sound Card
- Realtek ALC883 @ Intel 82801HB ICH8 - High Def.
- Monitor(s) Displays
- Network Card: Marvell Yukon 88E8056 PCI-E
- Hard Drives
- 2 ext. USB western Digi.
2 int. Samsung 200Gb Seagate 320Gb
- PSU
- Be quite 450 Watt
, I spent to much time only to end up with the same SHIT!!!
