HELP me correct my desktop display problem, Ati driver?
Hey? What makes you say that?
Artifacting and crashes as you described are indicative of VRAM and/or GPU instability. If it only occurs with CCC not Windows drivers or in safe mode then I suspect that the ATI drivers are adjusting the clock. I suggest using GPU-Z Video card GPU Information Utility to inspect the clocks and temperatures under CCC and in safe mode or with Windows drivers.
Great points baarod!
Geege:
Are you overclocking either the CPU or GPU? If so back it down to stock and report back. You may also try uninstalling any ATI/Sapphire utilities and go with driver only!
Also, does your mobo have more than 1 PCIE slot? If so, try moving it over...
Homebrew PC - "Alpha_Dawg"
Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
Intel Core 2 Quad - Q9550 - 2.83GHz stock - OC'd to 3.6GHz
Gigabyte EP45-UD3P
4GB DDR2 800MHz (PC6400) OCZ Reaper
Nvidia GE Force 8800 GTS
Asus Xonar DX
Samsung SyncMaster 2333HD
WD Caviar Black 750GB - 7200RPM - 32MB cache
WD Caviar Green 1.5TB - 5400RPM - 64MB cache
WD Caviar Green 2.0TB - 5400RPM - 64MB cache
PC Power & Cooling Silencer 750
Gigabyte 3D Aurora
Case is Air - 5ea. 120mm fans (mix of Arctic and Xigmatec)
MS Natural Wireless KB
MS Wireless Mouse
50 mbps down/5 mbps up
AVerMedia - AVerTVHD G2 Dual Tuner Card
No I haven't overclocked it, in fact I tried underclocking it and upping the GPU fan to see if the artifacts would go away, but no joy. I will try swapping it from PCI-E to the next, but I think the bottom slot is only 8x while the top on is 16x speed.
Windows 7 64-bit
Intel Core 2 Duo E8600
Biostar T-Power i45
4GB Crucial Ballistix Tracer 800MHz
NVidia 8800GTS 512MB (G92)
NEC MultiSync 24WMGX3
OCZ Vertex 120GB SSD
Corsair HX1000W
Coolermaster Cosmos S
ASUS G60-RBBX05
Win7 Home Premium 64x
16" LED Backlit
ASUS G60 Laptop
Mobo: GIGABYTE GA-990FXA-UD3
You'd need 2 identical slots to move. Try uninstalling all ati/sapphire apps... then manually install the driver only.
Gigabyte EP45-UD3P
Asus Xonar DX
Gigabyte 3D Aurora
MS Wireless Mouse
Rather than swapping blindly I suggest root cause analysis. Use GPU-Z to look for behavioral differences between Windows drivers and ATI with and without CCC. My guess, if you're not o/c on purpose is that Sapphire adjusted the dynamic overdrive nvram on the card and/or the dynamic fan control. Neither of those functions are enabled with the stock Windows driver.
Oh, and another thing... You didn't install Folding at Home with the CCC package did you?
Apple
El Capitan / Windows 10
i7-4980HQ
16GB
Iris 5200
I looked into that download... its a zipped exe file... no way to install drivers only. Try removing just the catalyst app and see if correct driver remains.
The way I see it you really have a few options left... Return or exchange the card... contact Sapphire directly since they list Win7 64 bit compatibility, or since Sapphire provides a WHQL driver... try that 1?
Gigabyte EP45-UD3P
Asus Xonar DX
Gigabyte 3D Aurora
MS Wireless Mouse
Have you tried checking your monitor settings? Just a thought.
Custom built
AMD Phenom II X4 965 Black Edition
Gigabyte GA-MA790X-DS4
GSkill 4 X 2 GB PC 8500
XFX Radeon HD 6790 D
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
