help interpreting /? help listinf of netsh
edcompsci
1:46 AM
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [-u DomainName\]UserName] [-p Password : *] [Command : -f ScriptFile]
How does, say, this command:
netsh interface ipv6 show addresses
fit into the above format? For example, what is "interface", is it an Alias, Context, RemoteMachine, ..., etc.?
Ubuntu Lucid Lynx 64, WIndows Vista 64 runnin...AMD64GT9500
Ubuntu Lucid Lynx 64, WIndows Vista 64 running virtually on aqemu/kvm
AMD64
Zotac
GT9500
HP HD
It's a Command?
Usage: netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [-u [DomainName\]UserName] [-p Password | *]
[Command | -f ScriptFile]
The following commands are available:
Commands in this context:
? - Displays a list of commands.
add - Adds a configuration entry to a list of entries.
advfirewall - Changes to the `netsh advfirewall' context.
branchcache - Changes to the `netsh branchcache' context.
bridge - Changes to the `netsh bridge' context.
delete - Deletes a configuration entry from a list of entries.
dhcpclient - Changes to the `netsh dhcpclient' context.
dnsclient - Changes to the `netsh dnsclient' context.
dump - Displays a configuration script.
exec - Runs a script file.
firewall - Changes to the `netsh firewall' context.
help - Displays a list of commands.
http - Changes to the `netsh http' context.
interface - Changes to the `netsh interface' context.
ipsec - Changes to the `netsh ipsec' context.
lan - Changes to the `netsh lan' context.
mbn - Changes to the `netsh mbn' context.
namespace - Changes to the `netsh namespace' context.
nap - Changes to the `netsh nap' context.
netio - Changes to the `netsh netio' context.
p2p - Changes to the `netsh p2p' context.
ras - Changes to the `netsh ras' context.
rpc - Changes to the `netsh rpc' context.
set - Updates configuration settings.
show - Displays information.
trace - Changes to the `netsh trace' context.
wcn - Changes to the `netsh wcn' context.
wfp - Changes to the `netsh wfp' context.
winhttp - Changes to the `netsh winhttp' context.
winsock - Changes to the `netsh winsock' context.
wlan - Changes to the `netsh wlan' context.
Lenovo IdeaCenter 450
Windows 10 Pro X64
Intel Integrated HD Graphics
HP 22" LCD
250GB Samsung EVO SATA-3 SSD
Dell USB
Lenovo USB
Seamonkey
UEFI/GPT
PLDS DVD-RW DH16AERSH
Ok I see.
Confusing though that there is also -c which precedes Context above, but down in the part you posted the command also refers to a context.
AMD64
Zotac
GT9500
HP HD
Agreed, not one of the better helps in Windows.
Windows 10 Pro X64
HP 22" LCD
Dell USB
Lenovo USB
Seamonkey
UEFI/GPT
if my net dongle connection name is Reliance (as appearing in control panel - network,
what would be the batch file netsh command to connect to net and to disconnect from net?
Windows 7 Ultimate x86/x64 dual bootIntel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz2GB DDR2Intel 82945G Express Chipset Family v 8.15.10...
assembled locally.
ASUSTeK Computer INC. Model P5G-MX
2GB DDR2
Intel 82945G Express Chipset Family v 8.15.10.1930
Realtek High Definition Audio 2.65 v6..0.1.6449
LG Flatron W1943S
1360*760
Seagate SATA 250 GB, Seagate IDE 40 GB
beetel ATX
Intex
zebronics K06 non-multimedia
zebronics M05
3.1 Mbps reliance broadband+ (it crowls mostly)
C:\Windows\system32>netsh interface /?
6to4 - Changes to the `netsh interface 6to4' context.
httpstunnel - Changes to the `netsh interface httpstunnel' context.
ipv4 - Changes to the `netsh interface ipv4' context.
ipv6 - Changes to the `netsh interface ipv6' context.
isatap - Changes to the `netsh interface isatap' context.
portproxy - Changes to the `netsh interface portproxy' context.
set - Sets configuration information.
tcp - Changes to the `netsh interface tcp' context.
teredo - Changes to the `netsh interface teredo' context.
The following sub-contexts are available:
6to4 httpstunnel ipv4 ipv6 isatap portproxy tcp teredo
To view help for a command, type the command, followed by a space, and then
type ?.
C:\Windows\system32>netsh interface ipv6 /?
6to4 - Changes to the `netsh interface ipv6 6to4' context.
add - Adds a configuration entry to a table.
delete - Deletes a configuration entry from a table.
isatap - Changes to the `netsh interface ipv6 isatap' context.
reset - Reset the IP configurations.
6to4 isatap
type ?.
Windows 10 Pro X64
HP 22" LCD
Dell USB
Lenovo USB
Seamonkey
UEFI/GPT
Hmmm, why would you want to do this? I don't understand what you are trying to accomplish.
Perhaps ipconfig would be a better choice?
ipconfig /release to drop the connection.
ipconfig /renew to reestablish it.
Windows 10 Pro X64
HP 22" LCD
Dell USB
Lenovo USB
Seamonkey
UEFI/GPT
