Help i need help with bsod blue screen problems
mateyani
11:40 AM
Hi all i hope you can help me,i have a lot of bsod blue screen error i will put them here to look at them and maybe someone can help me.thanks
windows 7 ultimate x64
Lenovo ThinkCenter, Custom Built PC, Acer Aspire V3-771G-9809
Windows 7 enterprise 64 bit, Windows 7 Pro 64 bit ,Windows 8 64bit
Core i5-2400, Athlon 64 X2 6400+ ,Core i7-3632QM
ASUS M4A79 Deluxe
4GB, 4gb g.skill ddr2, 8gb
Radeon HD 4550 sgb, Radeon HD 4870, NVIDIA Geforce GT 650m
dual samsung 22" monitors
500GB, Western Digital WD Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s, 1TB
Antec Twelve Hundred V3 Black Steel ATX Full Tower
ASUS Silent Square Pro
Razar Death adder
20 mbps
Hy again pls help me pls dont know what to do.....here i follow the steps from tutorial of forum post files i hope this one is good!
Sorry for the late response Been rather sick for the past few days. But I had a look through your files and if you could please do the following:
Enable driver verifier and allow it to crash your computer, if it has not crashed within 24 hours move on to the next step:
Driver Verifier - Enable and Disable
Tip: If you can not boot normally into windows after enabling Driver Verifier please boot into safe mode and then disable driver verifier.
If Driver verifier does not cause a crash after 24 hours please run memtest86+ for at least 8 passes:
RAM - Test with Memtest86+
Tip: Do this over night it can take a long time
ASUS M4A79 Deluxe
Razar Death adder
20 mbps
