How do I know if my device is running on USB 3.0 speed?
GTMoraes
7:14 PM
Hi.
I've bought a ThermalTake Muse 5G, and on the next day, I overstressed the connector and it broke.
I've re-soldered it back (a lot of work and hassle, hope I don't go through this again) -- making sure the fixture is reinforced -- and now, although the device is detected, I don't know if it's making use of those extra connectors.
Right now, I'm moving 143.886 items (156GB) from the external hard drive (the Muse 5G with a Toshiba mk5059GSXP, 500GB, 5400RPM, SATA II, 8MB Cache; USB 3.0 Connected). The estimated time left is around 5 hours and the speed is ranging from 26MB/s to 36MB/s.
At the moment I'm writing this, it started to transfer one big single file, and the speed went up to 42MB/s
I used to get around 25MB/s on USB 2.0, and this speed could be enough to ensure that the device is working on USB 3.0 mode, but I'm still not sure. Is there something that I could run or see to make sure of that?
USB 3.0 Drivers are properly installed and I'm running on Windows 7 x64 Ultimate.
Time left decreased to 1 hour left, and it is stable at 43MB/s
Windows 7 Ultimate x64 Custom / Windows2Go / ...Intel Core i5 2310 @ 3.1GHz6GB DDR3 1333MHz KingstonEVGA GTX550Ti 2GB Version @ 1000MHz
OH, the fins do move
Windows 7 Ultimate x64 Custom / Windows2Go / Ubuntu
Asus P8H61-M LE/BR
Realtek ALC889A X-Fi Mod
Samsung SyncMaster P2250 / LG 42LM3400 3D
Hitachi 320GB SATAII
Samsung 1.5TB SATAII
ThermalTake Muse 5G USB 3.0 with Toshiba 500GB 2.5"
Seventeam E-Force 550W
xPredator X1 White
six 12CM BladeMaster fans, two side 14cm Akasa Viper
Microsoft Wireless Keyboard 3000
Microsoft Wireless Mouse 5000
GVT 10MBPS
Always amazing people with the moveable fins on top of the Xpredator.
Sounds about right to me, my usb 3 drives and flash mem usually transfer single files around 35-45
Win7 Ultimate X64Intel i5 3570K8GB DDR3 1600Onboard
Pauly Special
Win7 Ultimate X64
Intel i5 3570K
Gigabyte Z77X-DS3H
8GB DDR3 1600
Onboard
Onboard
1280x1024
Samsung 840 Evo SSD (OS)
1TB Spinner (Data)
800W Arctic
Cooler Master
3x120mm Fans
MS Wireless
MS Wireless
20M
It just finished. Wow, this thing is too damn fast.
Asus P8H61-M LE/BR
xPredator X1 White
GVT 10MBPS
The speed of a USB 3 interface is 5 Gb/s but no conventional drive can come any where near that. In practice your performance will be limited by that of the hard drive. The speed you were getting seems about normal. The estimated copy time is only that, an estimate. Actual times can be very different.
Windows 7 Pro 64 bitXeon W35208 GBNvidia Geforce 210
HP
Xeon W3520
8 GB
Nvidia Geforce 210
That's been my experience too. I've been using USB 3.0 for a while with an external SATA drive, and while I can achieve peak speeds of 100+, the average is around 50. That got better when I went to Sony a while back and downloaded the firmware and driver updates for my Renesas 3.0 chip. If you have the same chip, you should check the Sony site.
Win7 Pro 32-bit, Win8 Pro 32-bitAMD Phenom II X6 1090T4GB ddr3 1300AMD HD 4290 onboard
Gigabyte
4GB ddr3 1300
AMD HD 4290 onboard
Builtin Realtek HD Audio
1920x1200/1920x1080
Kingston 256GB SSD
Logitech Illuminated Keyboard
Logitech M705 wireless mouse
Norton Av 2013
IE v10
I've heard about upgrading firmware, but I'm a bit scared to do so. Still got to know which chip is mine, also.
It's a PCI-E x1 expansion card, and the familiar generic chinese product box which doesn't give any information about anything.
Oh, you meant the device firmware? I upgraded it, even put a custom name for it haha
Enabled some new features, but speed is the same. It's an Asmedia ASM1051
Asus P8H61-M LE/BR
xPredator X1 White
GVT 10MBPS
