Hi all. Need solution for my graphic card problem.
Legendation
2:09 AM
Hi all,
I am using a Sony vaio laptop VGN-SZ75GN. I recently upgraded my windows vista busniess 32-bit to a windows 7 ulitmate 64-bit using a clean installation.
I have a external graphic card which is NVIDIA® GeForce® 8400M GS notebook graphics processing unit(GPU) (SPEED MODE) / Intel® Graphics Media Accelerator X3100 (STAMINA MODE). After installing Windows 7, it couldn't detect the graphic card. This was done by looking at the device manager saying that it only detected a stardard VGA Graphic Adapter. I tried to check for updates, but it said that the stardard VGA Graphic Adapter was the best driver software. I looked around the forum like a headless chicken and couldn't find a solution for my laptop.
Can anyone find a solution for my problem? Will be very much apprieciated.
This are some of the pictures of my laptop's specs.
Yours Sincerely,
Legendation.
Windows 7 ultimate
self built
7600.20510 x86
P4 550 3.4 GHz HT running at 3.5 GHz
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
OCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHz
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
Hi Torrentg,
I cannot seem to find NV_DISP.inf anywhere? Thanks for the fast response.
Legendation.
Windows 7 ultimate
You're welcome.
If you ran the .exe that you downloaded in step one, it will have extracted to C:\NVIDIA folder.
The exact location of the .inf is inside this folder -
C:\NVIDIA\DisplayDriver\191.07\WinVista_Win7\English
Make note of that because you will have to click on it as part of the install process, after you edit it.
Let me know how it goes for you and also take special note of the condition for this to work for x64 users, in the OP.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
I had the EXACT same issue with 2 different chips. Install the old vista drivers in compatibility mode, reboot, then run the new drivers. Use the uninstaller first from the new graphics card. I wouldn't recommend disabling driver enforcement. It has its uses in a 64-bit environment.
Sony Vaio Z46GDU
Windows 7 Ultimate x86-64
[email protected] 1066MHz FSB
Sony branded
6GB DDR3 1066MHz
9300M GS 256MB Dedicated (Speed) + Intel4500MHD (Stamina)
13.1' WXGA
1600x900
320GB 7200RPM w/ 16MB cache
1MB/s
Hi torrentg,
I have extracted the driver file. This is the location -
Local Dick ( C : )-NVIDIA-DisplayDriver-186.81-International...
In the international folder there are Display folders, HDAudio Folder and other files. Dont' seem to see the NV_DISP.inf file.
Legendation.
Windows 7 ultimate
Go to C:\NVIDIA
In the top right search box, enter *.inf then hit enter.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Hi torrentg,
Sorry for the mixed up. The driver that I'm suppose to install is the desktop driver? So if I have a 8400M GS, I'm suppose to download the 8400 driver?
Thanks for the response. Hope to hear from you soon.
Legendation.
Windows 7 ultimate
Yes. Follow what it says in the link I posted in #2 above.
You're going to have slight problems because of the intro to the post there, but you really should have installed x86 version on that machine. If you follow well, will work well though. Look down in the thread for how to disable driver enforcement.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Hi torrentg,
Alright, thanks for the reply. Will get back to you once I'm working on it. Thanks.
Legendation.
Windows 7 ultimate
Hi torrentg,
This is the box that came out once I installed.
Windows 7 ultimate
There's something you're doing wrong. Can't say for sure though.
Did you download the correct version for your Windows? Either x86 32-bit or x64 64-bit?
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Hi torrentg,
This is the box that came out once I installed the *inf file. What do I do next? Thanks for the continuous replies!
Legendation
Windows 7 ultimate
Hi torrentg,
It is a windows 7 64-bit.
Windows 7 ultimate
I have done it til step 10. About step 11, which setup file is it? The desktop driver or the mobile driver? Thanks.
Legendation.
Windows 7 ultimate
My graphic card is a Nivdia Geforce 8400M GS not a GT. Wonder if there is any effect on the rewriting of the strings for the post you made for making the decktop to laptop driver. Thanks.
Legendation.
Windows 7 ultimate
Legendation.
If you made it to step 11, the video driver is now installed and ready for use. The setup.exe is the one you downloaded in step 1.
Legendation.
GS, GT, anything, doesn't matter. You could name it after your first born child and it will work as long as strings and numbers are correct. Part in quotes makes no difference.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Hi torrentg,
Sorry about the confusion. I think is the string that is needed to be retyped. I looked into the NV_DISP.inf file and saw a few of my Nvidia Geforce 8400M GS strings are ,"NVIDIA_DEV.0404.01 = "NVIDIA GeForce 8400 GS", NVIDIA_DEV.0422.01 = "NVIDIA GeForce 8400 GS " ,NVIDIA_DEV.06E4.01 = "NVIDIA GeForce 8400 GS " In your post about the desktop to laptop driver, it states on step 8 that you add this, 6&SUBSYS_9016104D to the back of the string. Do I need to type that on the back of my string which is me graphic card? Pretty confused right here. Thanks once again.
Legendation
Windows 7 ultimate
No, that's ok though.
You have to make the line precisely as yours is.
This is how you find your line:
"Open device manager. Right click on standard vga or your video card and choose properties. Details tab. Change drop down to hardware ids. The second line down is of interest here."
So edit to make exactly like the second line down when you do that (leave out the "PCI\" part.) Make the same but keep the format of it too.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Hi torrentg,
Alright this is my device string found in the device manager - hardware ids
DE&DEV_0427&SUBSYS_9016104D
So what I do now, is I go to the NV_DISP, change one of the string to
%NVIDIA_DEV.0427.01% = Section010, PCI\VEN_10DE&DEV_0427&SUBSYS_9008104D ? Is this correct?
Thanks for the patience.
Legendation.
Windows 7 ultimate
