HP Dv 5215us Battery Power Settings Issues
Beta
Pro User
10:25 AM
I have had this laptop since 2006. I know that that is means it a old laptop but runs great. However, since I installed Windows 7 Pro onto it, back in 2009, the computer slows the CPU speed after 1 min when you unplug the computer then speeds up 3 min later and then repeats. What advanced options do I need to do to get this to run correctly on the battery.
Asus
Windows 7 Pro x64 SP1 and Mac OS X 10.8.3
Intel Core i7-3820 Sandy Bridge-E at 4.75 GHz
ASUS Rampage IV Extreme
8 x Corsair 8GB DDR3 64 GB Kit @1866 Overclocked @2000
GTX 580 and MSI R6870
HDMI on GPU and ACL898
32" Sony EX-500 120Hz
1920x1080P
1 x Corsair Force Series GT CSSD-F60GBGT-BK (OS)
2 x Western Digital Caviar Black Sata III 750GB (Raid 0)
1 x Western Digital Caviar Black Sata III 1TB (Media)
2 x Western Digital Caviar Black Sata II 640GB (Raid 0)
Corsair Professional Series Gold AX850
Corsair 800D
Corsair H80 High Performance Liquid CPU Cooler
HP Wireless Elite Keyboard
HP Wireless Elite Mouse
Cable, VisionTek Bigfoot Killer 2100 Gaming Network Card
4 x GELID Solutions FN-TX12-15 120mm Case Fan with Superior Temperature Control
1 x Corsair 140mm Case Fan
1 x SilverStone FP55B Aluminum front panel 5.25" to a 3.5" bay converter
1 x Ultra Card Reader
1 x Sony Blu-ray Burner BD-5300S-0B
Hi Beta there is a setting for Processor power management under the advanced options where you can set the Minimum processor state which is normally set to 5%. Personally I would just select the Balanced power option but if you are having problems when using your laptop you could then try other settings. such as High performance, bearing in mind that the battery may not last very long.
Something I threw together
Intel Core i7-2600K
Asus P8P67
16 GB G Skill F3-10666 CL9D-4GBRL
ATI Radeon HD 6870
ATI Radeon HDMI / Realtek ALC892
2 x 22" standard monitors / LG32LC56v TV to watch films
1920 x1080
2 x OCZ Vertex2 111.79GB
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
1 x Hitachi5K320-160
Thermaltake Toughpower Cable Management 750W
Antec 300
Noctua NH-U12P SE2 and 5 120mm Case fans
Microsoft Comfort Curve Keyboard 2000
Hama M3110 / Logitech M305
I have also used Fedora, Suse, Ubuntu Linux
And all other Windows from 95 to date except ME
Yea, I have tried that before. The profiles do not fix this issues at hand.
Asus
1920x1080P
Corsair 800D
Then it doesn't sound like a profile problem, bearing in mind that the cpu is most probably designed to change speed depending on usage, if this is not what is happening then I would suggest looking elsewhere like maybe the chip set drivers
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
1920 x1080
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
Antec 300
Thanks.
Asus
1920x1080P
Corsair 800D
